Homemaker Every 10-15 minutes my mouse freezes up. How do I fix it? I'm not computer savy at all. Any help would be great!
  • grneyedmom Jan 22, 2008
    I have an optical mouse and I use a mouse pad. This problem with the mouse freezing up started after I had to do a system recovery because my computer crashed.
  • 48 Answers
First, try to identify if your mouse is either optical or mechanical.. if it is mechanical, try to clean the rollers.. if it is optical, use a mouse pad...
Posted on Jan 21, 2008
CHEST FREEZER NOT FREEZEING
2Possibilities. Some rat/mice may have chewed a wire or supply line to cause a leak or wire disconnect. Most likely you have a seal that has dried out and leaked the Freon out of the system. The compressor will turn on for a short while them turn off. Based on the age of the unit, repair is not advisable.
Oct 29, 2014 | Freezers
Mouse constantly freezes....plug it in and out since i got it now it just freezes every 5 minutes or so
you might have to uninstall the mouse and its drivers then restart your computer then reinstall the mouse and its drivers
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have the options update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver in
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
Windows 7
hope this helps
don
Feb 22, 2011 | Innovera 4 Button Wireless Optical Mouse...
I am using an HP ProBook 4510s. My touch pad keeps freezing on me. Sometimes it will work for a few minutes and then freeze and sometimes the computer boots up with the message No Mouse detected. Any...
I have a 4510s and had this problem before.
Part of the problem was synaptics driver was freezing, Driver Synaptics software upgrade may help if that is part of your problem.
Have you opened the notebook to upgrade or remove the HDD for any reason?
If so, you should make sure the plastic of the palmrest (which houses the touchpad mouse) has been correctly fitted back in place. It may also help to remove the palmrest and ensure the flexible cable is correctly inserted in the ZIF connector.
I also notice there are some contact points from the PC to the underside of the trackpad, it may pay to clean those with metho to make sure the electrical connection is good.
Sep 09, 2010 | Computers & Internet
The mouse froze up
Hi
First try rebooting your computer and see if it works.
else
Take a look at how many programs you have open when your mouse freezes up. If you are running multiple programs at once and have limited RAM, this can be a major cause of mouse freezing. The solution is either run fewer programs or simply purchase additional RAM.
You also want to make sure your mouse drivers are up to date. In these cases simply go to the manufacturer website and check for any driver updates you may have missed out on.
But the most common cause of mouse freezing is due to errors in the Windows registry. The registry contains settings and commands that are utilized by the mouse to run properly. When there are errors in the registry this can cause a breakdown in the communication between your mouse and system. When your computer cannot communicate properly it will lock up or freeze.
Unfortunately there is no way to manually fix this problem. The registry is an extremely complex directory that is also sensitive to alterations. If you adjust or remove the wrong registry files your entire system can collapse.
This is why I highly recommend scanning your computer with a top flight registry cleaner. Not only can it fix mouse freezing, it will also speed up your computer considerably. So stop asking why is my mouse freezing. Scan your computer for free below and fix the problem today.
Sick of your mouse freezing up? Want to repair computer errors the easy way? Scan your computer for free and fix corrupt registry problems with the #1 registry cleaner on the internet. After scanning your computer, I promise you will be quite surprised by all the errors on your system.
http://www.registry-clean-up.net
Jul 29, 2010 | HP Compaq Presario CQ60615DX Notebook
My apple mighty mouse works for a few minutes and then it just freezes up and I can't do anything. I have restarted the computer and all of that but is still freezes up after a few minutes of use.
Try hitting your capslock key (which will light up) or command-tab (which will switch between applications) to see if the keyboard and computer are still responding when this happens. If so, it sounds like the mouse or the USB port it is connected to may unfortunately be failing.
Also, try connecting the mouse to another USB port as others have suggested, either on the keyboard or computer itself, as this will help you determine if the failure is in the mouse or port.
Mar 31, 2009 | Apple iMac G4 20" Mac Desktop
My Dell Logitech Wire mouse freezes randomly.
Update drivers to latest for the mouse. Replace the mouse's batteries & recheck. Hope this helps.
Dec 26, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Guild wars crash
This is great but why you posted it like aproblem?
Dec 10, 2008 | NCsoft Guild Wars for Windows
Computer mouse freezes
Are they wireless or wired mice? Also try a different port. If using USB, try the PS/2 (adapter may be necessary )
Let me know how it goes..
Oct 26, 2008 | AcerPower Sn PC Desktop
Computer freezes when printer is on
I had this problem, and the only way to stop it, was to uninstall all the drivers for all of the other printers and scanner that had been previously attached to my computer. That and three system restores and 5 reinstalls of the AiO software, that has yet to install the Home Center or the Help files! I can't customize the printer but I can use it now through WIndows programs.
Jan 11, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Computers & Internet Logo
95 people viewed this question
Alun Cox
David Payne
David Payne
