Question about Philips DVDR3380/05 DVD Recorder
Wont record on new disc
Will record normal on previously used disc,but when I load in a brand new one it just shows updating
    Problem Solver:
Re: wont record on new disc - Philips DVDR3380/05 DVD Recorder DVD & Blu-Ray Players
I think you need to format your new discs.
Posted on Feb 05, 2008
0 characters
3 Points
I just bought a new spindle of DVD+R (Sony) and when I tried to burn a movie from TV/cable on one, it said that I couldn't record on this disc. I thought the disc was bad so I exchanged it with another...
Are you using a stand alone dvdr(not hooked to a computer)? If so some dvd-recorders(mostly older models) May only record either dvd-r or dvd+r. They are two different formats that for all intense and purposes do the same thing. If its an older DVD recorder there may be another problem and that is the recording speed. Check the previous disc that have recorded ok and see what the recording speed was. It will look something like... 2.4X, 4X, 8X. Brand could make a difference but my gut feeling is its the recording speed. Check you owners manual it should list brand name disc as well as the recording speeds to use.
Jan 03, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Device will not play previously recorded discs or record new info,but will play shop bought discs.on occasions it will display disc error. i am using new discs.
I Have had this same problem with DVD recorders. They sometimes will not play disc that were recorded on another player, you have to play these on the recorder that you used to make the recording. When recording you must finalize the discs to get them to play in other recorders, if they aren't finalized then the dvd wont recognize them as being recorded, there is no starting point set on the disc for the laser to pick up on. I have also ran into discs bought at the store that were not any good and I couldn't record on them, or when I did I would get the disc error message also. Try another brand of disc,say Memorex or Soney amd see if these will work, make sure they are compatible with the player, and they are the correct format for your player. There are 2 types DVD -R and DVD + R the + R work better on a wider range of players.
Nov 25, 2010 | Philips DVDR880 DVD Recorder
Philips DVDR3450H. How format the HD?
Found a document DVDR3450H_3452H_3460H_eurp FWUpgradewk635.pdf Describes procedure of firmware update and disc formatting. Some cut'n'paste from the document:
2. Preparations for new HDD
In the event when the set unable to boot up or recordings not stored due to an defective HDD, the HDD will have to be replaced with the steps describe below:
1. Replace the Faulty HDD with a new HDD.
2. Before connecting the new HDD on the Digital Board ,the jumper pin at the connector of the HDD is to be removed.
3. Connect the new HDD to the Digital Board.
4. Power up the set . It will open the tray and prompt to load the upgrading disc.(the upgrade disc is
the same disc under firmware upgrading.)
5. The set will display
6. Put the upgrade disc and close the tray and the set will show
“Copy” ……… “Boot”
7. The rest of the procedure follows the software upgrade given in 1B -Procedure to apply the firmware upgrade.
*Note : 1)Do not press any button or interrupt the main supply ,otherwise the set may
become defective.
2)When the HDD formatting is successful ,the set will go to standby mode.
Jan 17, 2010 | Philips DVDR3450H DVD Recorder/HDD...
Emerson EWR 20V5
Jan 17, 2009
I posted this Jan 3, 2009 and seem to have a solution.
Similar problem. E4 54037380 Can not record on this disc. Even though it is from the same package of DVD-Rs that I have successfully recorded to previously. Contacted them about 9 months ago without a successful resolution so I am trying again. Unit will play any DVDs, will record and play back DVD-RWs but will not record on my imation DVD-Rs 8X discs that worked fine in the past. Starts to record for a few seconds and then the error message appears (sometimes with slightly different final 4 digits of error number). Other postings have suggested: maybe a firmware update is available (I requested and we will see Emerson's response), trying slower speed discs (I am skeptical since these 8x imation discs in this same package previously worked, and the instructions say 1-16x for DVD-Rs), unplugging the unit for 1/2 hour to reset the unit (did not work), playing the last disc recorded to the end and then trying a new disc (now it recorded for about 30 seconds rather than 10 seconds but then got E4 54043E02 error message, different but still did not work). So I am hoping for something more productive out of Emerson this time.
Update Jan 17,2009. Bought a CD and DVD cleaner disc with the little brushes on it. Cleaned the EWR20V5 per the cleaner instructions and tried to recod on the imation DVD-R 8X that I had used successfully in the past, no luck, same error message. So I bought another brand, maxell DVD-R 4.7GB up to 16X and IT WORKED. The instructions on pg 25 say for DVD-R "up to 16X" may be used but "4X-8X disc is recommended". Go figure, no idea why the 16X worked but they did in this case. So just a suggestion to try other brands. Someone else had suggested that also so I gave it a shot. $8 of new discs and $13 for the cleaner and I've back in business.
Jan 16, 2009 | Emerson EWR20V4 DVD Recorder/VCR
My recorder has stopped accepting NEW DVD-RW discs and ejects them. There is no problem loading DVD-R (new or recorded)or loading previous recorded DVD-RW, initializing and re-recording I have tried...
I had the same problem. After trying several brands, the only one which is working perfectly is Maxell (yellow discs). I found them is the US (Seattle), have not seen them in France where I am leaving. Hope it can help !
Nov 08, 2008 | Pioneer DVR-5100H DVD Recorder
Sony dvd rdr gx300 failure to delete discs
You can delete titles on a DVD+/-R, but it will not free up disc space. These are not "rewritable (RW)" disks.
To reuse discs, start with a DVD +/-RW. Be sure to format it "VR," not "Video."
Oct 12, 2008 | Sony RDR-GX300 DVD Recorder
Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
May 05, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Recording problem
I have the same problem. What I found was the recorder will not recognize a disc that was inserted into the machine and then the machine is turned off. If I load a disc, either a -R or -RW, program the timer recording and DO NOT turn the recorder off, then the unit does make the recording. I called the Toshiba techs and the only thing they recomended was to return the machine to them for repair at a flat rate of $140. The unit only cast $180. A friend of mine has the same recorder and he is going to check if it will recognise a previously loaded disc after the unit is turned off and back on. Perhaps everyone with this problem should call Toshiba so they can make a firmware update for the DR4s. I hope this helps. MW
Jan 26, 2007 | Toshiba DR4 DVD Recorder
Loading DVD-RW discs
I have tried several different DVD-RW makes. Puzzling??
Nov 03, 2006 | Pioneer DVR-5100H DVD Recorder
Philips DVDR3380/05 DVD Recorder Logo
69 people viewed this question
Top Philips DVD & Blu-Ray Players Experts
Level 1 Expert
rugby prop
Are you a Philips DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
