Question about Epson Stylus DX4200 All-In-One InkJet Printer
Epson dx4200 all in one printer.
I changed a yellow cartridge & charged it up but the full ink carriage is stuck & will not move, any ideas? thanks in advance. jackie
Just use the disk that came with the printer go through install again, it will print a page out then make u put it in your scanner this will sort allignment. PLEASE SEND ME A COPY OF DISK IVE LOST MINE AND AM TRYING TO INSTALL ON VISTA. HELP!!
Posted on Apr 18, 2008
HOW CAN I CHANGE A INK CARTRIDGE IN MY EPSON DX7400 THAT IS NOT EMPTY
Connect the power cord, rise the cover that accesses to the print-carriage, turn On the printer; when the print-carriage move to left, unplug the power cord then, manually, move the carriage until the right area where you can open the cartridges-cover and change the cartridge you need.
May 21, 2010 | Epson Office Equipment & Supplies
Changing Cartridges does not move into view so I change it
try the on/off button with the lid open. it should move the cartridges.
Jun 21, 2009 | Epson Stylus C86 InkJet Printer
Red warning lights remain on.....
Ink and paper light on : head carriage error/general error. Head can't move extremely to right : head carriage blocked or CR motor error. Turn of printer, unlock head carriage lock. Move head left and back to right (to parking position). Is it move freely?
Jun 16, 2009 | Epson Stylus Photo R200 InkJet Printer
Hi, please tell me how to install a new black ink cartridge into my epsonstylus D78 printer
Open the cover. Press the Ink/maint button (triangle shape on button) this moves the carriage to indicate empty cartridge. keep pressing until carriage moves to the ink replacement position. Open ink cartridge cover and remove the cart. Ensure you remove the yellow tape on new cart' before installing and be careful not to touch the chip on the cart'. Push new cart' in until it clicks. Close lid (ensure clicks down), close printer cover and press ink button again.
Please take a moment to rate this solution, thanks.
Mar 26, 2009 | Epson Stylus C86 InkJet Printer
Changing ink in Epson DX6000 printer
Normally, you lift the scanner/copy bed up while the unit is on and then the cartridge moves to the center.
Have you tried this and if so without success? let me know so I can find the secret if there is one for you.
Regards,
Worldvet
Jan 28, 2009 | Epson Stylus DX4200 All-In-One InkJet...
Remove ink cartridge
I found that the proper way to do it only worked when the ink light was flashing red. Then when I pressed the stop button it moved across and stopped beneath the marker to show which cartridge needed changing. The I pressed the stop button again and it moved to a place where I could change it.
This happened despite the fact that the pictures I was printing blatently showed that I needed to replace my ink, it wasn't until I had printed the liney pictures a few times that the printer decided the ink level was low enough to turn the flashing light on and let me change it.
Jan 23, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson R320 carriage jammed
The ink cartridge is probably not inserted correctly.  Unplug the printer and manually move the carriage to a location where you can take the ink cartridge out.
Remove it and reinsert it, making sure that it is fully located, before applying the power.
Make sure that there is nothing blocking the carriage movement, such as some remnant of paper.
Oct 21, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Photo R320 InkJet Printer
Here is how to get the ink cartridges to move to the changing position on the R320.
1. Press the paper jam/ink button on the printer control panel.
2. A menu comes up. 1st item is ink cartridge replacement. Press
OK button.
3. Another menu with ink cartridge replacement. Press OK button.
4. Thats it, ink cartridges move to the changing position. Change your cartridge as you normally would and follow prompts on screen to finish process.
Hope this helps.
Aug 21, 2008 | Epson Stylus Photo R320 InkJet Printer
Ink carriage jammed
Well, I'm not too happy that the only response I got was solicitation for the Premium Assistance Plan.
Figuring that the printer had pretty much died, I allowed my husband, Mr. Fix-It, to give it a try. He simply pushed up on the front end of the ink carrier and slid it into the opening. This allowed him to get at the cartridges and push gently down on the new cartridge I'd installed. It had not been seated completely. Works fine now.
I'd be curious to know why I found a huge ink spot under the printer. It has probably been there for quite some time, as I usually just dust around things rather than move them.
Mar 14, 2008 | Epson Stylus C84 InkJet Printer
Epson Stylus DX4200 All-In-One InkJet Printer Logo
55 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
