Question about Car Audio & Video
My radio In my 1996 chevy lumina my speakers dont work but the radio is on as if the speakers are working. can you tell me what may be the problem
    New Friend:
  • 101 Answers
Could be a short across your speaker terinals.are u using a seperate to be more specific on set up
some times in trunk metal from something might bre touching the terminal on speakers ,this will cause a muted affect also check to make sure you didnt mute the radio.
Posted on Jan 22, 2008
Why does my aftermarket Pioneer radio blow fuses after a few minutes of operation?
what is the model of your pioneer and these luminas have the amp built right into the stereos same as the 98 same deal
Apr 15, 2015 | 1997 Chevrolet Lumina
1996 chevy lumina van,3.1l,what are the three relays behind the right heAdlight for
The battery and the main power distribution box is all right in that area. So, that makes it hard to tell you without more information.
Nov 22, 2014 | 1996 Chevrolet Lumina Mini
Need the speaker diagram wiring for a 97 chevy tahoe
1997 Chevrolet Tahoe Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size:
6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Doors
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Mar 01, 2018 | Car Audio & Video
1996 Chevy Lumina temperature gauge rising
the drop- electric fan is coming on to cool the overheat- the heat- sounds like thermostat is bad-replace
May 21, 2010 | 1996 Chevrolet Lumina Mini
I need a wire diagram for 96 a chevy lumina and a 95 cutless supreme oldsmobile for stock steroes
96 Chevy
Battery ORANGE (+) RADIO HARNESS Accesory YELLOW (+) RADIO HARNESS Ground BLACK/WHITE (-) RADIO HARNESS Illumination GRAY/BLACK (+) RADIO HARNESS Dimmer BROWN/WHITE (+) RADIO HARNESS Power Antenna PINK (+) RADIO HARNESS LF Speaker (+) TAN LF Speaker (-) GRAY RF Speaker (+) LIGHT GREEN RF Speaker (-) DARK GREEN LR Speaker (+) BROWN LR Speaker (-) YELLOW RR Speaker (+) DARK BLUE RR Speaker (-) LIGHT BLUE
Apr 04, 2010 | Car Audio & Video
1996 Chevy Lumina Car. No dash gage lights. Radio works and has lights.Which fuse should I replace? There isn't one that indicates dash. Service Engine light sometimes comes on for a day or so and then...
It's probably the dimmer switch, chevy is bad for them going out or shorting. It should be on the fuse with the dome light. Try working the dimmer back and forth, see if it works then.
Feb 17, 2010 | Chevrolet Chevy Cars & Trucks
I have a 1996 chevy lumina. the motor wont turn
You need to check for power at the purple wire going to the solonoid while key is in the start position, if no juice then check starter relay-under hood- fuse ,and ignition switch
Feb 01, 2010 | 1996 Chevrolet Lumina Mini
I have a 1997 chevy lumina and i'm putting in a new radio but the wires are not hooked up to the old one and i need to find out how to hook up the new one correctly. where can i get the wiring diagram for...
1997 Chevrolet Lumina Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Orange
Radio Ignition Switched 12V+ Wire: Yellow
Radio Ground Wire: Black/White
Radio Illumination Wire: Gray/Black
Radio Dimmer Wire: Brown/White
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5 1/4′
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6′ x 9′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Jan 09, 2010 | Car Audio & Video
Car radio
ignition on, LOC appears
press MN and OOO will appear in display
press MN again to make the the last two digits agree with your code.
press HR to make the first one or two digits agree
with your code.
Press AM/FM after you have confirmed that the code matches the code you have written down.
The display should show SEC which indicates
the radio is now operable and secure.
'rock on'
Mar 13, 2009 | 1996 Chevrolet Lumina Mini
1996 chevy blazer radio turns on but there is no sound
I have a strong feeling that the head unit "radio" has finally gone bad. You describe a situation, in which you have to turn it on and off, to get it to work. Typically if the sound comes out of all speakers, after doing that, then the speakers were never broken. The head unit itself should be replaced. I hope this helps.
Nov 16, 2008 | 1996 Chevrolet Blazer
Car Audio & Video Logo
100 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
