Question about Panasonic PT-LB20NTU Multimedia Projector
PT-LB20VU unit won't power on
Hi, I have a projector model PT-LB20VU unit that won't power on. It was working perfectly fine, and then just shut off, went to orange cool-down mode for about 1/10 the time it normally does, then into Standby mode, and immediately all lights shut off. I've cleaned the air filter, cooled the unit, and vacuumed all the vents...
Is there anything else I can try at home before having to take this in to get service? There aren't any projector servicing places anywhere near me, and I doubt replacing the lamp will do any good, as I'm getting no notification that that's the problem. Any ideas?
  • 682 Answers
Check for the following:-.
1--the power cord may be disconnected.
2--main power switch is turned off.
3---no voltage(electricity)in wall outlet.
4-the lamp cover has not securely closed.
5--check for blown power fuse and change it with the same rate.
6--defective power supply unit.---.
Posted on Mar 16, 2008
I have a pansonic pt-ax220u, When I start it up it turns on perfectly fine and runs for about 2 minutes. After that the screen shuts off but the projector is still on.... Instead of the light being green...
The main board of the projector needs replacement! not worth getting it replaced as it would cost very high! look out for a old working board that would cost lower!
Jan 11, 2013 | Panasonic PT-AX200U Projector
After putting a new lamp in the projector in my PT-AE1000U, it turns off on it's own after 5 to 8 minutes of use. I was told it could be a BIOS setting that counts the hours of use that needs to be zero's...
Generally speaking a lamp timer is just a warning indication and won't shut the unit down. There should be indications of why the unit is shutting down. For example, is the power LED blinking or any other light blinking? My primary suspicion would be either an air flow problem or heat. Check to be sure that the fans are running properly.
Please update this with any additional detals.
Apr 25, 2011 | Panasonic PT-AE1000U LCD Projector
Projector posted error, "replace bulb" Projector
Your projector need replacement of lamp unit if you don't want yet you just reset the lamp counter
Power on projector
press MENU key
Press right arrow key to select Option
Press down arrow key to select lamp Hours
Press and hold down the ENTER key 5 second (lamp hour counter show red)
press POWER button to turns off the projector
now you power on your projector and no error displaed and no itself turn off after 15 minutes
Apr 13, 2011 | Panasonic PT-L785U Multimedia Projector
Works good for 2 minutes, Then shuts down & light goes red. Remote wont restart , so turn power off then on, Works again for 1 minute then shuts down. Panasonic PT-AE900U... projector
change the Bulb if that does not work it could be a power supply or power supply regulator this should be done by a professional except the Bulb
how many hours of operation does the unit have ??
Sep 21, 2009 | Office Equipment & Supplies
Panasonic PT-AE900U Projector Lamp stops working (intermittent)
Could be a heat sensor, fan bearing issue..have you listened to the fan speed etc, But I think more along the lines of the lamp needs replacing..each time you resit it is thinking ah a new lamp and then realises hey someone is fooling me and shuts down...this scenario is doing you a favour as typically if it blew and shattered the glass it will inevitablly scratch the mirror and lcd block... and if it does that you might as well toss it in the rubbish or sell on ebay for $50 ..
Regards Kevin Andreassend, ICE AV Technology Ltd
Apr 03, 2009 | Panasonic PT-LB10VU Multimedia Projector
Panasonic PT-AE700U
may be a heat problem: check the psu unit for components getting too hot...use a laser thermometer and keep you fingers away from the psu ! other possible problem may be a bad capacitor or the thermal protection before the psu..but this would be a very uncommon problem.
Dec 13, 2008 | Panasonic PT-AE700U Multimedia Projector
PT-LC50E LCD Projector
With power available at the projector and the lamp off (projector off) - hold the input button on and press the power button on and hold for 5 secs. This will reset the lamp timer to zero.
I wish they could have stuck this in the operators manual.
May 25, 2008 | Panasonic PT-F100NTU LCD Projector
My Panny AE700U shut down & won't restart
HI there
This is a faulty Mainboard that will need either repair or replacement.
If a Projector starts playing on and off tricks I have found it to be 99% of the time a faulty Mainboard.
Apr 13, 2008 | Panasonic PT-AE700U Multimedia Projector
Panasonic PT-LB20NTU Multimedia Projector Logo
190 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
