Question about Maytag 24 in. MDBH950AWS Built-in Dishwasher
MAYTAG DISHWASHER MODEL MDB7100AWQ
I WANT TO TAKE MY DISHWASHER APART SO I CAN CLEAN THE FILTER MY DISHWASHER IS NOT CLEANING PROPERLY.I DON'T KNOW HOW TO GET IT APART PLEASE DO YOU HAVE INF.LINDA FOX PLEASE REPLY TO nannyfox@suddenlink.net thank you.
  • Karen Canning Sep 21, 2008
    My maytag mdbh95oawb also doesn't clean properly. If you were to look down on the machine, the northeast quadrant both top and bottom do not get cleaned, sometimes they do not even get enough water. Is there anything I can do before I have to call in a megabucks repair person?
My MDB7100AWQ has suddenly stopped working. It will fill but then stops and will not move into wash. When I press the drain/off button the lights work but it does not drain. I do hear a switch in the door operate when I press the drain/off.
Posted on Aug 11, 2009
Dishes not coming out clean
Hello
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
Sep 13, 2011 | Maytag Dishwashers
Maytag Diswasher DOP Model MDB6600AWW Serial 15365054LE Water sits in bottom of dishwasher Dishes not clean Don't know how to get filter off to clean
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Aug 25, 2011 | Maytag Dishwashers
Have a real problem with etching,filming spotting not cleaning properly.Dishwasher 18 months old.Have tried all solutions as per manual,no joy.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes.
Nov 11, 2010 | Maytag MDBH945AWW / MDBH945AWQ /...
Self Cleaning filters are not cleaning themselves.
Pl check the over-head tank of your premises. Clean the tank.
Alternatively you can install a master filter in a accessable level( height ) for the easy cleaning. There are no self cleaning systems. If the filter is removed it will go and clog the out-let valve and you will end up in more maintenance cost.
Apr 29, 2010 | Maytag 24 in. MDB9150A Built-in Dishwasher
Clogged filter
Hi, The mesh does not open. You will need to GENTLY clean each section with running water. Are you using powder or liquid soap?
The most common thing that plugs them is food particles. This unit is best served by pre-rinsing the dishes. The mess gets plugged to easily.
I hope this helps.
Vic
May 30, 2009 | Maytag 24 in. MDB9150A Built-in Dishwasher
Water leaking after cleaning filter
Sounds like a washer problem. Either the wrong ones or did you forge to clean the washers before reinstalling them?
Mar 13, 2009 | Maytag MDB6000 Dishwasher
Maytag dishwasher filter (?)always clogging
How do I take apart and clean the filter, I've gotten the screws out but to do now?
Dec 22, 2008 | Maytag Dishwashers
Soap is in the dispenser after dishwasher has been run
You need to clean your particle screen under the heating element. It is found at the bottom center of the washer under the heating coil. It is usually a plastic mesh screen and sometimes are removable. This needs to be cleaned really good about every 2 months. This will stop the problem with the suds. Good Luck This Should Help!
By the way I see that you soap won't dissolve this is not because of water temperature it is that the jets in the washer arm are clogged. You need to clean these one by one with a small cleaning device and brush. When these clog the jets of water don't come out with any force they just trickle. Clean the jets(on the arm that spins at the top and bottom of the washer and your screen and it will be like having a brand new washer.
Nov 23, 2008 | Maytag 24 in. DWU9202 Built-in Dishwasher
Cleaning out dishwasher
Hi I checked the manual on line. Here's what it said.
Dishwasher has an odor
Run dishes being held in the dishwasher through a Rinse Only cycle.
• Many dishwashers have a “new” smell when first installed. This will dissipate with use.
• Dishwasher may not be draining properly. (See “Dishwasher Will Not Drain” section.)
• For a strong odor, place baking soda in both sides of the detergent cup. Select Light
Wash cycle and allow the water to circulate for about 10 minutes. Interrupt the cycle
by unlatching the door and let it stand overnight. Restart the dishwasher by latching
the door and allow it to complete the cycle. Another alternative is to use a dishwasher
cleaning product such as Jet-Dry Dishwasher Cleaner*.
Good Luck
Sep 17, 2007 | Maytag 24 in. MDB5651A Built-in Dishwasher
Maytag 24 in. MDBH950AWS Built-in Dishwasher Logo
1,060 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
