I NEED TO FIND MY DRIVER BECAUSE I LOSED THEM//
CANT YOU HELP ME TO FIND MY DRIVERS/ I´M TIRED TRYING TO FIND IT BUT I CAN´T FIND// PLEASE HELP ME
Placa base: Tipo de procesador AMD Athlon XP, 1533 MHz (11.5 x 133) 1800+ Nombre de la Placa Base PCChips M825G (2 PCI, 1 AGP, 1 CNR, 2 DDR DIMM, Audio, Video, LAN) Chipset de la Placa Base VIA UniChrome KM266 Pro Memoria del Sistema 503 MB (PC2100 DDR SDRAM) Tipo de BIOS AMI (02/14/05) Puerto de comunicación Puerto de comunicaciones (COM1) Puerto de comunicación Puerto de impresora ECP (LPT1)
Monitor: Tarjeta gráfica VIA/S3G UniChrome IGP (8 MB) Acelerador 3D VIA/S3G UniChrome Monitor AOC TFT1780 [17" LCD] (B9872HA007075)
Multimedia: Tarjeta de sonido C-Media CMI9739A/9761 @ VIA AC'97 Enhanced Audio Controller
Have a Brother MFC 7420 multi function printer/copier. Keep receiving screen message "Back...
(More)
Have a Brother MFC 7420 multi function printer/copier. Keep receiving screen message "Back Door Open" can you help ?
Suddenly both printer and 9 pin serial ports not working. I have been using a Dynalink V1456VQE...
(More)
Suddenly both printer and 9 pin serial ports not working. I have been using a Dynalink V1456VQE dial-up modem and an old laser printer on these ports, but no more. Windows XP is not recognising any hardware connected to the ports. PCI modem and USB printer are working OK. The same plug and play hardware works on another PC.
i can't install a cpu heat sync because my mobo does'nt have the white square where you put the cpu...
(More)
i can't install a cpu heat sync because my mobo does'nt have the white square where you put the cpu and clip the heat symc. My Mobo has onboard amd Athlon, the only way to instal a cpu heatsync is with screws on the side, but i don't find any heatsyncs with screws .
