Volume control needed
Hi
Am I likely to find a 30K ohm twin volume pot (two knobs on a co-axial shaft) for what must be a vintage amp? It's a Denon PMA-450.
Many thanks
Pete
  • m4m5driver Jan 24, 2008
    Thanks but none found on Ebay - I had already looked.
    I have found a source though from Charles Hyde & Son Ltd
    According to their stock list they can supply in 7 to 14 days although for a analogue manual volume control it's not cheap at over £28 all in!
    I'm now waiting for the part to arrive.
    Pete
  • 107 Answers
Have yoou tried to find in ebay.? they should have one there.
Posted on Jan 24, 2008
Distortion appears while trurnning up the volume on right channell
You just need to replace your volume knob for a better one , a couple of bucks 10 dollar
Jun 18, 2014 | Denon PMA-100M Amplifier
How can I connect a subwoofer to this device (denon pma-520) http://www.hifiengine.com/manual_library/denon/pma-520.shtml?destination=node%2F14208
Look around for a subwoofer which has speaker level inputs.
Something like this;
https://www.parts-express.com/dayton-audio-sub-1000-10-100-watt-powered-subwoofer--300-628
Jun 08, 2014 | Denon Pma-520 Integrated Stereo Amp...
The only safe way to do this us to connect the sub to one of the other speaker outputs using a "speaker selector" switch. For example, you would go out of the receivers left speaker output, into the selector switch then out of the selector switch into the sub and the left speaker. There really is no other way.
Cant get sound from my receiver and amp together
if you are hooking up 2 units to run together, take a pic of the back of both units, and post them here
Mar 06, 2013 | Denon Pma-520 Integrated Stereo Amp...
We have a DENON L.C twin transformer amplifier PMA-735R that has an input selector that freaks out now and again. Recently it has gotten worse, it just goes back and forth between tuner and cd etc. for...
Hi Readers to of Fixya,
This entry is January 22, 2016.
I own a Denon PMA 735R which I bought new in 1999, it is very good Amp; starting about a few years ago the input selector would occasionally randomly jump from CD to Phono to Tape etc., but would always end up back at CD so it was not terribly annoying until a few days ago when it started happening all the time. I am a very knowledgeable electronics person (I built musical keyboards at one time) so my thought was just that it was a dust problem and I started with that premise. I fixed it using an Electrical Parts Cleaner spray and here is how I did it:
I unplugged it, removed the CD input RCA cables and removed the L & R speaker cables and took it off its shelf and set it on a towel on my soft sofa; I removed the casing by unscrewing four big silver screws on the sides (my model is silver) and the three small black screws on the back top; I removed the Input Selector indicator knob on the front and the Record Out Selector indicator knob and the Volume knob, I then removed the small nut that holds the three of them tightly in place to the front panel; I then stood it on its back so that the front was facing up; I then sprayed my Electrical Parts Cleaner spray into the Input Selector indicator post liberally and then put the knob back in place and kept turning the indicator back and forth for a few minutes to work the cleaner inside the post down into the circuit board connection; I did the same with the Record Out Selector indicator post and I did the same with the Volume post; I then put the small nuts back on the three posts and tightened them; I then put the knobs back on the three posts; I then stood it back on its normal upright position and put the casing back on and then the screws; I placed back on its shelf and hooked up the cables and switched it back on and played my CD's, it has been working perfectly fine. The whole process took less than 30 minutes.I hope this helps.
Feb 20, 2012 | Denon Audio Players & Recorders
I have a Denon PMA 500V amplifier. all of the output fuses were blown so I replaced them but the unit still doesn't work. Any suggestions?
hi.
Did you checked balanced impedance?load speaker impedance vs PA output?or PA might over driven,causing a trouble on the pre-amp to power amp circuits and components damage,
need to recheck related components on the pre-driver up to main output section,
Note: That,blowing of fuses with the same rating is an indication of trouble/shorted in a circuits that driven on it,
Thanks and good luck
microhit
Jun 01, 2011 | Denon PMA-2000R 2-Channel Amplifier
Deneon PMA-250 amplifier -Volume knob not working correctly
Well, it seems you have your finger on the source of the problem. If accessible, try some tuner cleaner inside the potentiometer.
Mar 05, 2010 | Audio Players & Recorders
DENON Input selector jumps randomly
I have a PMA-535R. Same problem but slightly different dialknob. I fixed it by spraying a contactspray and WD-40 into the knob itself. This does mean you have to disassemble the front of the amp and take out print of the dialknob. The knob has a plastic dustcovere that you will have to lift. Good luck
Sep 18, 2008 | Audio Players & Recorders
102 people viewed this question
 Grubhead
Grubhead
