Question about Sony Walkman MZ-R909 Personal MiniDisc Player
Mini cd upload to computer
I have recorded my mothers voice with a mini cd before she died and wanted to save the content on to a regular cd.
Hi officer,
my question is how I download the music from my mini cd to computer?
Thanks~
Posted on Nov 25, 2008
How to download my voice record to youtube from my computer. I record it thru nokia 6300 and save it to my computer. I want to download it in youtube
create your account there or sign in with gmail account after sign in on youtube you can see a yellow upload switch under your sign out link click on upload and browse your video for upload write your comments there for your video then save after you save your video,, youtube guys take few time to check your video it is copyrighted or not when they approve your video you can see your video on under your account,,, video
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Mar 22, 2010 | AOC A15X221 15 in. LCD Television
Digir8 dv182 help uploading content from sd card
you should purchase a sd card reader, they are very cheap. ( ebay, amazon etc )
May 18, 2017 | DSC DV182 Camcorder
Dowload in my computer
If your computer has an input on the sound card (Three holes coloured Yellow Blue & Green on lots of machines) then by purchasing a lead from Tandy or Radio Shack you can plug your cassette recorder in and record the contents to the hard drive as .wav files You will need a mini jack lug suitable for the output on your recorder and the same for the PC Windows has its own built in Sound Recorder software but there are better products on the market.
Jun 07, 2009 | Oregon Scientific VR636 Handheld Voice...
Mini disc playback
Your computer probably wont read the disc, you may need to upload it. If you don't know how to do that I'd be happy to explain. Hope that helps.
Apr 12, 2009 | Panasonic VDR-D100 DVD Camcorder
Voice Recorder-Files to CD?
Please follow the below solutions to create either an audio CD-ROM of .wav files or back-up
.wav files to a CD-ROM.
Problem: .Wav files downloaded to PC computer from the DW-90, VN Series, and DSS Files
created with DS Series recorders cannot be copied to a rewritable CD-ROM using Windows
Media Player to create an audio CD-ROM.
Explanation: These digital voice recorders create .wav files at 8kHZ, 12kHZ, or 22kHz
depending on the Quality setting. Digital Wave player software is used to download Wav files to
a PC computer from the DW or VN Series of recorders. DSS Player is used to download DSS
files from the DS Series recorders and convert them to Wav files. If Windows Media Player is
then used to copy the files to a rewritable CD-ROM to create an audio CD-ROM, the files will
not copy properly or an error message may appear. Windows Media Player can only create an
audio CD-ROM if the .wav file is 44.1kHZ, 16 bit stereo.
Solution: Follow the procedure below to convert the .wav files to 44.1 kHZ, 16 bit stereo. Then
use Windows Media Player to copy the files to a rewritable CD-ROM.
1. Click Start, click All Programs, click Accessories, click Entertainment, and then click Sound Recorder.
2. On the File menu, click Open.
3. In the Open dialog box, specify the name of the audio file that you want to convert, and
then click OK. Files are usually located at C:\Program Files\Olympus\Digital Wave
Player\Message\Folder A.
4. On the File menu, click Save As.
In the Save As dialog box, click Change.
In the Attributes box, click 44.100 kHz, 16 Bit, Stereo, and then click OK.
Click Save. After you convert your files, try to copy them to a CD-ROM again.
Mar 21, 2009 | Olympus VN-4100PC Digital Voice Recorder
I need to copy digital voice recordings to cd
you will need to change the format of the files by using sound recorder in windows xp. just open the file and save as cd quality format. this will change the bit rate to 16 bit needed to make a cd
Jan 17, 2009 | Olympus VN-3100PC Digital Voice Recorder
Recorded Voice to CD Burner (Want to make CD of voice)
You should be able to burn them directly. Put a blank CD into your CD burner and then pull up My Computer. You should see the CD there in whatever drive you have your CD player/burner set up in (usually D: ). Double click on it to open it. There should not be anything in that folder.
Then while leaving that folder open, go back to My Computer in a new window and open up the folder where you created your sound files (My Documents/My Music). Select the files you want burned to the CD (you can select more than one at a time with by holding down CTRL while you click), right click on them and select 'Copy'.
Then head back over to your blank folder of the CD contents. Right-click and Paste them into that folder. Depending on your version of Windows, either a bubble will pop up on your task bar saying you have files waiting to be burned on the CD or you might have to go into File to find an option to burn to the CD.
Then your files should be all set!
Dec 23, 2008 | Audio Players & Recorders
Olympus VN-3100pc
on Windows XP, you will need to convert those files into 16bit cd audio quality. You can do this thru Sound Recorder on the computer. Just make that you change the file name before converting. Open up sound recorder, open up file, save as, convert, then change quality to cd quality then ok. After it is saved in 16 bit format, open Windows Media Player and then burn.
Aug 24, 2008 | Olympus VN-3100PC Digital Voice Recorder
Samsung digital voice recorder SVR-S1330
http://downloadcenter.samsung.com/content/DR/200303/20030328170645359_VoiceManager.zip
Oct 20, 2007 | Samsung SVR-S820 Digital Voice Recorder
Sony Walkman MZ-R909 Personal MiniDisc Player Logo
132 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
