Question about Intel Motherboard
Motherboard Change Mine went up, (C2480 emachine) they replaced it with P/N K800AM64 motherboard. I have hooked everything back in the correct way. The Power LED, Power SW, and H.D.D. LED hook up are different. They are not spelled out on the new motherboard. One says PW_LED, PL_LED1, and nothing says for Power SW. With the two wires on the board and attempt to turn it on, it appears that it is no power due to the power switch wire is not in the correct place? Can you help me?
  • Anonymous May 02, 2008
    need outline for hook up
  • whitetruck Aug 28, 2008
    i have a ASUS k8v-mx & i need to know the layout of where all the wires go on the motherboard. thanks if some can help that would be good.
  • 95 Answers
Need to look in the manual to find where they go. Don't just try at random or something will fry.
Posted on Jan 21, 2008
Need instructions for replacing and wiring Motherboard
Luckily that is pretty easy with modern motherboards.
1. Remove power and unplug all devices hooked to computer.
2. Open case.
3. Write down the location and orientation of all wires connecting to old motherboard.
4. Disconnect all wires from the case that are plugged into old motherboard.
5. Uncrew the screws holding the motherboard in the case.
6. Carefully remove old motherboard.
7. Install new motherboard and secure it to the case (probably using the same screws as the old MB)
8. Refer to diagram you made earlier to plug in all the wires to the proper places in the new motherboard.
9. Check and make sure the new motherboard works before closing the case.
10. If everything is working correctly, close up the case and you are done.
Nov 10, 2013 | Computers & Internet
Emachine el 1852g-52w motherboard
the problem,maybe the PSU the computer might not get enogh power.or you can allways clear CMOS and se if that helps.
Jun 22, 2013 | Computers & Internet
I have a emachine c2480 and the does not play dvd
Please first of all check which writer you are using.If your system is not playing dvd then might be you are using a cd drive.So to play dvd change the drive
Thanks.....
May 18, 2010 | E-Machines C2480 PC Desktop
I have desktop C2480 emachines with AMD athlon XP. The problem is when i turn on the CPU the leds never on. I opened the CPU and i saw the 3 connectors from the mother board disconnected thats 3 pair of...
Ok these go on a small dual row of Header Pins on the Motherboard, Generally near the front or side of the MB. They may be marked the same as on the leads. Otherwise you will have to look in the manual to see what one is what. I wonder how they came off?
Feb 06, 2010 | E-Machines C2480 PC Desktop
My Emachine T-6216 doesn't boot up, I try a new power supply, a new hard drive and nothing happens. So I assume the motherboard is no good.
Did you try to change the CPU? It is _NOT_ likely to be the problem.
But, if you did, and you still have the problem, then it _IS_ the motherboard.
If you didn't try to change the CPU, it probably _STILL_ is the motherboard.
Contact 'www.eMachines.com' and see if you can purchase a replacement motherboard.
Oct 27, 2009 | E-Machines eMachines Desktop PC
EMachines T2824. Does nothing but light on mainboard coming on...
This is a motherboard problem. You'll need to replace it. Although, it may be cheaper just to buy a new PC (eMachines are never very expensive, or well-made for that matter)
Sep 22, 2009 | Computers & Internet
I have an emachines T2542 computer with a bad motherboard (Imperial G motherboard). I am wondering if I have to get an identical motheboard to replace mine if I want to boot up using my hard disc with WIN...
Your better off replacing the motherboard with an Emachine spare, this is because your hard drive will not notice the change when replaced so you can still use all your programs.
If you was to get another motherboard with a different chipset or GPU (graphics processing unit) then chances are the operating system will not boot resulting in loss of data and programs due to a clean install.
Go here, fill in the form and get a quote for a replacement motherboard>>
http://l7inc.us/quote.php?buy.x=29&buy.y=15&buy=Buy&ID=2834574460
Regards.
Aug 26, 2009 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Need correct MOB location for power switch on emachine W3410.
what kind of motherboard did you change..?
try to search in the internet.. just type the name of the board and including the diagram.. sample.."ASUS MOTHERBOARD POWER DIAGRAM"...
Apr 27, 2009 | Computers & Internet
Hooking up the wires correctly??
may be the RAM of the computer is decreased during transfer withput ur knowledge . u know what was the previous amount of RAM ur computer had and check in system properties if the same squantity of ram is available . this may have slow don the sytem , try to remove unwanted starup options also
Dec 14, 2007 | Intel Motherboard
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
