Question about Mitsubishi CS-35503 TV
Mitsubishi CS-3515R tv problem
Have sound, but all black screen except for one very narrow bright line through the middle horizontally. HELP!
  • lilibelle Mar 15, 2009
    i have same problem on mitsubishi 35303
Is locked and forgot my 4 digital code number
Posted on Sep 29, 2008
6ya staff
SOURCE:
I have a Mitsubishi CS 3515R 35" Tube TV. The screen has narrowed at the top and the bottom so only about 2/3 of the horizontal screen has picture. There are black areas at the top and bottom....
There are two issues, the first is a vertical deflection problem, "needs a few parts+an ic" the second problem is intermittent color, "crystal and color processor ic" If the set is close to 10 years old then your money is better spent on a new tv.
Mar 20, 2011 | Mitsubishi CS-35503 TV
Model CS-3515R, has buzzing noise, screen darkens, then noise stops\r\nand screen lightens up, then repeats about every 15 minutes.
There is some short in the inside circuit of your TV. Horizontal output transistor may be leakey. Replace it with a new one of same type and number. If it doesn't rectify the problem, LOT should be replaced.
Oct 16, 2010 | Mitsubishi Televison & Video
Screen is black except for thin line in middle of screen
The problem is in the vertical section of the main board. Bad capacitors and maybe the vertical IC. If you are not inclined to be a tech you will have to take it to a shop.. I don't know what they may charge but I normally get $69- $89
Apr 10, 2009 | Mitsubishi CS-27205 TV
Horizontal Line through middle of TV screen
This is usually a bad elect capasitor or a bad solder connection on the vertical IC, The capasitors will be close to the vert chip..Sometimes you can clear problem with a light tap on the TV, if so then suspect bad solder.
Charlie
Mar 31, 2009 | Televison & Video
That sounds like simple ring-cracks in the vertical circuit, most likely the vertical Ic itself... On the printed circuit side of the Tv look at the vertical Ic and examine it carefully under some magnification where each pin of the Ic solders to the board. See if you can find any cracks in those solder connections.
Bill
Feb 04, 2009 | iLO V27DMBX Television
Narrow blue horizontal line across screen on intial power up
You have trouble with the vertical deflection circuitry. Probably something in the driver circuit or power supply to the driver. Maybe even a cold solder joint since it comes up after a little warmup.
Jan 17, 2009 | Mitsubishi CS-40503 TV
Picture/image problem
Bad solder connection in the horizontal pincussion circuit.have someone resolder.God luck.4tune
Jan 09, 2008 | Televison & Video
White horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Sep 20, 2007 | Mitsubishi CS-35505 35" TV
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Sep 10, 2007 | Televison & Video
Won't stay on
The quick horizontal line through the center of the screen usually denotes a failure in the vertical output circuit, and that would keep the set from staying on. You would have to take it to a repair shop for repair.
Dec 09, 2006 | Mitsubishi CS-31305 TV
Televison & Video Logo
313 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
