Question about HP LaserJet P3005n Printer
Hp 3005n error on display
Not always i get this error every 2 0r 3 days. cycle power the problem goes away! Like magic it returns again and again. can anybody help me.......
  • 417 Answers
What is the error number that comes up there should be a code that is displayed. Once I have this number I will be able to tell you why you are getting the error and how to fix it.
Thanks J
Posted on Jan 28, 2008
6ya staff
SOURCE:
I have a Kenmore Elite 795 bottom refrigerator. I keep getting an error code r dh. I cycle the power & it goes away for approx. three days. looking for a proper fix
Defrost problem when the defrost process fails to reach the required temperature to properly de-ice the cooling coils.
http://www.searspartsdirect.com/refrigerator-repair/error-codes/kenmore-refrigerator-error-codes-for-795-bottom-freezer-models.html
When you cycle the power you reset the code and it takes a day or so for the unit to cycle the defrost. Suggest that you ensure that the vents are not blocked.
Hope this helps?
Nov 11, 2016 | Kenmore Refrigerators
My sony bravia ex 400 made in malaysia is giving problem. The LCD goes of intermittenly and the red LED blinks,, again when I switch on again it comes up, but goes off again..This is happening again again...
Your power supply board is not yet dead you can fix this by having basic knowledge on electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem........
Dec 09, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
HP laserjet 3330 keeps flashing scanner error power off. I unplug and start again. It will print and then goes back to this same thing.
Remove and replace the power cord from the unit.
Wait approximately for 35 seconds for the scanning assembly to "walk out"(move to ready position)and then quickly remove the plug again.
Repeat step 1 and 2,three or four times until the head (scanner lamps)moves approximately 1 inch away from its normal resting place.
Replace the plug and let the product fully finish the boot cycle.
If it does not resolve the issue or the issue returns,upgrade the product firmware may help.Visit this url http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=72628&lang=en&cc=us&prodTypeId=18972&prodSeriesId=66359&taskId=135
and then upgrade the firmware.
Feb 10, 2010 | HP LaserJet 3330 All-In-One Printer
Nokia E66 screen sometimes goes off when the slide is open...
sounds like the cable is loose and just not getting a good enough connection just because you said after taking it apart it works for a few day then sarts acting up again
Aug 08, 2009 | Nokia E66 Smartphone
The sedons sat for two weeks while I was away. On
Replace the intermediate shaft. See TSB (KT2008101402). It connects the steering to the rack and the u-joint binds.
http://www.kiatechinfo.com/TechInfo/KMATSB/board_view.asp?docu_no=393&page=
Jul 08, 2009 | 2003 Kia Sedona
Magic Jack- Other person hears beeping every few seconds
You can use Magic Jack customer care at http://www.magicjack.com/2/customercare.asp
I talked to 3 operators. The long and the short of it is that they had me:
1. remove a Majic Jack related folder from an applications folder
2. insert MJ1 and MJ2 in the Windows Firewall exceptions
3. format the Majic Jack software "drive"....and then install an upgrade.
Based on this, I think the problem crops up in the Majic Jack software. So far, it has fixed my problem, though I've not made a long call yet.
I found the Majic Jack operators very helpful. Be sure to have them step you through this.
Good Luck!
Amy
Jun 17, 2009 | Computers & Internet
Furnace shutting on and off every four to five minutes all day
Have you had furnace cleaned? Have you changed filter or took filter out and try heater? Have you checked return grill to make sure you don't have anything in front of it. Return grill or duct could be blocked or two small. Blower motor could be going off on thermal overload. Does the heater do the same thing when it is 20 degrees outside. The other thing it could be is furnace is not big enough.
Good luck let me know what you find out
Jan 17, 2009 | Honeywell Electronic Programmable...
MCO160UW goes dead after 3 minutes
I returned the item to Home Depot and they took it back no questions asked.
Nov 30, 2008 | Magic Chef CMV1000B Microwave Oven
Xbox360 error code
Here is how you interpret the LEDs to get the code number:
  • All four lights flashing - 0
  • One light flashing - 1
  • Two Lights flashing - 2
  • Three lights flashing - 3
0001 power supply problem
0002 Network Interface problem
0003 Power problem could be the PSU could be the GPU/CPU, somehow the console isn't getting clean power from the power supply.
0010 over heating
0011 over heating - If you are receiving this error after disassembling your console make sure to all 8 of the heatsync screws are tightened securely to the board/heatsink holes.
0012 over heating
0013 over heating
0020 (Not yet known, possibly overheating)
0021 DVD Drive Time out - Can be caused by problems with a firmware flash. This is also speculated to sometime be caused by a problem with the southbridge chipset on the motherboard.
0022 GPU Error / GPU Overheating
0023 (not yet known)
0101 (not yet known)
0102 unknown error
Oct 12, 2007 | Microsoft Xbox 360 Console
Wont turn off, goes to magic focus
enter your menu set up and turn off auto focus and see what happens then,also check your other settings while your there.
Sep 09, 2007 | Hitachi 51F500 51" Rear Projection...
HP LaserJet P3005n Printer Logo
631 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
