Question about Compaq Inkjet Ij300 Printer
Compaq I cant get my printer to do anything since i put in a new ink cartridge. Says "cummication fault current printer cable does not support bidirectional communication"
Something similar happened to me with a Lexmark P122 which uses the same cartridge. I believe Lexmark also makes your printer. Did you check the simple stuff first? Shut down your PC and printer, unplug your printer cable, check to be sure it's clean and in good shape on both ends. You can used canned air to blow out the connections. Remove the cartridge, don't touch the copper part with your hands but you can use a lint free cloth with isopropyl alcohol and lightly wipe clean all the copper contacts. Reinstall the cartridge and cable, start your PC and let it boot normally, then start your printer. If you have the same problem, it's probably the printer cartridge itself. On my P122, it turned out to be the printer cartridge. Probably some shorted lands. And that in turned caused my printer to fail permanently. Is there a light flashing on your printer in a short/long type of sequence? If you don't mind, can you check the power adapter (the black box connected to the electrical outlet and supplies power to your printer) and tell me what it says following the word OUTPUT?
Posted on Jul 16, 2008
6ya staff
SOURCE:
I cannot get my printer to print in only black and white. I have put new ink cartridges in, both color and black. I have selected "print in gray scale only" in the print options. But anything I...
Please take out the new cartridges and re-position them correctly i.e. color cartridge on the left and black cartridge on the right seating. Check that you hear a click sound when the cartridge is placed in the seating. Print a test page. Then switch off the printer for some time. Re start the printer and now carry out the gray scale printing.
Jul 19, 2011 | HP PSC 1210 All-In-One InkJet Printer
Tip
How to Reset Ink Level Canon MX300 Cartridges
1. Switch off the Canon MX300 and disconnect the power cable.<br /> 2. While press and hold the power button, Connect the power cable to electric socket.<br /> 3. While pressing the power button, press the "Cancel/Stop" button (red button).<br /> 4. Now release the power button and the printer turns into a kind of factory mode. Wait for 10 seconds until it says "idle".<br /> 5. Press "&gt;" (next button) once "Shipping Mode 3&prime; then Press the "OK" button. Press "OK" again for "without cleaning".<br /> 6. A test page will print.<br /> 7. Open the cover, like you are about to change the cartridges.<br /> 8. Disconnect the power cable again without switch off the printer.<br /> 9. Take out the both cartridges.<br /> 10. Close the cover.<br /> 11. Connect the power cable and turn on the printer.<br /> 12. Now just put the cartridges back and the ink level in the canon Pixma MX300 have full again.
on Feb 17, 2011 | Canon MX300 Office All-In-One Printer
I installed new ink in my Compaq A1500 printer, however the printer continues to state" Clear System Err Then Press Clear." The printer is making a strange noise and it does not clear. It appears...
Try reseating the ink cartridge. Maybe, the cartridge is not seated properly.
Here are the simple steps:
1. Lift the control panel by holding the panel along the top edge.
2. Pull the control panel forward.
3. Lift the ink cartridge access door. for better access, stow the document input tray away. the carriage will move to the center.
4. Then, try reseating the cartridge. Hold the ink cartridge by the black
areas or colored top only.
Good luck,
Ryan
May 24, 2011 | Compaq Office Equipment & Supplies
Kodak esp 9 printer is out of black ink, meanwhile all i want it to do is scan a paper and it wont do anything without new ink. The computer says the printer is busy, and the printer just says "error...
This is a common problem encountered by printer users and is in fact not a bug but considered a feature by manufacturers who build this function into printers to encourage consumers to buy their expensive ink cartridges. To fix this problem I would buy a 3rd party ink cartridge for use when your ink cartridge is empty. This way you can use your scanner when out of ink (be careful printing with 3rd party ink cartridges, many have mangled or destroyed their printers by using non OEM ink).
Feb 28, 2011 | Office Equipment & Supplies
After many cleanings, head refreshings, and "head allignments" the color printing is very light...especially the black. I've put in all new inks and the print is still very light. The new ink...
Try putting a bit of isopropyl alcohol in the bottom of the cartridge holder where the ink goes through and letting it sit for a couple hours then putting the cartridges back in and running the cleaning cycle a few times.
The alcohol should help dissolve the dried ink in the print head.
Jan 07, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Printer flashes error "replace color cartridge"
Try unplugging the machine and removing all the ink cartridges.
Now plug the power back in. Wait a minute or two and then reinsert the ink cartridges.
If you get the same message, the machine's ink sensors are probably finished.
Thanks,
Pat
Nov 08, 2010 | HP PhotoSmart 1115 InkJet Printer
All the lights are flashing. I have put in a new cartridge, unplugged and turned off the machine, I cleaned it with the air duster. It will not work
Try the following tricks:
Disconnect any USB cables attached to the printer and remove any memory cards from drive bay. Restart the computer. Unlock the ink cartridge locking clips. Remove all ink cartridges. Lock down the ink cartridge locking clips. Close the main printer door Turn the printer off with the Power button and wait for the printer to shut down. Unplug the printer AC adapter from the printer and the wall outlet or surge protector. Wait approximately fifteen to forty-five seconds to allow all current to dissipate from printer. Re-plug only the AC adapter into the wall outlet then into the printer, but do not plug in the USB cable. Wait for the appropriate missing ink cartridge error to verify that printer can recognize this error. Re-insert one ink cartridge only, to minimize confusion in case one of the cartridges is defective, and print an internal test page. If no errors are found, insert the other ink cartridge(s) and ensure that they are functioning by performing internal test pages or calibration pages. If an error occurs due to a defective cartridge, perform the appropriate steps for Resolving Ink Cartridge Rejections. After returning to the main Windows screen, reconnect the USB cable to the computer then to the printer. Good luck. Thanks for using FixYa.
Jun 01, 2010 | HP LaserJet 1012 Printer
How can I print in " Black ink only " NO COLOR ?
go to control panel
printers and faxes than right click on the driver for the printer and click on properties ...
and you will find the option to print in gray scale
Dec 23, 2008 | Canon PIXMA MP150 All-In-One InkJet...
My printer will not print.
Is there a cable physically connecting the printer to the computer? If so, do you see the printer in Printers and Faxes?
Nov 26, 2007 | Compaq Presario 5000 PC Desktop
RECOGNITION OF GENUINE CANON INK CARTRIDGE
I posted the original problem. Although the cartridge was genuine I had taken it out and reinserted it as I wasn't sure I had loaded it correctly the first time. Advice from my local retailer was that this was a mistake. Canon PIXMA printers no longer recognise a cartridge once it has been removed. Solution was another new cartridge which I shan't remove until it's empty. When this second cartidge is empty I shall try the first cartridge again as it is still full and unused. It has yet to print anything! Why Canon's helpdesk couldn't help is a mystery. I conclude that Canon's printer management systems are unfriendly to users. They are friendly only to Canon. I hope my experience will help others especially those considering buying a Canon printer. dudbob
Jan 22, 2007 | Canon PIXMA iP1600 Printer
Compaq Inkjet Ij300 Printer Logo
49 people viewed this question
Top Compaq Office Equipment & Supplies Experts
Ekse
Damen Wong
Damen Wong
Thomas F. Schneider
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
