Question about Kenmore 19001
Kenmore 19000 Scan Driver
I have a Kenmore R/W 19000 scan reader and can't see the drive on my windows XP. I am using a USB Serial cable and USB to Serial driver on my computer. The computer is not recognizing the scanner. I have downloaded a XP driver for a USB to Serial port, and still have no luck.
    President:
  • 1,944 Answers
Did you install the driver for your scanner?
Posted on Jan 21, 2008
Can I convert a Kenmore Elite reader/writer 19000 to USB?
Not unless it was USB to start with you can't "convert"
Oct 30, 2017 | Kenmore Sewing Machines
Will my PED BASIC work with windows 10
There is a version of the Brother PED-Basic that will work with Windows 10. Go to http://support.brother.com/g/b/downloadtop.aspx?c=us&lang=en&prod=hf_basiceus , and accept the EULA. This is a free update.
However, check if your sewing machine will work with Windows 10. The list is here: http://support.brother.com/g/s/hf/os/windows10/win10_hsm_us.html . With some sewing machines, no USB driver is available for Windows 10. For these, you need to put the designs on a USB flash drive to import them on the sewing machine. For other machines, you may need to add a serial port card to the computer or get a USB to serial port converter to connect the card reader/writer. See https://www.amazon.com/Trendnet-TU-S9-USB-Serial-Converter/dp/B0007T27H8 for one model. (Note: you may need a different converter. The best converters have an option to change the pin assignments. A lot of older serial devices did not use the pin standard that was eventually developed.)
I hope this helps.
Oct 29, 2017 | Sewing Machines
Serial port driver windows 98 husqvarna
Try contacting them...
Let them know what machine you have: Designer, Rose, Ruby, Etc.
What current computer OS you are using (you said 98/XP)
Ask...
And they should direct you to your satisfaction. They are really pretty good at assisting.
Toll free 1.800.446.2333
Monday - Friday: 8:00 am - 4:00 pm CST -
Machine support info@husqvarnaviking.com
- See more at: http://www.husqvarnaviking.com/Support#sthash.inJFCE6W.dpuf
Support
Support
Feb 24, 2015 | Husqvarna Sewing Machines
Using 3D software with 4D reader/writer on XP operating system. Getting error message "reader/writer not found" "VSM reader/writer & embroidery machine USB driver Type A" If I...
Hi Sheila,
Click on start, click on My computer, then look in the left hand menu for View system information and click on it, click on Hardware, click on Device Manager, your VSM reader should show under Universial serial bus controllers, normally at the bottom of the page. If there is a yellow ? mark next to it, it means the driver has not been installed successfully. If so, double click on VSM reader, click on driver, make sure your software CD is in your cd drive and click on Update driver. Should solve your problem.
Aug 31, 2011 | Husqvarna Viking 1
I need new software for Kenmore embroidery machne reader writer
I am having the same problem however I have Vista.....help, there has to be someone who can solve this problem. Sears is useless, the 5 person I was transferred to asked about my "lawn mower" after I had explained I was calling about my Kenmore Sewing and embroidery machine!!!! I am pretty sure my next machine will NOT be a Kenmore!
May 28, 2010 | Kenmore 19001
My Janome customizer 2000 will not write to the scan card. It says that it will not recognize the serial port.
Hi, I have the same problem with mine. Janome have not been very helpful. I didn't know if it was the card or the card reader/writer. I have a Janome CX500. Have you solved any of the problems?
Louise
May 14, 2010 | Janome Memory Craft 9000 Computerized...
Looking for an internet site that offers a patch for Kenmore (Janome)R/W 19000 embroidery software for Windows XP. The orig software is only compatible with Windows 95 and MS Word. Thanks so much.
I was informed there was no patch. The software was formated for windows 95 and will only work with that software. you can pick up a computer for less than 100 with that old windows system-- that is what I did.
May 08, 2010 | Kenmore 19001
Can I use my Scan n Sew PC on XP. If so is it
What version of Customizer are you using?
To answer your question without knowing *all* of the specifics, yes, you can use your S&S PC on computers running XP. You will need, however, a serial-to-USB adapter. You can pick one up at Best Buy for about $30 or you can take your chances at eBay for about $15 (with shipping). I, myself, bought mine at eBay and got a great deal.
Once you've hooked up (and installed the software for) the adapter and your S&S PC, you need to tell Customizer which COM port to use. To do this, open Customizer (either EasyEdit or EasyImport) and click the "ScanCard" menu item. Choose "Communication Settings" in the drop-down menu and then choose "COM4" in the "Channel" drop-down menu. You may need to play with the "Baud rate" to get the best results.
From there, Customizer will be able to speak to your Scan N Sew and vice versa!! :)
If there's anything I can clarify, please let me know!! :)
Jun 22, 2009 | Janome Memory Craft 9000 Computerized...
Kenmore l900l /Janome 9000
call the people who made your computer (hp, dell) and ask for a down grade to XP and that will solve most all your problems that you will have with vista. vista has built in things that you will not be able to run alot of your programs on.
Dec 17, 2007 | Janome Memory Craft 9000 Computerized...
Card reader connection
Buy a USB to Serial Adapter. I bought one made by IOGEAR and have had not problems,
http://www.iogear.com/main.php?loc=product&Item=GUC232A&PHPSESSID=119a3d80d289daeb12185ff1ee32e7ff
Dec 17, 2007 | Kenmore 19001
Sewing Machines Logo
325 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
