Question about Motorola Mobility 5.8 GHz Digital Cordless Expandable Phone System
Motorola MD761 5.8 GHz phone
Both my base phone and additional unit read "out of range" even when sitting in their chargers, and I cannot get a dial tone. Can anyone help me with this problem?? Thanks!
  • 3 more comments
  • Anonymous Feb 07, 2008
    both phones say out of range
  • Anonymous Feb 17, 2008
    Same problem.
  • Lowhib Feb 19, 2008
    Thank you for your suggestion... However, this phone doesn't seem to have a channel changing option. We untimately ended up disconnecting the power and reregistering the phone as if it were a new phone, and so far, so good.
  • purrho Apr 19, 2008
    This is about the 3rd time my phones have done this. I can't find my instructions and it's driving me nuts. No channel option on my phone either. Last time I just unplugged them and it fixed the problem. This time, I'm not so lucky.
  • DETROITSLUML Jul 09, 2008
    GOT A HIGH PITCHED HUM ON THE LINE. I CAN HEAR THE DIAL TONE, BUT WHEN SOMEBODY CALLS THEY CANT HEAR ME. ANY SUGGESTIONS?
  • 72 Answers
Change the channel on the base or the phones. That should fix the problem.
Posted on Feb 19, 2008
Motorola SD4581 2.4 GHz Digital Cordless Phone won't stop chirping
Bad contact between the phone and the base unit making the pair think they are low on battery.
it probably wouldn't hurt to get some rubbing alcohol, and clean the charging contacts on the base station and the handset. Oxidation can build up, and depending on whether you normally leave the handset on the charger or not, that oxidation can interfere with the contacts.
Feb 20, 2018 | Motorola Mobility SD4581 2.4 GHz Digital...
Will the vtech interact with already an existing Uniden 5.8 ghz power max base unit and handset plus one additional handset and charger to give me four locations or just two more single handsets with...
Hi there, Your new phones will not interact with a base station from another brand of phones. If you want to use one base station, you can buy single phones of the same model and brand and those will interact with the original base station. Your new phones will not connect to the old base station Sorry, Alex
Jun 03, 2011 | Vtech CS62192 Cordless Phone
Not able to dial out
the issue will be in the handset. please contact a panasonic service center. Please let me know your location so that i can try to provide you the address or contact no.
May 03, 2009 | Panasonic 5.8 GHz Additional Handset for...
Motorola c51
Hello mdellarusso. Disconnect the power to your phonebase. Remove the battiers from the portables. If the battiers are over 2years old replace them. Wait for 10minutes. Reconnect the base AC power, reinsert battiers and place on their chargers. Perform an operational test. If test fails I suggest a replacement system. Good Luck.
Oct 06, 2008 | Motorola Mobility C51 SD7581 Phone
Motorola MD400
Take battery out of handset for one minute.
Unplug base unit (power and phone line) for one minute.
Plug base unit back in (power and phone line).
Put battery back in handset. Place hangset on base for
one minute. This got my phone up and running.
I had no battery power in the base unit, but if I did, I think
you have to remove those as well.
Apr 17, 2008 | Motorola Mobility MD41 Expandable Handset...
Help with MD781 phone problem
on the phone that says, 'out of range' you need to select MENU then scroll down to the option that says REGISTER and select that. Then go to your BASE UNIT and push and hold the PAGE button until the 'bad' phone synch's up again. .... I called into motorola support and they stepped me through this.
I’m happy to assist further over the phone at https://www.6ya.com/expert/chris_6ddd78f70d3cfe52
Mar 03, 2008 | Motorola Mobility MD781 Phone...
5.8 GHZ Motorola Cordless Phone, Base w/1 additional phone
This is not a problem with the battery but rather the phone has lost sync. You can get it back by going to the menu screen then going to register. The phone will walk you through from there. Mine lose sync from time to time and I get the same error. I have these phones both in my shop and home.
Hope this helped you out...
Feb 09, 2008 | Motorola Mobility MD41 Expandable Handset...
Brand new cordless handset -- no dial tone, no ring!
I doubt it's the battery. As I understand it the base works fine and the problem is only with a cordless phone. Are you using an external charger stand for the cordless handset? These phones need to be registered to the base unit. That is usually done by installing the cordless phone in the base unit but you may need to do that shortly after insalling the battery or you could have a register button or setting.
Jun 18, 2007 | GE 27851FE2 Phone
No dial tone...but can hear the tv
move the Base unit away from the TV. Check if ADSL filter in use may need to replace one or all ADSL filters
2.4 GHZ hmmm do you have 802.11 BNG WI FI in use with any of your computers ???
2.4 Ghz is a problem as computer WI FI uses this frequency as well !
check the line cord is plugged in to the base unit
Check base has power
May 24, 2017 | Uniden DCX770 for DMX700, DCT600 Cordless...
No dial tone on handsets
Hey.. Did you check to see if the phone is registered correctly ???
Jan 09, 2007 | Olympia CDP 24201 Cordless Phone
Motorola Mobility 5.8 GHz Digital Cordless Expandable Phone System Logo
255 people viewed this question
Top Motorola Mobility Lands Phones Experts
John Donghia Jr.
John Donghia Jr.
Level 1 Expert
Eric Sutherland
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
