Question about Kenmore 17439 Built-in Dishwasher
When I turn on dishwasher it kicks breaker at wall outlet.
I have dishwasher that is portable and it is pluged into circuit breaker outlet. When I turn on dishwasher is acts like it is going to put water into dishwasher, but before water comes in, the dishwasher kicks the breaker off. I ck the lower panel where cord and motor are located and they appear like new with no visable problems.
Ne ideas to ck?
  • jwesbrooks Jan 28, 2008
  • jwesbrooks Mar 09, 2009
    Well, I put off fixing this until now. I ck the fill valve like recommended and then order new Fill Valve and installed it.
    Now when I turn on this dishwasher it will cycle thru the timer but nothing happens. I can hear the timer going thru each cycle and a small hum is heard then click, nothing but ticking of timer to next cycle. At least it now does not kick the wall breaker but it no "workie"
  • 770 Answers
If it is tripping the breaker you have a dead short to ground check the water inlet valve on the left side front unplug the 2 wire connector to it and plug it in see if it stays on if you you found your short if not let me know.. but i will need the model # off the unit to get the wiring diagram
Posted on Jan 21, 2008
Resetting computer on kdte204dss0 Kitchenaid
The most common reset for the dishwasher is:
1. First, unplug the dishwasher power cord or turn the circuit breaker off for 30 seconds.
2. Then, plug the dishwasher power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
3. After that, press the Pause / Cancel / Stop button twice to clear the display.
4. Finally, start a short cycle, to check operation of the dishwasher, by selecting a cycle and pressing and holding the start button until the dishwasher starts.
Jul 28, 2016 | KitchenAid Dishwashers
Our machine is frozen not responding to panel buttons
You can try resetting your dishwasher.
Jul 28, 2016 | Dishwashers
How do I fix -no power issue on my samsung dmr78ahs dishwasher?
To eliminate a dishwasher problem, run a heavy 3 pronged extension cord from a known working outlet to the dishwasher and plug the dishwasher into the cord. If you still have no power (dishwasher is not showing any signs of life) then it is a dishwasher problem (circuit board, bad connection from dishwasher cord to dishwasher, etc).
If the dishwasher actually shows signs of life, then you may have a tripped breaker. Check the breaker to make sure it is on and that the tab is not either in the center or the off position. Also, try moving the dishwasher cord's plug from the outlet it is currently in to another outlet in the under sink area. There is a chance that the plug got switched from the normal outlet to the outlet that controls the garbage disposal, that outlet should only be hot when the disposal wall switch is flipped to the on position.
Dec 18, 2014 | Samsung DMR78AHS Builtin Dishwasher
Blomberg dishwasher
Check your line fuse, circuit breaker, and/or ground Fault switch at the wall outlet. If they are OK; then a technician needs to do some troubleshooting techniques in you home to see if the panel circuit board is at fault.
Dec 25, 2013 | Dishwashers
My dishe washer wont turn on
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced
Now, if you have confirmed that the unit is receiving power from the outlet, and the unit is still not responding, this will lead to a failed control board, or timer module. replace either the timer, or control board, in this case.
Nov 05, 2009 | Dishwashers
Model ;LD-14aw2 will not turn on
Before you suspect the dishwasher, check the circuit that supplies power to it.
Determine if the DW's power is provided by a cord that plugs into a wall outlet or not. If the power is supplied through a wall outlet, unplug the dishwasher and plug in something like a light or a vacuum cleaner and turn on. It it comes on, then the problem is inside the dish washer.
If the power is provided through a direct connection from the circuit breaker, go to the circuit breaker box and track down which kitchen circuit ~may~ have tripped.
If the problem is inside the DW, solving that problem is not trivial and requires some special knowledge. If you investigate on your own, be 100% certain that the power has been removed from the DW for your safety.
Good Luck
Aug 16, 2009 | LG Dishwashers
Washer stopped mid-cycle, water in the bottom of the tub. Circuit breaker popped due to over-load. Reset breaker and it immediately popped again. Could this be cause by a jam in the grinder assembly?
My dishwasher just quit mid cycle. (still has water in it) It is a whirlpool partner 1. I checked the breaker and it wasn't tripped... but i reset it anyways. When I tried the dishwasher again it worked for a second and turned off. I have done reading about the thermo fuse but can't find it. Not sure how big of a problem this is.
Dishwasher is 5 years old.
Thanks,
Dale
Jul 02, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Won't turn on
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
May 29, 2009 | Kenmore Dishwashers
The water doesn't stay at the bottom of Dishwasher & The detergent doesn'e get totaly emptied out from detergent Tray. It looks like the the residue remain in the Dishwasher & On Dishes too. Please, help...
hi there,
no indication that machine is not working,is there any power supply,check the power source,circuit breaker switch on.
Step 1: Check to make sure it's receiving power. If the unit plugs into a wall outlet, check the cord, the plug, and the outlet to make sure they're functioning properly. Also check the switch that controls the outlet to make sure it's turned on. Most built-in dishwashers are wired directly into a circuit. Check the main entrance panel for a blown fuse or tripped circuit breaker, and restore the circuit. If your home is an older one, the dishwasher may be wired to a separate entrance panel; look for a blown fuse or breaker at this panel, and restore the circuit.
Step 2: If the circuit is receiving power, and the wall outlet is controlled by a switch, the switch may be faulty. Test the switch with a voltage tester. Take off the switch cover plate and place one probe of the tester on one terminal and the other probe on the other terminal. If the tester bulb lights, the switch is functioning. If it doesn't light, the switch is faulty. Replace the switch with a new one of the same type.
this should be done by appliance technician,but if you have knowledge on this check it out.regads have a nice day,dont forget to rate me thank's
Apr 30, 2009 | GE 25 in. Profile PDW8200J Built-in...
Dishwasher wont turn on
The dishwasher is generally on a separate circuit so if that circuit breaker kicks, or that fuse blows you won't see anything else turned off. Go to you panel and check to see.. If it is a blown fuse, replace it with a new one of the same amperage. If it is a kicked circuit breaker turn the breaker all the way off and then back on.
Apr 07, 2009 | GE GSD3800G - Multiple Color Built-in...
Kenmore 17439 Built-in Dishwasher Logo
209 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
