Question about Kenmore 43142 Front Load Washer
Belt keeps popping off when its spinning
I have replaced belt on this frontloading washing machine but now i think the problem is something else b/c when the cycle begins to spin it can not make a full rotation w/o the belt popping off again
  • 3 more comments
  • darlingangel Jan 21, 2008
    i do believe it is tight ...takes 2 just to pull it on (and even then it is no small feat). when the drum begins to spin it seems it cant go even half the rotation with out the belt popping off. the belt also keeps popping off the same spot. i can not afford the sears mechanic to come. is there anything else i may not be doing right?
    i do not see any guides...the machine is only 3 1/2 years old ..warrenty up. i am certain it is the right belt. now i am just not certain the belt is the cause.i attached the belt which has ridges on 1 side and flat on the other to the bottom half cylinder which seems to come out from a motor?. this cylinder also has ridges and spins to fix the belt to. then i attached the belt to the metal round piece which is attached to the drum ridges side up.
  • darlingangel Jan 22, 2008
    any other solutions????
  • Gcjhart Oct 22, 2008
    I have the same problem, but my machine did make noise like it was off balance then the belt came off.. Got a new belt and I know it;s the right one, but even if you turn the puller by hand the belt comes off.. Any answeres please e-mail me at Gcjhart@zoominternet.net..
  • newegg Oct 24, 2008
    I have the exact same problem. I ordered a new belt, and that even pops off. I spent an hour trying to make sure when I hand-crank the drum that the belt wasn't drifting forward or bak off the drum wheel. Worked fine until I actually loaded it and then the belt popped off again. I feel as though I'm missing something.
  • 397 Answers
You have to make sure that the tensioner and belt are tight, see if you can slide the housing back some more to give it tighter fit
Posted on Jan 21, 2008
  • Custom Exchange
    Custom Exchange Jan 21, 2008
    are u sure u have the right belt?, plus how old is the machine? and is everything aligned? meaning machine parts where belt go doesnt look slanted or off track? ,,,do you see any guides to keep belt on track?
GE frontload washer doesn't spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 12, 2011 | GE WSXH208A Front Load Washer
Maytag Neptue frontloading washing machine model MAH5500BWW stopped spinning (machine is about 15 years old). I opened up the back and saw the drive belt was thrown. Reinstalled it (perhaps badly) and...
i would say you have a warped main pulley, run the machine in spin,watch it early to detect any wobling in the belt should be no sideway movement. also check main pulley is tight with no lateral wobling.
Dec 21, 2010 | Washing Machines
Frontloader spins when washing but when it's time for the final spin it won't spin, even if I set it to the spin only setting and still nothing. What to do? Is there a belt or something?
heatman101
Sep 29, 2010 | Frigidaire Affinity ATF7000E Front Load...
Frontload Duet. The tub will not spin, the belt
I am not an expert but I would suspect a failing bearing has seized up. Mine would spin one direction, but not the other. I worked it and got it to go both ways, but with a snapping sound. This is checked by spinning the pulley with the back panel off (machine unplugged of course).
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The washing machine belt keeps coming off any ideas why, should it have any stoppers or something to keep it from sliding off thanx . beko wma1512s
Belt would have become expanded after use. Try adjusting the motor base by moving in the direction it tensions the belt. Or replace with the identical belt No. Clean belt resting area free from any old belt rubber deposits /markings.
Apr 16, 2010 | Beko 24 in. D3731F Free-standing...
On my frontload LG tromm I have the error code EO it will
There is a filter on the bottom left of the machine. If you pop the door off you can drain it with the hose, then spin the black filter out of the housing. This may help. Keep a wet/dry vac handy.
Nov 28, 2009 | LG WM1814CW Front Load Washer
Maytag frontloader washer, seems to wash ok but won't spin water
madam some times the timer of the washer may go wrong and it wont makes the machine to spin so please check it once without loading the machine.
Aug 07, 2009 | Washing Machines
Frontload Washer won't spin or wash.
check the door lock/ latch mechanism
Sep 17, 2007 | GE WSXH208A Front Load Washer
Front load washing machine would not spin now won't wash either.
Sounds like you have a broken belt or a bad motor. The easiest way to tell if the belt is bad is to reach inside the drum and turn it. If it turns very easily, you probably have a bad belt or something has caused the belt to jump off, such a s a loose pulley or bad bearing. If it feels like there is a good amount of resistance, or a kind of "winding up" noise, then the belt is still on and you likely have a bad motor. Also, you could just scoot the macine out, unplug it, and remove the back cover a look inside to see if the belt is still on the pulleys. Good Luck!
Oct 17, 2006 | Bosch Exxcel WFO 2465 Front Load Washer
Kenmore 43142 Front Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
