Question about Dell Inspiron 9400 Notebook
Dell 9400 Won't Start
I have a Tell Inspirion 9400 and it won't start. When I press the power button, all that happens is the power light and the light next to it come on and about 3 seconds later it makes a sad noise and turns off. Does it with and without the battery and/or power adapter, tried all combinations.
  • 1 more comment
  • joethristy Mar 27, 2008
    I have the same problem with my dell 9400 and i called dell and they told me to reinstall windows, and i did and it help for a couple of days, so i dont know what it is now, what a piece of ****, i have used a lot of dell computers and had great success but this one is about to ruin me on dell
  • gorean May 28, 2008
    Exact same problem. Just had the Mainboard , vid card(7800 go)Lcd replaced,for other problem, now this.
  • DaveJH Sep 20, 2008
    Dell 9400 purchased March 2006. It won't start up by battery or mains supply. When I try to start it the screen sometimes goes blue and then fades away, and that's it!
SOUNDS TO ME LIKE A BIOS DATA PROBLEM THAT'S STOPPING IT FROM BOOTING TO THE BIOS.
Posted on Mar 03, 2008
I suggest that you should replace the battery because batterey may be faulty take it down to your nearest pc repair shop
Posted on Jan 21, 2008
6ya staff
SOURCE:
When i turn on my Dell Inspiron 2400 Desktop Computer why won`t it start.
Is the computer plugged in to a known good power source with a known good power cord? Also, make sure the power is fully seated on both ends. When you press the power button are you getting any indicator lights? The power button itself has an LED that will be either solid green, blinking green, solid amber, blinking amber, or off. Do you hear any beeps?
May 19, 2014 | Dell Inspiron 530s Desktop Computer...
My laptop won't turn on. I tried taking out the battery, a different battery, a differnet power cord. It won't turn on. Is there a way to reset it?
Are there any lights or indications on the battery itself that might tell you if the battery is good? I had a laptop with a similar problem and it turned out to be both a bad battery and a bad "power brick". replacing both fixed my issues. Also, try holding the power cable at the point where it connects to the laptop and push to the left or right. A friend's laptop would only start if you held the power cable to the left. Otherwise, it sounds like a mother board issue. Sorry.
Oct 11, 2012 | Dell Inspiron 8600 Notebook
How do i turn on my wireless capability for a dell inspirion 9400 without using the fn and f2 buttons because the f2 button dose not work
Click start then type Device Manager in the little window. Go to networks adapters click the square or triangle beside it. Right click on the one that says wireless whithin the description and then click ENABLE if this does not work your wifi card is bad. You can purchase an aftermarket really cheap
Nov 12, 2011 | Dell Inspiron 9400 Notebook
Poweredge SC 1420 won't come on, it keeps blinking an orange light on the power button and the lights below the power button the first 3 indicator lights are orange. I tried unplugging and plugging it...
hi,
I have several of these and most often there power supplies blow. since they come by default with only one powser supply. the system won't start
I would start there as most other problems will generate beeps.
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Aug 17, 2011 | Dell PowerEdge SC1420 (SC1420MIN) Server
My dell desktop won't start. when press the front panel button, computer won't start
check the power connections, if its okay change the power supply or smps
Jul 27, 2011 | Dell Dimension 3100 PC Desktop
Dear sir! my dell optiplex gx 150 won't start when i press the power button but power supply will be start and pc can't give any beep ?
try to remove the power cable on that product and then hold the power button for 8 secs. Reinsert back the power cable and press the power button. If it won't turn on, then the power supply is the main cause of trouble. Contact dell right away for repair...
Jun 22, 2011 | Dell OptiPlex GX280 PC Desktop
I have a dell Inspirion 9400 and it won't start. When I press the power button, all that happens is the power light and the dvd player light comes on and about 3 seconds it turns off. Does it with and...
It shows no power on your laptop but it shows you the dvd player led comes on then off. I would suggest try the following:
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well. 2. Make sure AC Adapter is not yet connected to the laptop. Press and hold on the laptop's power button for 10 seconds to drain the power flea. 3. Connect the AC Adapter to a known good power outlet, check AC Adapter power LED if it is on. Try to sense if AC Adapter is not making a bit of noise when it is plugin to the wall power outlet. 4. Connect now the AC Adapter to the laptop. Check if AC Adapter LED stays on when it is connected to the laptop. If the LED stays on means the AC Adapter is fine. If the AC Adapter LED turned off check the AC Adapter pin that goes to the laptop AC socket if it is loose. 5. If AC Adapter stays on after connecting to the laptop try to power on laptop. If no power LED comes on then this is motherboard problem. 6. Before replacing the motherboard there is one checking needs to do. If you can open your laptop bottom part then good, do this when laptop is not connected to any power source. Try to reseat the laptop CMOS battery then try to power on laptop after, if still fails then replace motherboard. I hope this helps.
Dec 12, 2009 | Dell Inspiron 9400 Notebook
Dell inspririon 9400 wont start
(before you do anything remove the battery and th ac plug)remove the memory inside small door on the backside that has a "M" on it now once you remove the memory install the battery, power on if you hear a couple of beep tones you are half way there the motherboard is good so the problem is what you took out so there are two memory slot try them in the A slot one at a time.If the problem is memory replace it.
Good luck
Aug 29, 2009 | Dell Inspiron 9400 Notebook
sounds like bad motherboard/power supply. Just to be sure though have you upgraded the ram? If you have more then one memory chip try siwtching out each one and seeing if it's boot farther. It's possible a dimm went bad or the port it's in went bad. Otherwise motherboard/powersupply
Dec 08, 2008 | Dell Inspiron 9400 Notebook
Dell Inspiron 9400 Notebook Logo
1,095 people viewed this question
Ekse
Clive
Clive
Alun Cox
