Question about E-Machines eMachines Desktop PC
My computer Emachine t6410 will start to start up but turn off right away. i tried a new power supply, but that did the same thing as before. what do you think it is?
  • 55 Answers
Ok " here is what i would do , un plug the power to hardware one by one, and restart computer, after each unplug
think youll find the one thats causeing the problem
Posted on Jan 21, 2008
I cannot start my eMachine ET181003r. Every time I try to start, just hear humming sound for one second and then stop. I am not sure it is the FAN problem or not.
What you are most likely hearing is either one of the fans within the computer case, or a Hard drive. The problem could be many things and would most likely need to be inspected in person. I am sorry I cannot be of more help in this situation. Good luck!
Dec 23, 2010 | eMachines ET181003R PC Desktop
How di do a hard reset on emachine t6410
A hard reset means that you press the reset button that is next to the power button on the computer case, as opposed to a software reboot, start > restart.
Nov 28, 2010 | E-Machines eMachines Desktop PC
I have an emachine t5026 that won't turn on. It
There can be two problems with your PC. either the power supply is faulty which is highly probable, and the other is that your Motherboard maybe faulty or both things are faulty. Try replacing the Power supply first. It should solve your problem.
May 15, 2010 | E-Machines Emachine T5026 power supply **...
Emachine T6410 turns on but the screen says ''No Signal''
This problem is very common when you have a bad ram/ memory module or it is not making sufficient contact. Remove them and clean with a piece of dry cloth and reseated properly. Try it again. If it is still not coming on, the ram may be bad. Get them tested and replaced.
Jan 05, 2010 | Computers & Internet
My gateway desktop PRB 510S, if I turn it off and unplug it or electricity goes off, the computer wont start back again. Wont do anything. No lights no fan, nothing. Then 5 to 10 minutes after I turn it on...
Try connecting a different power supply to it. If the same situation repeats, then it's an internal (motherboard) problem. If the problems go away, then the power supply needs to be replaced.
6 years... I'm surprised the PSU even lasted that long! The power supply is the cheapest part of the PC and usually one of the first parts to fail. Don't worry, a replacement power supply is not too expensive. Good luck!
Dec 02, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
I have a emachine T5082
might be a bad power switch have had trouble like this before
Sep 25, 2009 | E-Machines Emachine T5026 power supply **...
Emachine wont start
remove all external and internal peripherls.
example for external: mouse, monitor, keyboard, printer.
Internal: hard drive, memory modules, video cards, modem (if there's any), optical drive or dvd drives.
just leave the motherboard, power supply and processor intact, try turning on the computer with out those components mentioned. see if you get a beep sound before it turns off, but if not the most logical part that needs to be replaced on this type of problem is the power supply if that doesn't work the next thing to do is replace the motherboard. hope that helps
hit me back on the results. thanks!
May 25, 2009 | eMachines T6211 PC Desktop
I have a e machine T6410 ,had to restore, sound, help!
Download and install the audio drivers from this eMachine link:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 19, 2009 | E-Machines eMachines Desktop PC
Emachines shuts down by itself all the time
There are a lot of problems with Emachines as far as motherboards go. Since you've already replaced the power supply, it's safe to say that it's not causing your issue.
Since you seem comfortable with the inside of your machine, go ahead and take out all unnecessary components. If you've left your machine the way it was since you've bought it, start with the modem card that's in the bottom PCI slot. Often, those can cause issues with the computer not starting up, staying on, etc.
Also ensure that the machine is free of dust, and that all cables and connections are secure. Try not to let things float freely, and make sure you're plugging the machine into a surge protector, and not directly into the wall.
Apr 08, 2008 | E-Machines eMachines Desktop PC
Emachine wont start, just beeps
This is probably a problem with your DIMM(RAM) Did u recently install an extra RAM?If yes then remove it because the beep sound is due to the mismatch of frequency of two DIMM's. If not open your computer and check if the DIMM is loose just push it in and powerup your comp..Let me know if its fixed..
Oct 08, 2007 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
94 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
