Convergence adjustment @ 52MH84
I know this question is old, but here we go again.... I have a 52MH84 with a convergence problem. All the instructions indicate to enter the service mode and then press the "yellow" button on the remote. Problem is I do not have the original remote (CT90159) since it is no longer available. I replaced it with a dynatron MR120 miracle remote which works fine but does not have a "yellow" button. Can someone tell me what the yellow button's normal function is on the original remote so I can try to figure out which button duplicates this and thus enter the convergence adjustment menu? I can get the screen to go entirely red, green, blue.... but cannot find the convergence grid
  • 8,617 Answers
Press mute on the remote then while pressing mute press menu on the set.then you navigate with the instructions below.
3. KEY FUNCTION IN THE SERVICE MODE
The following key entry during display of adjustment menu provides special functions.
Screen adjustment mode ON/OFF: TV (ANT)/VIDEO button (on TV)
Selection of the adjustment items : Channel s/t (on TV or Remote)
Change of the data value : Volume s/t (on TV or Remote)
Adjustment menu mode ON/OFF : MENU button (on TV)
Initialization of the memory (QA02) : RECALL+Channel button on TV (s)
Initialization of the self diagnostic data: RECALL+Channel button on TV (t)
“RCUT” selection : 1 button
“GCUT” selection : 2 button
“BCUT” selection : 3 button
“SCNT” selection : 4 button
“SCOL” selection : 5 button
“TNTC” selection : 6 button
Convergence adj : 7 button
Self diagnostic display : 9 button
Posted on Jan 21, 2008
6ya staff
SOURCE:
Panasonic pt-51hx42f replaced 2 convergence chips and 6 convergence resistors. still can move any of the convergence set-up arrows. was told it might be the pico fuses. But I cant locate them on the...
No thats not the Problem you have to know HOW TO ENTER SERVICE MENU Their is a Long Step in getting into the SM
if not done correctly you can really Mess this TV up! Once you Enter the service menu then you can go to convergence and adjust
to correct Pattern,Then you Must Exit correctly with the Save Mode to Save alinement or you will have to adjust all over again.
Sep 20, 2010 | Panasonic PT-51HX42 51" Rear Projection...
Picture is distorted blurry
Model number indicated is prone to convergence problems; red or blue shadows around writing or letters---
The model indicated uses two of the STK-392-570 convergence chips; they are located on a large metal heat sink with fins at the front of the middle board inside the set.
The board has to be removed to replace them.
A pair of the chips can be purchased on EBAY (where I buy mine) for about 15 dollars-----total parts cost to fix set should be under 25 dollars.
I also have repaired hundreds of these sets and have:
Start to finish, step by step instructions for this repair in this set; they tell you everything you will need and exactly how to do the repair.
I can if you request post the instructions here for you for FREE.
I will attach a photo or two of typical convergence problems so you know if it is your problem and a photo of a typical convergence chip.
If all this information helps you, rate this solution as very helpful here as I do this for free.
SD TECH
ee35869.jpgTypical convergence chip---yours will have stk-392-570 on the front of them.
Red convergence skewed and off.
Convergence skewed---also a bad ic chip!
Let me know if I can assist you in any way.
Aug 13, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Sony kp-53xbr45 please let me know step by step how to enter convergence service thank you
To enter into the convergence service of your sony, follow the steps below;
  1. Press "Menu" on the remote control. Use the up- or down-arrow button to move the cursor to "Setup" and then press "Return."
  2. Use the up or down arrow to move the cursor to "Convergence" and press "Return." This will bring up the convergence-adjustment screen.
  3. Press the up or down arrow to move the cursor to the line you want to adjust (either vertical or horizontal for red and blue) and press "Return."
  4. Press the up or down arrow again to move that line until it converges with the center green line and press "Return."
  5. Repeat to adjust the other lines until all three lines converge and are seen as a white cross.
  6. Press "Menu" to exit the convergence menu and return to the original screen.
You can as well follow these steps;
  1. Press the "Power" button to turn your TV on.
  2. Wait at least 30 minutes before you adjust the convergence in your television. This allows your TV ample time to warm up before you make the adjustment.
  3. Turn your TV to a cable channel or to an antenna channel with a picture that you can see. A music channel with a static shot of music notes isn't the kind of picture you need. Instead, look for a picture like what you would see on a movie, sitcom or drama.
  4. Press the "Flash Focus" button located in the front panel on your TV. You may need to open a hidden compartment on the front of your TV to access this button. The convergence will repair itself automatically after you hit this button. It may take several minutes.
Any of the two processes are detailed steps on how to enter your convergence service.
Take care
Jul 03, 2010 | Sony KP-53XBR45 53" Rear Projection...
I have a ghosting problem everything else is good
Ur convergence it dead,must replaced convergence ics.resistors so..Buy a convergence kit,use what in that kit,u know how to solder right?Tries Tv repair World.com,Ebay.com or Repair kits,for this convergence kits,most of the DLP tvs with this prob.
Oct 31, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Service code needed to complete convergence adjustments
I have the service convergence code: mute-1-8-3 (make sure your tv is on and set to antenna. if it doesn't work press S. Mode and make sure is says standard then re-enter code.
So, I have the code but I need the convergence chips. Where did you get the convergence chips?
Jan 26, 2009 | Samsung HCM653W 65" Rear Projection...
Convergence will not line up after replacing ic & resistors
Did you replace the resistors when you replaced the convgence chips? If one of them was bad you would still have the problem.
Here are some of the most common symptoms and example photos.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Jan 03, 2009 | Philips 51PW9303 51" Rear Projection...
Panansonic rear projection TV Convergence needed
Go to this web site and Print out information on How To Enter Service Menu http://www.freelist.org/archives/techassist/09-2005/msg01111.html Read this very carefully when trying to get into service menu its no easy walk in the park, i hope i never have to set convergence on another myself. (1) Switch to cable (2) Set sleep timer 30min ,exit menu , now enter channel 124, Press vol- on tv ,at zero volume a Red Ck should appear , Re enter menu turn sleep timer off ,Now Press power untill you see oVoo using ch+ Adjust to OV1 ,now Press vol+ You should now be in convergences---- Mute locks- cursor to move- vol-&vol+/ch- ch+ to ajust lines---- Press R-Tune to switch color to adjust When done Press (7) to save then Press Then Press and hold power and action for 5 sec . GOOD LUCK.
Dec 15, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Convergence Adjustment
you need new convergence ICs let me know if you want the link to where you can get new ICs along with free installation instructions and instant messaging tech support for free to do the repairs.Thats a free service for customers who buy the ICs
Apr 04, 2008 | Sharp 55R-WP4H 55" Rear Projection...
Convergence
Touch-up Convergence adjustments Enter the Digital Convergence Mode (DCM) by entering 0-6-2-5-9-7-(Status or Index) on the Remote control. The following menu will appear: Select an active channel or Aux Input. A signal must be applied to the set when performing convergence. If any Customer Adjustments need to be made, the Menu button can be used to toggle between the Customer Menu and DCM. The MPOSD ADJUST is used to center the Customer Convergence grid. A highlighted cross will appear along with the Convergence alignment grid. The highlighted cross should be centered onto the center of the Convergence grid. To perform a Touch Up Convergence, highlight SELECTION and press the right cursor button on the remote. The following menu will appear: Selections STORE, RESTORE FACTORY, and RESTORE DEFAULT are not shown after selecting SELECTION. Press the cursor down button on the Remote for these selections to appear. RESTORE FACTORY loads Convergence defaults from the Factory Loaded section of the Convergence Memory IC. RESTORE DEFAULT loads Convergence defaults from the sets software. To perform a Touch-up Convergence: 1. Enter the Convergence Mode and select RED TO GREEN or BLUE TO GREEN. Do not select GREEN (Green Geometry) without placing a Template over the screen. To perform Green Geometry, refer to the Complete in-depth Convergence. 2. Use the Cursor buttons on the Remote to Navigate from one adjustment point to another. Press the Status or Index button on the Remote to select ADJUST. Use the cursor buttons on the Remote to adjust the Red to Green or Blue to Green. Press the Status or Index button again to navigate to the next adjustment location. 3. After Convergence alignments are complete, press the Menu button on the Remote to return to the SELECTION menu. 4. Highlight the STORE selection and press the right cursor key on the Remote to save changes. 5. Use the GREEN TO RED or GREEN TO BLUE selections to perform convergence when the Green CRT has been replaced.
Aug 18, 2007 | Philips 60P8342 60" Rear Projection...
Televison & Video Logo
226 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
