Question about Mitsubishi VS-50707 50" Rear Projection Television
Unable to access all tv channels
I can only access 12 of the 60 channels in my cable package. I purchased the tv new in 2000 and it has worked fine until recently. I had it serviced by a local tv repair store and was told the problem is a bad circuit board (part #930E:856002.) Does this sound correct? If so, how do I replace it ... the technician did not know where to get this part.
Maybe hit menu button and go to add or delete channels and add the channels then reprogram your tv. let me know what happens at www.gillardk.com
Posted on Jan 21, 2008
Hdmi cable for 40" led TV WHAT ARE THEY FOR
The hdmi cable is used to connect the tv to devices so it can be displayed on the tv. Devices such as, but are not limited to, computers, bluray/DVD players, gaming consoles, etc...
For channels, you have two options.
1. You would need to purchase a cable package from one of the options in your area. They will run a line I to your house and provide you with a cable box in which you connect the cable box to the tv via hdmi cable.
2. You can purchase an antenna and plug it into the tv. Run the channel search and you'll have those channels. Some TVs may have built in antennas but if yours doesn't, I'd go for a simple antenna from target or best buy. Or you can purchase it online.
Thanks!
Sep 22, 2014 | SEIKI Digital SE40FY19 40" LED TV...
Unable to switch from tv to cable Magnavox older 13
Have you tried accessing the on screen menu and maybe changing the input type to cable or even line in if you are using rca (red/white/yellow) plugs to connect the cable box to the television?
Oct 19, 2012 | Philips Magnavox 20MT133S 20" TV
I am unable to record digital tv channels on my LG RC389H dvd recorder. I have a new tv with a digital tuner and have hooked them up but unable to view any digital tv on my LG player only the old analogue...
The RC389H is only deigned to receive standard TV signals, not digital. If you are routing through a straight cable line you usually can't access anything above 100 if you don't have a digital tuner. Try using a cable/satellite box if you haven't already, this bypasses the requirement for a digital tuner because the cable/satellite box has one of it's own.
Aug 27, 2011 | LG Televison & Video
Unable to view TV programming on TV, able to utilize set for viewing DVD/VCR movies. Cable company says their Cable Card is 'OK' and the TV needs updates (assume software) in order to work correctly with...
U get a channel numder and menu screen do show up?Not the tv,it the incomming broadcasting signal cable plug in or the cable box itself have problems.Tries unplug,replug the tv and the cable box back in like about an hour later.The tv will reset itself to the factory setting and the cable box should upgraded it softwares.Should work now.If have the same problems,tell the cable company change the cable box or check the incomming broadcasting cable wire with another tv,see the incomming broadcasting signal cable wire,with a new cable box,see if it work.
Oct 21, 2010 | Toshiba 46HM95 46" HDTV
Cannot access channel 73 on TV2
If you are unable to access the TV menu using the buttons on the TV itself it is possible you can with the TV2 remote if it still controls the volume etc. for this TV. If it doe not you will need to find a code for your set in the manual for the receiver or you can go to the following link to find that info as well.http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/625.shtml
Assuming you have control of the volume still press the small TV button on the top left of the remote. Now press the menu button and you may be able to access the TV's menu. If so you need to run a channel scan/auto program the TV. You may need to use the buttons on the TV still to maneuver through the menu.
If you are still unable to access the menu you may need to purchase a universal to access the menu.
Jan 11, 2010 | DISH Network DVR-625 DTV Receiver /...
On-screen menu works but channel search yields no channels.
if you can access tv menu go to settings that show source(antenna/cable)highlight cable setting and hit search/program ;tv should go through all the channels and scan them into memory. it just might be that it is still under antenna setting .try solution ,it might be what's wrong.
Apr 02, 2009 | Televison & Video
Channel Changing
Some TV's have a 115 to 125 channel limit then will go to video in and then channel 2 and start over. Your TV's tuner may not have the ability to decode those channels. My suggestion would be to get a set top box (cable box) that can access channels. Your provider should have these or can suggest where to get one. Probably less expensive than a new TV.
Sep 24, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Can not access setup
hit vol down on the tv and hold then with your universal remote puse 1. This will set the tv back to factory defaults and give u acess to all cable channels.
Jan 08, 2008 | Televison & Video
LG 4912 using with a new digital TV
in order to solve the complect of channel/ choose one / if tv is digital in line w/dvd is digital.
If your your recorder is analogue choose use analogue channel.
Dec 14, 2007 | LG DR-4912 DVD Recorder
Sharp 36K-S400
Check the tuner input mode it has (air, cable,hrc,irc) with new stations updating to HDTV the demodulation at the tv sometimes looses the color burst sync. I have seen this with more and more tv's with pip tuners , it resets to the default of air ( rabbit ears ) at 75ohms and the low band snow, when you go to the high band (56+) it finds the color sync and resets the vestigial sideband offset, it happens more often if the SAP or CC is also trying to aquire the proper offset. good luck.
Nov 17, 2007 | Sharp 36K-S400 36" TV
Mitsubishi VS-50707 50" Rear Projection Television Logo
73 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
