Question about Motorola Mobility RAZR V3i Cellular Phone
"busy" camera hi...i could no longer use the camera and video on my motov3x...every time i open it.. a "busy try again" message is displayed...is my camera damaged or this is a software problem in my phone?...i already tried resetting it...i just bought this phone...thanks When I use the upper left soft key, the screen goes black with a small camera icon, then within less than 1/2 second, the phone screen returns to the main menu. If I drill down to the camera function via menus, then when I select camera, the screen goes to black with the icon, then displays an error message "Busy. Try again later". I called Motorola and all they could suggest was to go through the "master reset" process, which I did, with no impact on camera function. The only alternative for me was to send the phone in to Motorola for service (since I did not buy the phone from my service provider who would handle any warranty service) and that they would charge me $75 to evaluate the problem and advise me of the cost to fix the problem. I only paid about $100 for it (V3i) and I don't really have much need to use the camera, so I guess I'll just live without it, unless someone comes up with a fix on this blog.
  • 3 more comments
  • hankjeff Jan 22, 2008
    In case you hadn't noticed, a lot of people are having the same problem. What do you suggest to remedy it, get a software update from Motorola?
  • mourty Mar 17, 2008
    Motorola v3x camera/video camera doesn't work "busy. Try later" appears - HELP
  • Anonymous May 13, 2008
    same, my camera says busy try again
  • whitelily Aug 20, 2008
    I am facing the same problem as well. Please suggest what i can do.
  • kingnalive Apr 10, 2009
    how do solve the problem tell me plsssssssss
  • 70 Answers
It sounds like its a software problem
Posted on Jan 21, 2008
Video no longer transferable to PC
HI DID YOU FORMAT YOU MEMORY CARD AND TRY AGAIN TO TAKE VIDEO AND TRANSFER TO PC.
Jun 02, 2014 | Sony Cyber-shot DSC-H9 Digital Camera
Camera turns on, lens cyles (in and out) 3 times, then camera displays a message "Turn the power off and on again" superimposed on the display. Image is not in focus and camera will not take picture, just...
This is lens mechanism problem and lens assembly will be replaced to fix the issue.
Lens tries to correct its mechanical error three times then gives up and you see turn power off and on again display in lcd. If camera is under warranty, please call Sony to get it fixed or take camera to local camera repair shop if its out of warranty.
Thanks.
Jun 13, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
This message displays any time i try to access the camera. "could not start the camera. close other applications and try opening the camera again". please help.
This is what you should do, press and hold the menu key.. you'll get a display in a rectangular form with all programs that are currently running on your blackberry.
You can scroll through the open applications and for you to close all running applications, you'll have to click on your trick ball to get you to that open application and then you close it.
Go over the process of holding the menu key for about 10 seconds again until the rectangular window opens with applications that are currently open.
Click on another program and close it.... do this for all the applications until your have about 4 applications running. Once it's reduced to this you would be able run your camera.
Regards
Apr 08, 2010 | RIM BlackBerry Bold 9000 Smartphone
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
L7 Camera is not working.
check any vires issue,or full format
Aug 18, 2009 | Motorola Mobility SLVR L7 Cellular Phone
No display; flash busy message is in view finder; new battery
I had the same problem, camera is only 5 months old and still under warrenty. I sent it into cannon for repair...mother board was shot...new board installed...have used the camera 2 times since getting it back...camera has died on me again...same problem. Have to send it back again! Don't recommend this camera to anyone!
Jun 23, 2009 | Canon EOS Rebel XS 35mm SLR Camera
Camera Is Not Working
Is the memory card full? try removing some files on and try opening the camera again, normally if the space in full it takes time to initialize.
Nov 05, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Camera
I have the same thing. even after taking the battery out and replacing it says the same message.
Jul 27, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
"busy" camera
ur phone connecting cable is not functioning, reply me with more detail
Dec 07, 2007 | Motorola Mobility RAZR V3x Cellular Phone
Camera says busy, try again later
did you recently dropped your fone? if yes, open up your fone on the display part and try to push back the camera connector module. hope it works. if not theres a problem with the flex cable of your fone
Nov 26, 2007 | Motorola Mobility V265
Motorola Mobility RAZR V3i Cellular Phone Logo
166 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
