Question about Uniden BCD396T Handheld Scanner
Programing I know this is basic, but have lost the instruction book for uniden UBC72XLT. How do I program a frequency in to the channels. I have managed as far as puting the frequency on the the display, but can't find how to enter it to keep it.
  • fuchsiaman Jan 23, 2008
    Many thanks for your help. It's easy when you know how. Put it down to a senior moment. Once again many thanks
  • 204 Answers
Hi, this is from the book.
1. Press Hold. Then enter the channel number
where you want to store a frequency, then press
Func and Pgm. The channel number appears.
2. Use the number keys and to enter the
frequency (including the decimal point) you want
to store.
3. Press E to store the frequency into the channel.
If you need to print a new manual, just go here.
http://www.uniden.com/pdf/BC72XLTom.pdf
or you can read it online also,,I hope this helps you out with your problem,,, Mechanic
Posted on Jan 23, 2008
Lost owners manuel. need code install instructions. and also how to clear off all old codes
There is no general reset function that will clear all of the frequencies (they're not codes) from your scanner, but there are two ways to clear individual frequencies:
1. Programming "0.0" (zero point zero) into a channel will remove the programmed frequency.
2. Programming a new frequency into any channel will remove/override the previously programmed frequency.
You can download and print the manual for your scanner, at no cost, here:
http://www.uniden.com/pdf/BC248CLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Nov 16, 2010 | Uniden BC248CLT Base Scanner
I have a Uniden Bearcat 140 10 channel scanning radio and need to know how to program it. Can you help? The Model is BC 140 and the serial # 73061234 It was my dads and he passed on and I want to...
Your scanner is a basic 10-channel "oldie" and it's fairly simple to program and operate. To enter/program a known frequency:
- Power the scanner On
- Press MANUAL to stop scanning
- Press MANUAL repeatedly to advance to the channel that you wish to program
- Enter the desired frequency, including the decimal point (e.g., 156.225).
- Press E to enter the frequency into memory
Press the MANUAL key to advance through the channels, and press SCAN when you're ready to listen.
For a comprehensive database of active frequencies in your area, visit:
Bill B.
Oct 20, 2010 | Uniden BC244CLT Base Scanner
How do I program my bearcat 144xl scanner?
The BC144XL is one of the few scanners that I haven't been able to locate a manual for, but programming it is fairly straight forward. Here's some guidance from Uniden:
Here are basic instructions for programming nearly all of the older scanners that Uniden produced. When the scanner is turned on press the MANUAL key, then press the channel number that you want to program first, then the MANUAL key again. This will stop the scanner from scanning and hold it on the channel that you want to program.
Then you enter the frequency (be sure to use the decimal point in the right area when entering in the frequency) and then press the E or ENTER button to save the frequency on the channel. You are now finished programming the channel. To advance to the next channel simply press the MANUAL key and enter your next frequency the same way that you entered it on the previous channel (as described at the beginning of this paragraph).
I hope this helps.
Jan 01, 2010 | Uniden BC248CLT Base Scanner
I inherited a uniden bearcat BC147xlt! How do I
I was unable to locate a manual, but this is a basic 16-channel scanner, and the frequency coverage is probably listed on the ID plate. To program, turn the scanner ON and use the MANUAL button to stop scanning and to advance the scanner to the channel that you want to program. Enter the frequency that you want to program, including the decimal, then push the E (Enter) key. Use the MANUAL key to advance to the next channel, and program as above.
For an extensive database of active frequencies in your area, visit
or
www.CityFreq.com
Oct 29, 2009 | Uniden BC60XLT-1 (30 Channels) 2-Way Radio
How do i program a uniden bc144xl scanner
I couldn't locate a manual for this one, but here's some programming guidance from Uniden:
I hope this helps.
Oct 15, 2009 | Uniden BC248CLT Base Scanner
Need manual for uniden scanner bc155xl
I couldn't find a manual for this oldie, but here's programming guidance from Uniden:
I hope this helps.
Sep 15, 2009 | Uniden BCD996T Base Scanner
I LOST MY MANUAL TO MY UNIDEN BEARCAT BC142XL CAN I GET A FREE REPLACEMENT?
A number of scanner manuals can be found online however I don't know the difficulty of finding it for this unit. More than likely if you need printed material sent to you it will cost you.
To program the BC142xl 10-channel scanner:
Press the Manual button. Continue to keep pressing the Manual button until you are at one of the ten channels you wish to program the frequency into
Press the E button
Enter the frequency you want to store in this channel
Press the E button - Your frequency is now stores in this channel.
To later see what frequencies you have stores use the Review button.
Aug 05, 2009 | Uniden Office Equipment & Supplies
Uniden UBC72XLT scanner problem.
The cheapest solution would be to directly program the frequencies that are available in your area, usually this is public information with the exception of high security channels, you can call each location and ask them what frequency they broadcast
Jun 06, 2009 | Uniden BC72XLT Handheld Scanner
Uniden Bearcat Scanner Model# BC147XLT
The BC147XLT is too old to obtain a manual from Uniden, but here's how you program it:
Turn it on & press 'Manual', then enter the number of the channel you wish to program & press 'Manual' again. Now enter the frequency you want to put in that channel, example 155.550, and press "Enter'. Then press manual to go to the next channel or repeat the first procedure to select a different channel other than the next one. Repeat the programming procedure for each channel.
Sep 26, 2008 | Uniden BC244CLT Base Scanner
Programing
Follow this link for the owner's manual,
http://www.uniden.com.au/RESOURCES_MAIN/pdfs/UBC72XLT_for_web.pdf
See page 29 for programming instructions.
Hope this helps,
Check out my blog at http://www.pchelpforanyone.blogspot.com
Mar 26, 2008 | Uniden BC60XLT-1 Handheld Scanner
Uniden BCD396T Handheld Scanner Logo
240 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
Greg Cann
Greg Cann
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
