Question about Dell Inspiron 8200 Latitude C840 Laptop Keyboard03J247 CD-ROM Drive
Mouse moves on its own
I have a Dell Latitude C840 laptop. My mouse will start movving on its own and go to the lower left hand corner or to the upper right hand corner and not be able to be moved for a while. The mouse then becomes available to be controlled for a while and then it will do it again. I will do it with just the touchpad or even when a mouse is attached. Any suggestions?
  • Anonymous Oct 15, 2008
    Ya I have a compaq Evo N400c and it worked fine till one day it acted like it was possessed. and now every once in awhile it will be un controllable. I have an external mouse(optical) and a built in one in the middle of my laptop like a pencil eraser. when this happens the optical is useless but i can use the built in one barely. However i click on the wrong stuff at times and it sucks bad. then it will go away as fast as it started. wierd.
    Help!!!!!!! Pc problems **** cause they are like an itch you cant scratch
Its actually the blue thing that u can also controll with so just take th elue cap of and wiggle it around n it should stop
Posted on May 10, 2008
My mouse got worse and worse until it did it every time the computer was on. I took the key board off and unplugged the center mouse (blue/purple pencil eraser thing)from the connector. I had to un-clip one side of the connector to pull the mouse ribbon out. Be careful that you do not break the connector latches. Once I put it all back together and turned it on the mouse problem has not returned. Problem solved. To take the keyboard out you have to remove the screws on the bottom of the laptop. I am not sure of the exact screws. None of the panels on the back need to come off. It took me about 10 minutes to do everything. Good luck.
Posted on Sep 17, 2008
I have not torn the Dell laptop apart yet, but I think I know what causes the problem. At least in my case, the problem is a short in the wiring or on the board. I believe it is caused by my right hand resting down on the area over top the DVD drive as I use the touchpad to maneuver the mouse. As I found in one solution web site, just press briefly beside the mouse pad (in my case about 1.5 inches east) and it will eliminate the problem. It seems to be a design flaw and people have had good response from disconnecting the track mouse cable (Go to Dell for instructions). If it becomes to distracting or unusable, I will tear off the case and investigate further as to the actual physical cause.
Posted on Dec 12, 2008
    New Friend:
  • 44 Answers
My dell laptop does the same thing. I found that dell wouldn't replace my touch pad so what i typically have to do is push on the laptop around the touch pad until it starts working again. Sometimes I restart and that fixes the problem. I think there is something that is shorting out in the case and if you push around the touch pad and put pressure in and around that area it usually starts working again. This does not happen very often if it happens very often call dell support and get them to replace it esp if you can get them on the phone when the problem occurs.
Posted on Jan 21, 2008
Where do I turn off my laptop
Power button is top left corner of keyboard above the "Esc" key.
If you are trying to shutdown from Windows 8, follow these steps:
1. Mouse over the little gadget in the lower right corner of the screen. (You can also move your mouse cursor to the upper left corner; same result. Or, you can press Windows-C on your keyboard.)
2. In the slide-out menu (known as the Charms Bar) that appears, click Settings.
3. Click the Power button, and then click your desired action: Sleep, Shut down, or Update and restart.
Mar 07, 2014 | Dell Computers & Internet
Hi, I have a Dell Latitude E6400 laptop running on windows XP service pack 2. Recently, my mouse is acting weird jumping to the upper right or lower left corners of the screen and freezing there. I am able...
This problem is common in all laptops that have a pointing stick (eraser tip like) in the keyboard between G H and B buttons. It's a registry problem that cannot be fixed easily. The most economic and time effective way t solve it is to format your hard disk and reinstall your operating system.
Make sure to update your operating system before downloading any other programs or application and even before uploading your backed up files.
If this does not work for you, the problem will definitaly be a hardware issue caused by the pointing stick. Then the keyboard or the motherboard of your laptop should be replaced (I hpe your laptop is still on waranty....)
Regards
May 10, 2011 | Dell Latitude E6400 Latitude E6500...
How can I disable the mouse tapping function on my dell latitude e5400?
  1. Click Start.
  2. In the Search box type main.cpl, click main.cpl in the list of programs.
    • In Windows XP click Run, type main.cpl in the box next to Open, click OK.
  3. Click the Dell Touchpad tab.
  4. Click on the picture of the touchpad.
  5. Click Touchpad Settings.
  6. Make sure there is a check in the box to the left of TouchCheck, move the slider bar all the way to the right (this can always be adjusted back).
  7. Uncheck the box to the left of Tap to Click.
  8. Move the slider in the Touch Sensitivity area to the right until it is 3/4 of the way toward Heavy Touch.
  9. Click Apply, then click OK.
  10. Click the X in the upper-right corner to close the Dell Touchpad Utility.
Sep 23, 2010 | Dell Latitude E5400 Laptop
Cursor jumps while using touchpad.
> try to go to touchpad properties,you will be able to see there an option for tapping,you will be able to see there an option where you can turn off tapping while typing
Jun 21, 2010 | Dell Latitude C840 24X CD-R W/ DVD Combo...
Mouse pad
you would be better off using an optical mouse that has a usb or ps2 connector ( depending on what your laptop supports ) usb would be better though less chance of pins bending as there are none on a usb connection ( at least not like a ps2 connector )
Also download the latest drivers for the touchpad and make sure that the scrolling options for or on the touchpad are not configured too thickly which will be in the touch pad settings.
Apr 15, 2009 | Dell Inspiron 8200 Notebook
Dell d600 mouse pointer jumps into corners if working on documents etc.; maybe if the system stores data in the cache or ram, the cursor wether jumps into the left down corner or moves slowly in directon...
What the issue is, is the eraser head mouse in the enter of the keyboard. When you type, it's putting uneccessary pressure on it, and it makes the pointer move. The only solution I know for this is to get the updated ALPS driver for the mouse, and disable the eraserhead (The updated driver gives you an option to do this), thereby using only the touchpad mouse.
Mar 15, 2009 | Dell Latitude D600 Notebook
Dell latitude C840
try using the usb mouse then go into control panel>system>hardware>device manager. Click on the +sign next to touch pad or pointing devices and right click on touchpad, then click on uninstall. Reboot the computer, unplug the usb mouse and the touchpad should be picked up as new hardware and be re-installed.
Dec 08, 2008 | Dell Latitude C840 Notebook
Mouse not working
down load drivers from the manufacturers web sites for each individual item in use
Nov 17, 2017 | Dell Inspiron 8200 Latitude C840 Laptop...
Dell latitude 820 mouse driver
Whne you double click on the mouse in device manager, does it say "device not configured" or "unable to start this device". If it says "unable to start this device" try the mouse on a different computer to make sure it works properly. If it does then you probally have a software driver problem. Try contacting the mouse manufacturer or see if you can down load drivers from their site.
Jul 24, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
Mouse cursor moving by itself
i have latitude c610 and same problem happens with me too. i think that happens when i finish my brakfat and without cleaning my hands start using the touch pad. what happens according to me is that small particles of food(eg bread/dust particles) stuck in the corners or the body wall where the touch pad ends and keeps pressing the touchpad, thus causing the mouse to move to one direction. when i clean the corners and sides of the touchpad, it starts working ok !!
thanks
Johal
Dec 12, 2007 | Dell Latitude C610 Notebook
Computers & Internet Logo
868 people viewed this question
Alun Cox
