Question about Compaq Armada 1700 Notebook
Armada 1700 laptop
I have a armada 1700 will not boot how do i get it to boot i plug it in and the only thing that happens is the two green lights above the touch pad blink
  • mike_1990 Oct 13, 2008
    hi
    how can i detect the bios of my Compac Armada 1700 laptop?
Hi, my armada 1700 is now working.
No bios menu built-in. bios settings program runs from a floppy disk.
google search:  HP Compaq Armada 1700.  goto link of HP support site whose address starts h20000.www2.hp.com/bizsupport/TechSupport/ etc etc.
one of the links in the centre of page will take you to driver downloads.
create a new folder 'armada1700' and download all the win98 drivers to this folder.
run the .exe file that creates a bios update floppy
boot the armada 1700 with this floppy and flash the bios.
run the .exe file that creates a floppy 'compaq computer setup for portables'
boot the armada 1700 with this floppy.  disable ACPI which sometimes interferes with boot-up. (you can enable it later). In each hardware category, is an upper window showing allocated memory addresses and interrupt numbers. check if any hardware conflicts are mentioned in the lower window. Don't make big changes to IRQ or memory addresses. (only later when you are sure this is the problem.)
Once this is done, try installing Microsoft Windows. good luck. I'm still trying
I FOUND AN EASIER WAY.
download a pdf copy of
Building a Server with FreeBSD
by Bryan J. Hong
DOWNLOAD freebsd install cd #1 and correctly burn the iso image at 16x speed (not faster).
boot from the cd. let it do most thing on auto but specify your install profile 'X-user'.
that means ordinary user account + windows. the first part of the book will help a lot. the later stuff about servers is not relevant.
Posted on Sep 30, 2008
    President:
  • 4,402 Answers
Remove the battery and power from the A/C and then plug in the battery and a/c cord
Posted on Jan 21, 2008
6ya staff
SOURCE:
Compaq armada 1700-when powering the system the following error appears "Error loading operating ststem"
There is a good possibility that the hard disk drive may be failing, so if you can try running diagnostics and see if you get a failure on the hard drive.
If you can't run diagnostics, then boot to your Windows CD, press R for recovery console, then at the command prompt run the command CHKDSK /R see if you get any errors on files.
If that doesn't resolve, then boot to the windows CD press enter instead of R and repair windows.
If that still fails, then the hard drive is likely bad
Aug 20, 2011 | Compaq Armada 1700 Notebook
Have a Compac Armada 1700 laptop with Windows NT4.0 After reinstallation of NT4.0 i have only 16 colors on screen. Sombody know how to get 256 colors? Karl Hole Norway
hi
you have not install the Display drivers just go to below link and download the VGA drivers
http://www.laptopdrivers.net/video-drivers-for-compaq-armada-1700/
vote me if you find your solution
Oct 13, 2010 | Compaq Armada 1700 Notebook
Dont boot , 3 green light on no LCD didplay
try going to the BIOS setting and load the default setting......or change the boot order......than restart ur laptop.....it mite solve ur problem....
Nov 17, 2008 | Compaq Armada M700 Notebook
Help with compaq armada 1700
Sounds like your Hard Drive is gone, or you have a floppy disk in drive or cd in drive, could be a CMOS setting wrong also, but I would suspect the Hard drive is shot on a machine this old. P.S. I am running an Armada 1700 right now. Your HDD door should be on the bottom of the machine about 3"X3" with a 1"X3" lip that is hinged and has a catch on it, you need to release the catch and see if it even has a hard drive in the caddy, it will slide towards the front of the machine, slide it back towards the back it is only held in by the cover's foam and may have come dislodged. Some things to try.
Jul 14, 2008 | Compaq Armada 1700 Notebook
Please help me with my COMPAQ ARMADA 1700
plz check the hard disk cable if its ok then your hard disk may be bad.
Jun 11, 2008 | Compaq Armada 1700 Notebook
My comp doesnot boot
sounds like something was spilled on it
Mar 29, 2008 | Compaq Armada 1700 Notebook
No boot
Sounds like the motherboard is getting power to the lights but not to the rest of the computer. try to drain all the power out of the laptop by unplugging it and holding the power button for 30 seconds. Then plug it back in and try again if this does not fix it your motherboard is probably shot and would need replaced.
Jan 21, 2008 | Compaq Armada 1700 Notebook
Laptop
Most laptops will run without the batteries, its only a few that won't however I do not know for your specific laptop. So its a possibility. Although, the two lights mean that the unit has power so its likely that it doesn't need a battery and the laptop won't boot.
Do you know what the green flashing lights represent?
Jan 16, 2008 | Compaq Armada 1700 Notebook
Does not power up
its alright..usually, the total charging time of Laptops is about an hour or two. What is unique in laptops is becuase it has automatic cut-off charging feature that your laptop has the ability to turn off the charger when its already battery full no matter how many hours you've using it.
just enjoy what your doing.ok? =)
How do i turn my laptop on, so it shows the screen?
Slide the power switch 1 to turn on the computer. The
power/suspend light 2 indicates the computer is on.
see this linkl http://img206.imageshack.us/img206/7214/armadawa9.png
for your complete manual
need to install adobe acrobat reader to see the manual
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c01120750/c01120750.pdf
Dec 07, 2007 | Compaq Armada 1700 Notebook
Compaq Armada 1700 Notebook Logo
430 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
