Question about Daewoo DSJ-4710CRA 47" Rear Projection HDTV-Ready Television
Dsj4710cra The tv shuts down when I turn it on.
  • 4 more comments
  • MissRara Mar 04, 2008
    The tv turns on and immediately turns off
  • daileydee Mar 13, 2008
    When i push the main power button the stand by light comes on ok, then wheni hit the power button the green power button light comes on and in about two seconds it turns off, but the main power light stay on until i push the main power off. What is the problem?
  • jimbojetback May 14, 2008
    Turns on... but then off again! Is it my powersupply? If so where is it located, and where can I purchase one?
  • azafa28 Jul 01, 2008
    i have a daewoo 42 in rear projection hdtv, and it was working perfectly. two hours later, it would turn on, then a couple seconds later shut off again the same as previous poster. when i spoke to the daewoo people i was directed to, they told me any repair would be between 300 and 500 dollars, i don't think it is worth repairing if that's the case.
  • daved1400 Nov 09, 2008
    same problem. This is e-mail sent to Daewoo.
    We purchased a DSJ-4710CRA/5510CRA TV about two years ago from BJ'S wholesale club. TV has been fine until about a month ago. Turned TV on and it shut down after a minute.Called local TV repair people and they came out . First call they suspected the High Voltage generator. That trip was $102.55.They ordered the part from Daewoo. Part came in and was installed. TV still did not work. That call was $115.56. They took unit to their shop for further testing. Found the Deflection board was bad. Call Daewoo to order and was told part is not available. Tried a board rebuilder and no luck. This TV was built in 2004 and purchased in 2006. How am I to justify any more purchases from Daewoo that can't be repaired after two years of use. I work for a large copier manufacturer that if you purchased a copier that had to be replaced after two years I would probably never see you as a cutomer again. I'm attaching the service tickets for credibility. I would appreciate any help with this matter.
    I'll let people know if I get some answers.
  • hohrein05 Mar 25, 2009
    I have the same problem have any of you found a way to fix it yet?
I have the same problem with my daewoo 42 in hd, i am waiting to see if there is a solution
Posted on Jul 01, 2008
  • Bobo8504 Jan 02, 2012
    I too am having the same problem. Do we have a solution yet?
Power indicator light blinks-7 times. will a new power supply fix it
Physically disconnect the SU board and the SD board. (See precaution # 5)
Plug in the TV and turn it on.
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
blink 7
There is a sequence that you have to check to figure out which board is bad,
Feb 16, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
TV cuts out
Loose connections on power supply and vertical IC.Resolder
Aug 04, 2009 | Panasonic CT-32D12D 32" TV
TV shut off will not stay on.
Sounds as though you have a video problem. It may be the convergence chips. The TV is shutting down do to a default in the circuit ( the set knows there is an error of somekind so it shuts down to protect itself). This is a problem that needs a pro trouble shooter since it could be in about any board. Sorry I couldn't help more
Ed
NC Electronic
Mills, Wyoming
Jan 07, 2008 | Mitsubishi VS-55707 TV
Shuts down after power up 50ux53k bought new 1998
Refer to owners manual will tell you what blinking light means. But at the front not at the back.
Dec 16, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
My TV shutting itself down
My TV is shutting off after you turn it on.Model #27MT5005D.
The light continue to blink, but thats it.
Dec 09, 2007 | Philips Magnavox 27MS343S 27" TV
Tv shuts down
does the main board have the flyback on it? if so the yokes or CRTs can be intermittently shorting which in turn triggers your shut-down.
turning it off or unplugging just resets the shut down circuit.
Sep 04, 2007 | Samsung HL-R4266W 42" HDTV-Ready...
Blue screen of death
What you Have Is a Main RCA Failure you Have a Cathode to Grid Short In your Picture Tube,The Tube shorts and Tells the Miainboard to shut Down...Good Luck
Jul 13, 2007 | RCA TruFlat 27F520T 27" TV
TV won' turn on
Solder, solder, solder! Shut down circuits protect crts to avoid permanent damage. If any of the deflection circuits are defective, or intermittent, shut down occurs. I have not only seen bad solder on deflection circuits, especially vertical, but also intermittent connections on the yokes themselves. I've also seen shorted convergence ics cause shut down. Don't forget solder connections in the power supply.
Jul 05, 2007 | Mitsubishi WS-55807 TV
Projection TV keeps shutting down
I just took my Mitsubishi WS-65315 65" in to be repaired for the same problem and was told that it needed a new main circuit board part number 930b899005 as was told they wanted to charge me $1100.00. So I told them not to do the repair and picked up my tv and found that same part at Sears parts for only $225.00. Some of these TV repair places are theifs.
May 10, 2007 | Mitsubishi WS-48315 48" Rear Projection...
Daewoo DSJ-4710CRA 47" Rear Projection HDTV-Ready Television Logo
460 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
