Question about Fellowes 220 Powershred Strip-Cut Shredder
Shredder stops in the middle of shredding and won't shred.
When I place the paper in the shredder, after just starting, it shreds paper half way and stops and will not go anymore. Also after getting that clear, when trying to shred any amount of paper it will not sense that there is any paper trying to go in, even though it is on. What is wrong with it???
  • 2 more comments
  • Nanna Banana Jan 21, 2008
    It does this even when it is empty. It is very sad.
  • Anonymous Mar 25, 2014
    it runs fine for the first half of the paper then stops
    shreds paper but stops halfway
  • Anonymous Mar 27, 2014
    Will not allow papers to shred
I have the same problem with my shredder. I opened it up and found one of the gearwheels had teeth missing. That is why the partial shredding could not advance further. I was able to remove the part and am now hunting for a replacement.
Posted on Feb 15, 2008
Is the paper bin full?....mine always shuts down when the paper bin is a little over half full.
Posted on Jan 21, 2008
My Staples 16 sheet Microcut shredder starts the shredding operation after I push the button and continues the shredding operation after I shred a paper. How can I get the shredding mechanism to stop...
It's a tedious process to clean it out. Most auto switch shredders use either a tiny little lever or an optical sensor in the paper feed slot. Usually removing the shred head, picking all the paper out and blasting all the dust out with air will clean it up. Then run a few sheets of paper with shredder lubricant (basically clean mineral oil) to oil the blades and it should be good to go again. Just be careful cleaning that cutting head. I've donated many drops of blood to office equipment over the years.
Mar 14, 2015 | Staples Office Equipment & Supplies
When i put paper in it to shred it cuts then stops. ihave to physically hold the shred button for it to shred?
sounds like the paper in switch is either worn, or loose. Not much you can do unless you replace the switch. Look in the slot where you would place the paper and see if you see a small lever. If you do, watch it when you place paper in and get the shredder to work.
Does it happen on single sheets or multiple sheets. If just single, try multiple sheets and see if it works better.
good luck
Mar 05, 2015 | Office Equipment & Supplies
Staples Shredder SPL-S302D I think I need a new
Take a look underneath where the shredding mechanism is and remove every bit of paper. It is a messy job, but necessary. When you finish, the shredder probably will function normally. Also, ignore the advertised sheet capacity and feed one sheet at a time. Stop when the bin is half full, dump it, and repeat the bit-by-bit cleaning process. I just went thorough this exercise yesterday!
Feb 16, 2018 | Office Equipment & Supplies
The shredder doesn't automatically shred anymore. How do I set it so the "eye" works and it shreds automatically without me holding down the button?
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Sep 04, 2013 | Quartet gbc 5550X Shredder
WON'T STOP SHREDDING WHEN ON AUTO
You will probably find some shredded paper is blocking the sensor in the middle of the paper feed slot
Feb 26, 2013 | Black & Decker BD10P Shredder
Secure-Shred
Home paper shredders tend to accumulate bits of paper that have to be cleaned out from time to time. With power off, turn the shredding mechanism upside down and look for scraps or wadded up strips. Sometimes only tweezers and persistence will get rid of all.
Dec 18, 2012 | Shredder Secure Shred Shredder
I have an Ativia 6000 shredder. The red light comes on and the shredder stops, after only shredding a few papers..why?
If place too many pages in the shredder the motor will be overworked and it will overheat and shut down until it has cooled down. Try shredding fewer pages at a time.
Jul 03, 2012 | Computers & Internet
Royal 85x paper shredder: The shredder will start to shred but stops shortly after "grabbing" the paper. In order to get it shredding again, I have to put the machine in reverse, remove the...
Sometimes spraying shredder oil on the cutting teeth wil work.
You should shred paper with a light weight machine oil poured on the paper to keep the cutting teeth working freely.
Good luck.
P.S. If this doesn't work then just take the head off and cleanj/lubricate any bearings you find.
Mar 23, 2011 | Royal 85X Shredder
My shreader isabout 2 years old. While in the process of shreading 2 sheets of paper (it's rated for up to 10), the machine stopped half-way through the process. The bucket was not full. It was not...
If you look under the shredding mechanism you probably will find it jammed with bits or shreds of paper. It all has to be removed bit-by-bit. The stated 10-sheet capacity is nothing more than marketing hype. In reality, feeding sheets indivually will ensure longer shredder life.
Feb 01, 2018 | Aurora Electronics AURORA - Aurora paper...
Fellowes 220 Powershred Strip-Cut Shredder  Logo
830 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
