Question about Zenith R49W36 49" Rear Projection HDTV
Picture is bowed and color is way off
This is a 52 in r49w36 my dog ran in the set afther that color's ran and the picture bowed at bottom I tryed the convergance no help, then tryed addjusting the lens just a bit now have 3 color's of red blue and green. I just add HD and the picture was great just before this happen..
  • cookiedog88 Jul 23, 2008
    I have a very similar problem. My picture is bowed and has a red line in the bottom left.
  • Anonymous Jul 23, 2008
    I am having the same problem. Color is off and picture is bowed. Where do you find out if there is a loose connection? Convergence area? where is that at.
    President:
  • 4,402 Answers
I Would look for a loose connection around the convergence area.
Posted on Jan 21, 2008
Picture bowed & Colors separted
Conversions are out....RCA>>>>>>>>>>>>>check
fuse by the flyback transformer
May 19, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Bowed in on both sides. colored lines everywhere
Open fuse/bad connections on HV ckt board and one or two bad capacitors.
Mar 22, 2010 | RCA D52W19 52" Rear Projection Television
I need to know the parameter for configuration for a zenith tv 52 inches R49W36 ,because the colors and image are really bad thanks fredy
Sounds like a convergence problem. I had the same issue. I got a repair kit from the folks at TvRepairKits.com. Worked great for me and saved a ton of money.
Dec 31, 2009 | Zenith R49W36 49" Rear Projection HDTV
Same problem as above, picture bowed top and bottom, convergence
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 19, 2009 | RCA P52939 52" Rear Projection Television
Bowing of picture at top and bottom towards center.
*Screen Looks 3-D
*Colors wont align
bb0cf99.pngSOLUTION
Jul 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Double VIsion on Zenith R49W36
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 18, 2009 | Zenith R49W36 49" Rear Projection HDTV
Color is off....
the convergence is in the tv its self just about side of the scran if you take off the back of your tv you will see all the wires runing to little bords them are the convergence chips
Sep 12, 2008 | Zenith R49W36 49" Rear Projection HDTV
Zenith R49w36 problem
Had the same problem with my Zenith TV. Convergence was all out of whack. I purchased a repair Kit from www.TvRepairKits.com The kit had all the parts and simple step by step photos of the repair. At first the repair did not work so I emailed them and within an hour they told me to check two other items. Sure enough they were right! The set is now working perfectly. You guys rock!
I will spread the word.
Louis
May 27, 2008 | Zenith R49W36 49" Rear Projection HDTV
Rca d52w2052 d523c10df itc222
The issue is the Deflection board. The Fl1231 is open. The Deflection board needs replaced
Nov 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Zenith R49W36 49" Rear Projection HDTV Logo
157 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
