Question about Toshiba CZ27V51 27" TV
TV Tuner failure after warm up
I'm a Systems Engineer and my father has a Toshiba CZ27V51 TV that started to exhibit intermittent tuner drop outs where the tuner drops the TV signal and goes static until you wiggle the coax cable a little. Once you wiggle it, the problem goes away for few but reoccurs. It seems to be a possible failure with the tuner control card and/or board. I opened up the unit but was unable to see any damage other than a loose cable on the tube itself which was reseated. I wanted to inquire if others have seen this issue and if Toshiba has any solutions towards salvaging a some what good and decent tv.
thanks
anthony
  • anthony ryan Jan 21, 2008
    The f connector is attached to a relay (tin box) EL933L3 / 9K2678 which contains a F860 fuse. It is soldered down to the board pretty well so I think it might just be a fuse or something. I am gonna see if I can just order that box.
    Has anyone seen this type of problem with this tv?
  • 800mk2 Jun 20, 2008
    i put a new antenna but the tv is not giving a good picture i check the tunner and all the voltages arround it
  • 2,335 Answers
Check where the F connector is soldered inside the tuner circuitry, it may have a loose solder joint there. Also check the inside of the connector where the coax is attach, sometimes the inside conductors spreads and do not make good electrical contacts.
Good Luck.
Posted on Jan 21, 2008
Signal dropping out
I believe that your signal may be too strong. Have a cable tv tech to measure the signal strength as you tuner may have to adjust itself to correct the problem each time.
Nov 08, 2013 | Hisense LHDN32V66AUS 32 in. LCD TV
Quisiera saber que numero es el fly back de tv toshiba cz27v51
ustede debe abril el chasis del TV, y ver el numero del Flyback.
o ver el catalogo de repuesto. o llamar a Toshiba de USA, y tenga
el numero de parte.
Dios le bendiga.
Oct 11, 2012 | Toshiba CZ27V51 27" TV
My sony bravia digital channels always drop out of signal. Sometimes a channel has no signal for a couple of weeks. Could that be a fault with the tv?
For tuner problems, especially the digital channels, you should check for a TV firmware update at www.sonystyle.com. I was having some strange loss of digital channels on our 40" Bravia, starting with channels only appearing for a second before the screen produced a 'No Signal' message. After we tried the automatic retuning, then we could not even get the one second signal. None of this appeared on the description of the download. However, we downloaded the patch to our PC, loaded the file (19 MB) onto a small flash drive, which we then used to upgrade the firmware in the TV. All our digital tuner problems disappeared!!
Oct 16, 2009 | Sony Televison & Video
TV Picture Pops In and Out Toshiba Color TV CZ27V51
mine was doing the same thing. If i put pressure on the cable input from left or right it would fix this.
May 22, 2009 | Toshiba CZ27V51 27" TV
VIZIO LCD VX20L, intermittant video/audio with Blue screen message "No Signal"
If the tuner is bad, changing the mainboard should fix the problem.
May 18, 2009 | Vizio VX20L 20 in. LCD TV
Do Ineed a converer to receive digital tv signals ?
Your TV has an ATSC tuner and will receive over-air HDTV reception available in your area with an antenna.
Jan 27, 2009 | Toshiba CZ27V51 27" TV
Trouble with Tuner 2
From experience, I suspect that the dish has lost it's optimum "focus" on the satellites, and your signal has dropped. In your case, tuner #2 just happens to need a little more signal than tuner #1 - and that's revealing the root problem.
If you can have a second person handy, use the signal meter function and view the signal. Then one person should move the dish a bit (likely upward a hair). If the signal goes up with just the slight movement of the still tight dish, that's the problem.
If so, it's time to align the dish.
May 14, 2008 | Samsung SIRS4120R Receiver
No sound or tv signal
Probably need the TUNER either fixed or replaced.
Apr 27, 2008 | Toshiba CZ27V51 27" TV
Philips 27RF70 S125
look for any burnt capacitors in the horizontal sweep circuit. They usually cause the pincushion.
C-Dog
Feb 10, 2008 | Televison & Video
Toshiba CZ27V51 27" TV Logo
200 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
