Question about Canon PowerShot SD30 / IXUS i Zoom Digital Camera
Lens cover mechanism is broken
I have a Canon SD30 and the lens cover mechanism seems broken. The top iris does not close and when started the bottom iris stays partially open.
Any suggestions?
    Genius:
  • 2,985 Answers
It will need replacement if under warranty
A repair will be almost as expensive as buying a new camera
Posted on Jan 21, 2008
Dropped my 28 - 75 2.8 tamron lense and will not screw back on the canon 5d. Can you describe what happended?
I Have a problem qith the Tamron 28-75Aspherical Lens XR Di for Canon mount. Just make a strange sound like to power on the iris motor when you insert the lens to the camera body. I just disarmed totally it, but the problmes seems to be with the electronics parts.
If you are interested I will sell the lens to you or you can sell your broken lens to me. For contact please write to partgio @ hotmail . com or to partgio @ yahoo. com or partgio @ gmail.com
Thanks in advance, all the best
Giovanni
Mar 22, 2011 | Tamron 28-75 F2.8 XR AF Lens
A 620 canon camera iris does not open, photos seem
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 23, 2010 | Canon PowerShot A620 Digital Camera
Any advice on a sticking lens cover on the canon G7
This blog post outlines repair procedures for stuck lens covers. Recommend trying reader "Jeff's" fix first shown in the comments section.
Jan 20, 2010 | Canon PowerShot G7 Digital Camera
Shutter will not operate in bright sunlight
It is more likely that the problems is in the lens and not in the camera body.
This usually happens when the iris mechanism in the lens is not closing/opening properly. It may be a mechanical or electrical failure in the lens.
The easy way to confirm it is using other lens and test the camera. If the lens is defective, you have the options of send it to a repair center to fix it, or get another lens for your camera.
I hope this helps you to define the problem.
Best regards,
Jul 10, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon 50mm fd len;
Before opeing the lens. You cannot check the iris without setting the lens on the body. Engage the lens on to a body and check the iris opening by releasing the camera at "B" speed. While holding the shutter release, move the f/stop ring if the iris work. If not, you cost of repair by technician would run anywher from $35 to $60 so go ahead and be brave. open 4 screws from the back and start digging in. Good Luck. For further repair assitance, go to www.camerarepairjapan.com James.
Mar 26, 2009 | Nikon FG 35mm SLR Camera
Canon power shot sd30 digital glph
There is nothing for the user to here.
If the camera is lessthan one year old then returnit to vendor or contact Canon customer support for replacement.
If more than a year - simply replace the camera
Aug 26, 2008 | Canon PowerShot SD30 / IXUS i Zoom Digital...
Powershot SD30 taking blurry pics.
dust could have gotten insode making the focus lens to stick.
you might have to take it to a camera shop for a good cleaning.
dusty places are always bad for electronics.
but sounds like the focus lens is failing, there might be an option to clean the lens electroniclly, most canon has the option. not sure about sony.
good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jul 14, 2008 | Canon PowerShot SD30 / IXUS i Zoom Digital...
Canon powershot sd30 digital elph
I have same problem. I turn on the camera you hear it trying to come on, shows display pic for like 3 seconds and then shuts down. If I could get the lens to retract I am sure the camera would work.
Jun 23, 2008 | Canon PowerShot SD30 Digital Camera
Lcd panel stays black
a penlight shined into zoomed back lens - shows if iris is open ( ccd looks like a small xmas tree scene , deep in center ) : if iris is stuck closed , a thorough lens cleaning should restore camera video - if iris is open , the ccd may be or already has failed ;
Aug 14, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon powershot a510
Try this test. While turning camera off apply light pressure to the lens tube to see if there is a point where the gear engages to close the lens fully. This fault indicates broken gear teeth on the outside of the largest diameter barrel. Scrap the lens or use it for parts. A broken gear in the motor gear box will not respond to this test whatsoever. A lens that doesn't fully close, sticks up about a quarter inch and freezes on the Canon logo on power up inidicates the focus mechanism has not fully closed--perhaps a software glitch. The repair involves desoldering plastic ribbon connections and removal of the back panel to gain access to the focusing screw type motor armature to reset the small internal lens so it is flush with the back cover. This lens prevents the lens from completely closing. Reassemble and start taking pictures again.
Mar 21, 2006 | Canon PowerShot A510 Digital Camera
Canon PowerShot SD30 / IXUS i Zoom Digital Camera Logo
134 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
