Speaker errror message
I have a Yamaha DVX C300SW DVD home theatre system After hooking it all up I get a speaker err message. I have tried the trouble shooting suggestion to unhook the sub and power off, but it still happens? help??
  • Regan Long
    Regan Long Jan 23, 2008
    I tried this, and checked all wiring. I even unhooked the left and right inputs coming from the t.v. but I still get the "speaker error" message. It only goes away when I unhook the main cable from either the sub or the main unit, but the message comes back when I reattach this cable. Help.
The usual fix for "Speaker err" message is to simply unplug the sub-woofer power cord to reset the speaker diagram, plug it back in and remember to "match the negatives to negative, positives to positives" and never try to replace the original speakers with anything but equivilent speakers, adding on more speakers can cause the "Speaker err" message and an inoperative system.
Posted on Jan 15, 2011
    Genius:
  • 1,067 Answers
All the red is postive blacks in negitive on wires plug it in back off cheak wiring
Posted on Jan 21, 2008
6ya staff
SOURCE:
Yamaha DVX-S100 Theater Sound System
check your surround sound settings. Switch the speakers and test it again. if the problem persist, take it to your store and ask them to test it.
Jan 18, 2014 | Yamaha DVX-S100 System
How to hook up system to tv
The wires from the speakers usually go to a receiver/amplifier, which then connects to your TV. If you do not have a receiver/amplifier, then you will not be able to connect the speakers.
Oct 17, 2013 | Yamaha DVX-C300 System
What player will work with the dvx-s100 speakers
http://www.retrevo.com/support/Yamaha-DVX-S100-Home-Theater-Systems-manual/id/320bh037/t/2/
The note about using other speakers (Page 11) implies that the electronics and the speakers are not dependent on each other but there might be tonal changes if you mix and match. Therefore, since they use bare wires you could drive them with any common amplifer that is comfortable with 6-ohm loads.
Sep 12, 2011 | Yamaha DVX-S100 System
Where can i find a dvd/reciver for the nx-sw300 home theater system/
Here's one with a subwoofer only for $120 delivered Buy It Now. You'd have an extra sub.
http://cgi.ebay.com/Yamaha-DVX-C310SW-5-CD-DVD-Changer-Subwoofer-ONLY-/170602173289?pt=Home_Theater_in_a_Box&hash=item27b8ae9369
Other possible model numbers to search for that may eventually appear ...
DVX-C310
DVR-C310
Mar 06, 2011 | Yamaha YST-SW160 Subwoofer
IM tring to output the tv sound to my dvx-s60 *yamaha* im using a samsung led tv 42 how can i fix it?
You hook the DVD etc to the inputs on the receiver and then output from the receiver to the input on the TV.
Aug 14, 2010 | Yamaha DVXS60 System
Speaker Err on Yamaha Home Theater Unit ???
I am assuming this is the message that shows up from your receivers front display panel? It could be the receiver is telling you that you may have the neg & pos. wires crossed and in the opposite position either in back of the receiver speaker posts, or in back of the speaker terminals themselves. My Yamaha receiver has this nice feature where it will tell you when the speakers are "Out Of Phase" which describes the problem I have described here.
Just go back and make sure your wires are hooked up correctly, and use tape and a Marker to label pos. and neg so they will be easier to hook up next time you have to move the system, or decide to change some aspect of your system. I would then take the time to label every wire that goes to each speaker that you plug into the back of your receiver. This a BIG time saver........
Apr 10, 2010 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Video/dvd/cd play but no sound from speakers
Try changing "audio" setup in your TV to "variable" instead of "fixed", if you have that option on your TV set up... I have a Sony HD widescreen, and that worked for me...
Feb 16, 2008 | Audio Players & Recorders
Home theatre problems sound
Did you try to connect AUDIO OUT from your TV to AUDIO IN on your package?
Oct 04, 2007 | Sony DAV-C700 System
382 people viewed this question
Ekse
 Grubhead
Grubhead
