Question about Dryers
Trying to how to remove drum rollers on Amana ALG643RAW gas dryer!
Our dryer is making a real racket when it runs. It appears that at least one drum roller is wanged out in the center. There is a stud or bolt that it is attached by, with a slot in the head and also a snap ring. How do I remove and replace these rollers?
Fran
  • jim68 May 02, 2008
    need to remove top to get to baffles
  • 55 Answers
Ok if you go to a appliance parts shop take youe model number
and make they will give you a repalcement roller kit
snap ring hold the roller on , just replace them
Posted on Jan 21, 2008
    Genius:
  • 1,003 Answers
You have to the top off the dryer to acess this part as well as the back entire cover once you remove the top and rear panel the rest is self explanable
Amana LEA30AW makes loud racket
either a bad blower wheel or you need to change out the rollers and belt pulley
Nov 08, 2013 | Amana NDG6800AWW Gas Dryer
Stackable dryer making racket, very loud vibrating noise
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch.
Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt.
Remove the drum and belt and this will expose the drum rollers, idler arm
pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the
idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go
to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Dec 05, 2010 | LG Dryers
My Amana Dryer model # LGA60AW makes a knocking sound when drying
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please rate me,
Thank You
May 11, 2010 | Amana NDE2330AY Electric Dryer
I have an Amana NDE2330AYW dryer. It squeaks
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS If your a Handyman then this will be no problem to you. Your problem sounds like drum rollers have flat spots on them or in need of lubrication. If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Jan 04, 2010 | Amana NDE2330AY Electric Dryer
Dryer is making a terrible racket, but drys perfectly.
It depends on the noise. It could be a drum roller going bad, the idler pulley, or even something caught in the blower wheel. Can you describe the noise?
Jan 01, 2010 | Dryers
My amana dryer model is making screeching sound
Hi Peggy...
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your belt has slipped off of the idler arm pulley. If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. BE REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Dec 30, 2009 | Amana DLE330RAW Electric Dryer
Amana Gas Dryer LG3912W When dryer is turned on ignitor glows for 5-10 seoonds, then shuts off. I don't hear any opening and closing of gas valve. Is it the gas valve solenoid? Also when dryer is tumbling...
Good day,
If your sure it is getting gas, then the problem is with the gas valve. There are 2 coils mounted on top of the gas valve and they are either shorted or open. In either case they need replace.
Simple job, just remove both wire connections, then the bracket is held on with one screw. Remove the bracket, and the coils will lift right off. Very common problem.
P.S. When purchasing the dual coil kit, if the Amana seems pricey, check with the counterman and ask for the Whirlpool kit. It's identical except for the part number.
The rollers are an obvious solution. You'll have to inspect them first. The belt tensioner is another item, and in rare cases the blower wheel attached to the motor.
Dec 16, 2009 | Amana ALG331RAW Gas Dryer
Alg643raw gas dryer
try unplug and plug back in first let it reset and if that dont work, check thermal fuse may be blown..the fuse located in the back next to the fan in the housing. If fuse blown unit not work, if you go to www.appliancepartspros.com choose your model and it will give diagram of location termal fuse. check fuse first make sure is blown before you order it.
Mar 31, 2008 | Amana ALG643RB Gas Dryer
Grinding
Could be front slides that act like a bearing to support front of drum or rollor bears in rear of drum.. wheels that supposrt drum in back
These pics may help some
http://www.pcappliancerepair.com/model-display.php
Nov 03, 2007 | Amana ALG643RB Gas Dryer
Dryers Logo
366 people viewed this question
Top Dryers Experts
Marvin
Marvin
