Question about Tomtom GO 910 GPS Receiver
TomTom 910 problem
My TomTom 910 does not switch off anymore (using the on/off switch) and the touch screen doesn't work anymore. It starts up but doesn't go to the navigator menu anymore.
  • 2 more comments
  • Tommy Tom Jan 24, 2008
    This was helpful. I also had to try a few other things. The problem is solved now. Tommy Tom
  • Vaida Feb 27, 2008
    My tomtom one XL does not switch off anymore. Start screen is just frozen. I have tried to press and hold POWER button for as long as 1 min, run battery out and then start switching on again - same happens. Please help.
  • Anonymous Feb 28, 2008
    does'nt turn off and no navagation screen
  • Anonymous Apr 05, 2008
    My TOMTOM GO 910 does not switch off, not reacted on switch,screen is bleu ,not menu.
    President:
  • 4,402 Answers
Leave on charge for two hours, then with the SD card out hold down the reset button at the back of unit for ten seconds and then the 'on' switch for ten seconds.
STEP 1
Connect your TomTom to your
computer True True (``````````` (``````````` 0 95250 95250 TomTom 910 problem - clip_image002.gif via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
Copy the Yellow Folders one by one to your PC. Ideally, save all the folders under a new folder that you name.
You may find that the folder ttntools and gns may not be copied. This is o.k. if they aren't.
STEP 2
Format your Tomtom via MY Computer.
STEP 3
Copy the Yellow Folders from the
backup True True (``````````` (``````````` 0 95250 95250 you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Install the latest update onto your TomTom.
Once installed, switch your TomTom off, then disconnect if from the PC.
Thats it. From now on, make a full backup using TomTom Home prior to any updates.
Also note, that copying all the files will take some time.
Posted on Jan 21, 2008
6ya staff
SOURCE:
It is in french . how to get back to english
Hello.
Dutch sat-nav equipment maker TomTom's GO series includesthe compact, portable GO 910. The
device features a wide-screen four-inchdisplay with turn-by-turn voice instructions. The TomTom 910 sat-nav is offeredin many markets and instructions are available in numerous languages, includingGerman, Italian, Spanish and English. If your instructions are in a languageother than English, you can use this article to get started and make a journey. INSTRUCTIONS BELOW.
1 Turn on the 910 using the "on/off" button and tap on the screento answer some questions that the TomTom will ask you. After you have answeredthe questions, the GO will show the "Driving View," which appears inmonochrome until the GO finds your location. It then transitions to color.
2 Place the TomTom outside inan open space without tall trees or large buildings around you, and the TomTomwill find the location. It can take up to five minutes when starting the TomTomfor the first time. The "Driving View" appears in color when the GOhas positioned itself.
3 Tap the screen to launch themain menu and touch "Navigate to" then "Address." Choosebetween "City Center,""Postcode" and so on. Type the details onto the screen using theletter-pad. Touch "Done" when you are finished and the TomTom willcalculate the route.
4 Stay on the route by following the map on the screenand by listening to the voice prompts. The TomTom will immediately startguiding you. The "Driving View" will show the name of the next road,the next instruction and your current position in addition to otherinformation.
Thanks.
Sep 18, 2011 | GPS
GPS Status screen on tomtom 910
On the normal screen tap the time info to get summary screen.
Then tap satellites (top right) and the GPS Status page appears
Apr 05, 2010 | Tomtom GO 910 GPS Receiver
My tomtom 910 touch screen is not working it jumps about
hi try reset, go to tomtom.com go to support, search for reset, select soft reset, select your device do as the tell you. good luck.
Feb 14, 2010 | Tomtom GO 910 GPS Receiver
Tomtom 730 doesn't switch on!
Hopefully all you need to do is a soft reset. To do this use a streightened paper clip and insert it into the small round hole marked reset on the bottom of your tt. Gently press the reset button in until you feel a click. Hold the reset button in for 20 seconds. Hope this does the job.
Jun 07, 2009 | Tomtom GO 910
Seeking the repair of my tomtom Go 910
One suggestion is to plug the Tom Tom using the temporary power cord to you home circuit (not the power source from the car). That worked for me. Sometime the Tom Tom shuts down when left in the hot car requiring a reset. Then the best way is to plug in at home and restart. Try it, otherwise I can't help.
Jim
Aug 19, 2008 | Tomtom GO 910 GPS Receiver
Tomtom go 910
I have seen the green screen problem a few times before and this was caused by corrupted data / software or an error in booting up.
If you can't turn any TomTom off then perform a reset by inserting a paper clip into the rest hole and give 1 short press of the reset button ( it's a tactile switch so you should feel it click ) then try switching the TomTom on again the normal way. ( reset buttons are normally found through a small hole underneath the TomTom ).
If the TomTom does switch on but continues as before with the loading up problem , then it's best to format and reload all files from your backup copy.
A RED CROSS indicated a loading fault / corrupted files / incomplete files / corrupted or damaged media . ( media , meaning SD card or hard-drive )
Aug 05, 2008 | Tomtom GO 910
Tomtom 910
I dont think so. The unit runs on 5 volts (why I dont know!!!) so the first thing to fry on a 12v hit is the on-off switch then some of the components. Sorry
Jul 25, 2008 | Tomtom GO 910 GPS Receiver
Tomtom 910.
Complain to Tom Tom ,you may have a lemon,look for law suit soon
Mar 23, 2008 | Tomtom GO 910 GPS Receiver
Tomtom one xl
Try to reset the unit with a paperclip,
look at the bottom of the unit...
Feb 24, 2008 | Tomtom GO 910 GPS Receiver
TomTom GO 910 - screensaver?
try this it does take a while to do.
STEP 1
Connect your TomTom to your computer1.gif via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
STEP 2
STEP 3
Copy the Yellow Folders from the backup1.gif you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Dec 27, 2007 | Tomtom GO 910 GPS Receiver
Tomtom GO 910 GPS Receiver Logo
251 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
