Question about NEC ND-6500A DVD±RW Dual Layer Burner
NEC DVD+-RWND-6500A since installing itunes I can't get my dvd/cd player to read, the motor runs then stops, I have since uninstalled itunes and the the problem is still baffling
  • 55 Answers
Ok " click on start , go to programs, go to system tools, click on
system restore , restore to a date before you installed Itunes.
if that doesn't work try click on start , click on settings, click on
control panel , click on system, in menue click on hardware,
click on device manager, click on dvd/cd-rom drives, your drive
should be there , click on drive with right button.and a menu will come up ,delete it .
now shut down windows , and restart your computer
windows will now will see your new drive, and you can reinstall it.
Posted on Jan 21, 2008
6ya staff
SOURCE:
Installed XP SP3 to my Dell 6000 and now NEC 6500a can't be found. Device manager says that the drivers are loaded by cannot find the hardward Code 41
see if its recognised in the Device Manager. Start/My computer/Control Panel/System/Device manager.
if so remove or uninstall the Drive.
Physically remove/eject the drive from the Computer. reboot then shutdown. re-insert the Drive. boot computer and see if it,s detected by the system or ( found new hardware Wizard )
re-install any drivers as requested. Installing SP3 shouldn,t do this. unless the drive was actually Virused Or failing already.
Mike @ compurepair.
Oct 16, 2009 | NEC ND-6500A DVD±RW Dual Layer Burner
Cd/dvd drive device is broke
There is a reason most DVD readers, writers are so cheep is because they are warranted for 1 year. If you're NEC is less than a year old & you have a recipt you can send it back to NEC for a new one. If you need another DVD player to replace a bad DVD drive & want to buy one, I can suggest a couple.
http://www.meritline.com/sony-nec-optiarc-ad-7530b-8x-dvd-dl-slim-drive-black.html
http://www.geeks.com/details.asp?InvtId=AD-7530B&cm_mmc=GoogleProducts-_-DVDDrives/DVDBurners-_-DVDDrives(Notebook)-_-AD-7530B&zmam=2003677&zmas=1&zmac=129&zmap=AD-7530B
It would not hurt to install the firmware for you're current DVD drive. This might breath life back to the drive. (Might)! Nothing to loose. Download the firmware from this link: http://drivers.softpedia.com/get/FIRMWARE/Nec/Nec-ND-6500A-firmware-424.shtml
Good Luck!
M
Jun 08, 2008 | NEC Computers & Internet
Nec dvd rwnd 3500ag
my burner plays dvds but wont play cds
Mar 01, 2008 | NEC ND-3500A DVD±RW Dual Layer Burner
NEC ND-6500A Cant burn DVD-R
I figured out what was causing the problem with my NEC 6500A on my Dell laptop: The Sony Picture Motion Browser software that I was using to burn DVD's is only compatible up to Service Pack 2 of Windows XP. The day after I installed Service Pack 3, the software stopped burning DVD's. So I uninstalled Service Pack 3, rebooted, unistalled the Sony PMB software, rebooted and re-installed the Sony PMB software and I can now burn DVD's again. So check whether the software you're burning your DVD's with is compatible with whatever version of your operating system you're operating with. Hope this helps someone else!
Dec 16, 2007 | NEC ND-6500A DVD±RW Dual Layer Burner
NEC ND-6500A DVD±RW DON'T READ CD
I have encountered this problem numerous times and, while I'm not sure of the exact cause, the remedy that works 90% of the time for me is to create a 1:1 solution of isopropyl alcohol & distilled water and to GENTLY brush the laser with a cotton swab tipped with this solution.  Afterwards, use the other side of the swab to completely dry off the laser, ensuring that absolutely no cotton fibers are left behind.  Good luck!
Oct 30, 2007 | NEC ND-6500A DVD±RW Dual Layer Burner
NEC 6500A DVD Rw
I used to have a DVD/CDRW driver on my Sony Vaio and I had to replace it twice it died on me and I had to buy a new one every time the truth is that many things can go wrong for such small device so try this go to http://drivers.softpedia.com/get/FIRMWARE/Nec/Nec-ND-6500A-firmware-424.shtml Download the firmware, if after that it still wont work your chances are that you have to buy a new one.
Aug 21, 2007 | NEC ND-6650A DVD RW Dual Layer Burner
NEC nd 6500a
Hi, I think that it's a firmware issue. If the unit is till covered by warranty, you may have to bring it back for replacement. When doing so, it may be to your advantage to bring the PC while it is still attached and blank CDs and DVDs just to demonstrate the particular failure and likewise to be able to test if and when it would be replaced. If for some reason, you would want to try DIY, please look over these sites that you may have an idea. http://www.cdrinfo.com/forum/tm.asp?m=132275&mpage=1𠓝 http://liggydee.cdfreaks.com/page/6500/ Hope this be of some help and pls post again how things turn up. Good luck and kind regards.
Aug 04, 2007 | NEC ND-6500A DVD±RW Dual Layer Burner
Cannot read dvds
sounds like your dvd laser has failed if it reads other media as there are normaly 2 lasers one for reading cds and one for dvds try using a cleaning disc to clean the lenses
May 27, 2006 | NEC ND-6500A DVD±RW Dual Layer Burner
NEC ND-6500A DVD±RW Dual Layer Burner Logo
83 people viewed this question
Top NEC Computers & Internet Experts
Ekse
Steven Wander
Steven Wander
Thomas F. Schneider
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
