Question about Singer 7422
Singer Futura CE100 Embroidery
The top thread is balling up under material. It only does this when embroidering. Top tension is set on E & instruction manual says bottom tension was set at factory. It will start embroidering then starts tangling up. I've changed needles, needles size & material.
  • Anonymous Mar 20, 2014
    I am unable to adjust tension . Bottom thread lays flat and top tension is tight. I have tried to tighten bottom tension but it won't stay where it is set although the screw does not change
  • 397 Answers
Check to be sure machine is being threaded correctly first, then when pressure foot is lowered pull thread and see if you are getting tension, if not assembly is bad
Posted on Jan 21, 2008
Why is the fabric bunching into the bobbin when embroidering with the Singer Futura
bobbin thread is too high pressure or too low pressure on teh top adjustment!
remove bobbin and turn tension screw about 1/8turn left (anticlockwise) check if still grabbing, if so - top thread turn about 1/4 turn (at embroidery ir should do automatically, but sometimes need kick...).
check if it is still grabbing on the bottom, do it grab during straight? zigzag? double zigzag? if do not - setting on the pattern need to be look at. if it tangle as well on these three - need definitely servicing...
follow manual how to adjust.
Jan 09, 2015 | Singer Futura Xl-400 All-In-One Sewing And...
I bought the SINGER FUTURA XL400 in august. It sews,monograms an embroiders. Sews like a dream with no issues. The monogramming part has me at my wits end. It skips stiches, leaves big loops an looks bad...
Be sure to install a brand new sharp needle before sewing. Check that the needle, thread, and fabric are compatible. An embroidery needle or top stitch needle may help.
When threading the top thread, ALWAYS RAISE the presser foot before threading to insure the thread seats in the tension disk.
Apr 08, 2017 | Singer Futura Xl-400 All-In-One Sewing And...
I have used my Embroidery machine for a couple of years and have not near mastered it, My thread is too loose, then at the same time the bobbin thread is pulled through to the top. Yes the bird nest is...
When you're embroidering, ALWAYS have the tension set on "E." Unfortunately with a Singer, you will always have bobbin thread pulling thru to the top-I found this out from a technician a few years ago who also serviced Vikings and Husqvarna's. He went through a lot to show and explain it to me, but suffice it to say that with a Singer you need to use the same thread in the bobbin as on top when you're embroidering-it's simply a flaw with their machines.
The bird's nest could be a number of problems, but first we need to be sure you're setting your tension set on "E". If you are, leave me a comment back and we'll go through some specific steps to take about the bobbin. Otherwise, correct you're tension setting and see if that corrects the bird's nest problem. If not, again, leave me another comment back and leave me any details you can as to the type of material your embroidering on, the thread you're using, etc. It may seem like a pain, but you'd be surprised how fussy the littlest thing can be. I check in daily, so I'll get back to you within 24 hours. I've used my CE100 for 4 years and have mastered it quite well, so I feel confident that I'll be able to help you.
May 29, 2011 | Singer CE-100 Futura Computerized Sewing...
I have a singer Futura CE-250. I am having problems with the tension I think. While embroidering the top thread is showing completely on the underside of the material. In other words the bobbin thread...
One of the things they don't really tell you about embroidering with the singer machines is that you really do need to use the same color in both the bobbin and the top. No matter how much you adjust the tension, you will still end up with some of the thread from both showing through on the other side, unlike with most other machines.
I found this out from a Singer technician about 3 years ago when I had the same problem with my CE 150 and was going nuts! He worked with both Singers, Vikings and Huskvarna's. and saved my sanity after demonstrating a lot of technical stuff that basically showed me why Singers did this.
Save your sanity-just bite the bullet and use the same thread in the bobbin as you do in the top.
May 27, 2011 | Singer CE-100 Futura Computerized Sewing...
My bobbin thread keeps coming to the top of my fabric during embroidering on my Singer Futura CE350, I've tried bobbin embroidery thread, regular embroidery thread and clear nylon thread, I've tried...
With the embroidering, some of the bobbin thread is SUPPOSED to show on the top of your embroidery-the machine isn't doing anything incorrectly. You'll need to thread your bobbin with the same thread as you are using with the top. I had the same "problem" when I first got the machine and took it to a wonderful local technician whose helped me with a lot of things who informed me that this is perfectly normal on embroidery machines.
Oct 23, 2010 | Singer CE350
I had to replace a bobbin case because either a design ( I made) was too dense or my thread caught on something and the machine needed to be timed. When I did the test stitching in sew mode it stitched...
Being simple minded as i am, if your singer ce100 works the stitch looks good just be glad you are not having the problems so many are, if you want to see bobbin thread on bottom tighten top tension
Sep 23, 2009 | Singer CE-100 Futura Computerized Sewing...
Top thread will not pick up bobbin thread makes a big loopy mess
This is sometimes caused by the upper thread not threaded correctly. You need to thread it first with the pressure foot in the up position. You need to "floss" the thread into the clear plastic guide as this is where the tension is. The tension should be set to E for embroidering. Also make sure you get the bobbin thread in the slot on the bobbin case. Also, lower your pressure foot before you begin embroidering. Hope this helps!
Sep 20, 2009 | Singer CE-100 Futura Computerized Sewing...
Thread Mess!
The symtoms you describe are typical to insufficient top tension.
First check the dension dial is on S for normal sewing and E for embroidery. If this is the case, re thread your machine with the pressure foot up and make sure the thread goes over the take up lever.
Dec 10, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer 7422 Logo
181 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
