Question about Acer Aspire 3610 Notebook
I HAVE A LAPTOP THAT WILL NOT TURN ON , WHEN A TAKE OUT THE BATTERY AND PUT THE AC ADAPTOR IT MAKES SOME NOISE THEN IS TOP WITH THE BATTERY ON THE LAPTOP THE LAPTOP WILL NOT TURN ON , THE ORANGE LIGHT BLEEPS FOR AC CURRENT BUT I HAVE CHECK AND THE AC ADAPTOR WORKS FINE .
    President:
  • 4,402 Answers
Remove everything possible from the unit, including ram and try it again.
Posted on Jan 21, 2008
Battery was running out on my Acer mini book, hibernated and turned of, tried to turn it on nothing happened., used ac adaptor....still nothing
take battery out, unplug ac adapter. Wait one minute. leave battery out. Plug in ac adapter and turn on laptop. Once it turns back on. Shut down laptop and put battery back in. Now you should be able to turn laptop on with or without battery.
Nov 08, 2009 | Acer Aspire One AOA150-1635 Notebook
My laptop will not turn on
Do you have a light on the power supply when you plug it in the computer?Remove the battery the power plus the memory .Press and hold the power button for twenty seconds.This will reset the computer and hopfully turn it on when you replace the parts you remove.
good luck
Sep 15, 2009 | Computers & Internet
Does not start; no power indicator light
Take out the battery and then try the different ac adaptors. If you still get no lights on the laptop then the motherboard is bad and would need to be replaced. Just make sure that you know at least one of your ac adaptors are good.
If the adaptors have lights and they turn on then you know the ac adaptor your working with is good. Also make sure they are plugged into a good working outlet.
May 29, 2009 | HP Pavilion ze2000 Notebook
I have a Dell D600 (PP05L), its not powering up no lights. I noticed on the power adapter the green light goes out when plugged into ac power. What could be wrong here? please help
Hook up your power adaptor to ac power without it being hooked up to the laptop and see if the green light stays on. If it does then you know your adaptor is okay. if your adaptor is only hooked up to ac power and the green light still turns off then you know your ac adaptor is bad.
Take out the battery from your laptop. Now hook up the ac adaptor to the laptop and if it stays green then you know your battery is bad but you also want to make sure you can get your laptop to turn on. Hopefully it will turn on with only the ac adaptor hooked up to it.
May 04, 2009 | Dell Latitude D600 Notebook
Laptop is nmot working
hi,
welcome to fixya,
as u said that ur laptop is not working and it is not booting,i mean is it a dark screen or do u see the lights on the computer,can u clarify me pls...u can try and safe mode and if it doesnt load in safe mode then what u can do is that disconnect the ac adaptor and take out the battery and then without ac adaptor and the battery press and hold down the power button for one minute and then release the power button and then connect the power cord and put the battery back in and then turn on the computer,and if still it doesnt turn on then try and connect with the different wall outlet and if still doesnt turn on then try with the different ac adaptor and still if it doesnt work then replace the motherboard and the ac adaptor.
Feb 19, 2009 | Toshiba Satellite A100-S8111TD Notebook
Can't get laptop to turn on. Battery pack lights show full charge, power cord is plugged in. No indicator lights illuminating at all, wondering if it is my motherboard. Compaq Presario 2200 laptop.
very first thing u have do is if u have any other laptop try and connect the aac adaptor with that laptop and also try the battery if it is working with the other laptop that means the motherboard of the computer has gone bad u need to replace it and what also u can try is disconnect the ac adaptor and take out the battery from the laptop and the without ac adaptor and the battery press and hold down the power button for one minute and then connect the ac adaptor and put the battery back in and then try and turn on the computer and also what u can do is shut down the computer first and then just hit the power butoon once only to turn it on and then keep tapping f8 key on the keyboard and it will take u to windows advance options and select safe mode with networking and then try if it turns on to the windows screen or not......and if it doesnt turn ono then definately replace the motherboard...good luck....
Jan 23, 2009 | HP Compaq Presario 2200 Notebook
Laptop won't turn on
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
Jul 11, 2008 | Dell Inspiron 5160 Notebook
It won't turn on,
change the other battery work's if the work then you battery work goes
Jun 13, 2008 | HP Computers & Internet
Lap top problem
Hi
If the AC power light is blinking, try the following steps:
1 Cut off power to the computer by disconnecting the AC adaptor and removing the battery. The error condition will be interrupted, and the AC power light will stop flashing.
2 Put the battery back into the computer. Do not connect the AC adaptor. Try turning the computer on again. If the computer starts normally, the AC adaptor may be
defective and will need to be replaced. If the AC power light starts flashing, remove the battery, and continue with the steps below.
3 Connect the AC adaptor to the computer. Leave the battery out of the computer. Try turning the computer on again. If the computer starts normally, the battery may need charging, may be depleted, or may be defective. Turn the computer on, insert the battery, and then leave the computer running for several hours, which will deliver a slow, steady “trickle-charge” to the battery. Once the battery has been trickle-charged, it may begin working correctly again. If the trickle-charging does not prove effective, consider replacing the battery with a new one.
4 Connect the AC adaptor to a different power outlet, preferably in a different room. If the computer starts normally, there may be a problem with the AC outlet itself, or the voltage level available from it.
5 Verify that the AC adaptor is the correct unit for your computer model. The computer may not be able to start from an AC adaptor that is rated for less current (amperage) than the computer requires, even if the rated voltage is correct, and the plug fits correctly in the DC-IN socket. The labels on the bottom of the computer and the AC adaptor show the specifications for voltage ("V") and current ("A") for each device. The voltage level must match exactly. The amperage rating of the AC adaptor must be equal to or greater than that required by the computer
Regards
Mike
Mar 21, 2008 | Toshiba Satellite 1805-S204 Notebook
NOT TURNING ON LATOP ACER ASPIRE 1410
ya im having the same problem. please help!
Jan 20, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 3610 Notebook Logo
70 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
