Question about Plantronics CS70 Wireless Headset
Headset static Well i just got my headset for Christmas, and it already has static.. This has happened to all of my headsets in the first few months.. I think the wiring is coming lose or something, because all i have to do is push in the cord to make the static stop for a min. or two.. Well thanks for your time hope to hear back soon.
Can you explain in more detail? I am not understanding what you mean by "the cord". We are talking about the Plantronics CS70 Wireless Office Headset System correct?
If we are talking about the same system, was it new when you got/bought it? If it was new try contacting Plantronics (yes, I do know it's August now but you can still try) to get it exchanged/repaired under warranty. That being said, I am not sure how long the warranty is or if you even have a receipt. If you don't have a receipt but know that it was purchased at Best Buy, Circuit City or another electronics store that keeps the receipts then get all the information together (date of purchase, purchasers name & phone number, etc) and visit the store to see if they can give you a copy of the receipt to forward to Plantronics.
I used to work at a Best Buy (Store 817 in Paducah, KY) on the Geek Squad. I have helped customers find their receipt and also have seen the Customer Service Reps in the store find the receipt if I can't. They have access to more information on you/your purchase than you could ever imagine and it will be extremely helpful in this quest.
I know I typed an essay but I hope it helps you resolve your issues.
Thanks,
NkryptD
Posted on Aug 14, 2008
How do I change language with motorola hk250 headset from italian to english
Turn off the headset. Then hold down the call button and turn the headset on again. The voice interface will ask if you want to continue in a number of different languages. When they ask if you want to continue in the language you want, press the call button again to select that language.
Jan 06, 2013 | Motorola Mobility HK250 Universal...
Mototola wireless headset H550 OWERS MANUAL NEEDED
You can download the manual in PDF format by clicking this link:
http://static.compusa.com/pdf/Motorola-H550-Manual.pdf
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Aug 10, 2010 | Motorola Mobility H550 - Bluetooth Headset...
When ever im playing and using the mic after a while what happens is that everyone goes like "AHHHH STATIC DUDE!" so after i use it for like 2-5 min it turns static unless i replug it then it goes back to...
Get a smidge of moly grease and rub in on your mic plug, then insert it into the jack. All static will be all gone. Insert and remove a few times if you have to, until the static stops.
Mar 21, 2010 | Genius HS-03U Headset
Static in headset
Here is an even simpler solution that works almost 99% of the time, do a system reset:
1. Take the headset off the charging cradle.  Make sure that the headset is not turned on (i.e. the green light on the base is not on) 2. Hold the mute button and the call answer button down at the same time.  (The mute button is the little black wheel on the top of the headset.  Push it straight in with the tip of your finger). 3. Hold these both down until you see the green light on the headset blinking a few times.  After 2 sets of blinks release. 4.  Put the headset back on to the charging cradle, wait 30 seconds, pick it up and try it now.  It should work.
May 15, 2009 | Plantronics CS-50 Professional Headset
Headset has static
Perform a reset on the headset.  Hold down the mute button (the dial on the back of the headset needs to be pushed straight in), and at the same time hold down the call answer button until you see the green light on the headset blink a few times.  Release both the mute button and the call answer button.  See if it works now.  If it doesn't, try a re-subscription (should be available in the manual).
Oct 24, 2008 | Plantronics CS70 Wireless Headset
My jabra bt250 headset wont turn on
check my post on solution 4 on this link, my headset still working 1 month after i boosted it.
http://www.fixya.com/support/t190081-jabra_bt250v_indicator_light_doesnt
Aug 14, 2008 | Jabra BT250 Consumer Headset
Static h700
Good Afternoon.
Has the headset been dropped, or kept in a hot car? The battery could also be going out too, but unlikely if its only 3 months old. Is the headset near the phone? They do have a 10-20 ft range in a perfect condition. But it works best in my tests only a few feet away. As I roam away from the device, it causes static.
Also, is this everywhere you go, or just certain areas?
The reason I ask, if you are near a Wireless network, it could be conflicting. Bluetooth communicates on a 2.4 ghz band. Wireless Network runs on the following: 2.4, 3.6 and 5 GHz frequency
Try removing the device from you phone, and re-connecting it.
Apr 12, 2008 | Motorola Mobility H700 Wireless Headset
Motorola HS850-
almost all of moto bluetooth headset get this problem. i think H680 is much better that HS850 or H700. i'm using RAZR2 V8 and almost all BT headset have static problem. So i end up with korean's and french's BT headset which have much lower static.
Dec 05, 2007 | Motorola Mobility HS850 Consumer Headset
Plantronics CS70 Wireless Headset Logo
424 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
