Question about Philips 20PT6441 20" TV
Philips 27p6441/37 has a foldover
Tv plays well, but has picture folded over at top of screen. Any help would br greatly appreciated Thanks Jellybean1
  • Jellybeanpb Jan 30, 2008
    the info was very helpful and timely Thanks again will recomend this site to others..
    Genius:
  • 1,694 Answers
Bad capacitor / IC in vertical circuit...usually a shop repair...
If not corrected,could get worse in short period of time,.....T.
This model also requires an upgrade kit for future reliability...
Philips part number 483531057673 senior tech only.......
Posted on Jan 27, 2008
  • angelarho905 Feb 14, 2012
    MY TELEVISION HAS A CHANNEL ISSUE I HAVE A DIGITAL CONVERTER BOX HOOK TO MY TV BUT IT ONLY WORKS ON A CHANNEL THT SAYS AV WHICH WILL COME UP ON THE TV IT'S STUCK ON A CHANNEL THT SAYS SVHS I'VE TRIED TO REMOVE IT BUT IT'S NOT WORKN WAT CAN I DO TO FIX IT
6ya staff
SOURCE:
A black line (about 2 inches wide) appears at the top of the screen with this amount of the picture looking like it is folded down translucently over the remaining picture. What's up?
Hello
Your TV has vertical fold problem. Just check all the electrolytic capacitors. On checking, most of them may look good. But on circuit, when energised, will show problems. So it is best to replace all of them once and check. Please check the electrolytic capacitor connected to the vertical power supply [usually comes from the secondary supply section of the Line Output Transformer], first, and replce it. It may be a 1500Mfd or 2200mfd. Check it first by replacing a new one. In most foldover cases, this service will solve the problem. [email protected]
Oct 18, 2010 | Philips Televison & Video
Lines at top of screen, about 4"
Hi:
This is due to vertical deflecton problem, there is some capacitors that has gone bad and need replacing. It might just be one cap rated at 100uf 35 volts. This is called vertical foldover eventually the top will fold over or you will get a 4" black border on the top of the scrn.
Aug 23, 2010 | Toshiba 27A33 27" TV
Phillips tv picture folds down from the top, as if
It sounds like a defective capacitor in the deflection circuit. Check all of the high voltage caps.
Aug 09, 2009 | Philips Televison & Video
Image compresses to the middle of the screen after 20 minutes
This TV have problem in Vertical section, probably the capacitor or cold solder. by replacing the dried capacitor and resoldering the component will help to solve the problem.
Jun 01, 2009 | Sylvania 6432GG 32" TV
Vertical problem
sound like a bad capastor. This is called foldover. Could be the main ones in the power supply dont know for sure but that is whare i woul start. If youdont know how to fix then take to a shop for repair.
Mar 05, 2009 | Toshiba 24AF44 24" TV
Folddover at top of picture about an inch from top
Replace cap. 2465 and cap. 2561. That should take care of it unless the vertical transistors are bad or there are other bad caps.
Oct 27, 2008 | Philips Magnavox 27MS343S 27" TV
Wide black area top of the screen.
More than likely it's not the crt. If the picture has "foldover" at the top of where the picture is currently, then more than likely there are bad caps. in the vertical scan circuit. If not, the vertical sizing probably just needs to be adjusted. You will have to get in to the service menu to do that.
May 26, 2008 | Philips Magnavox 27MT5405 TV
Philips magnavox 32" TS3260C1
Sounds like retrace lines. Leaky caps or worse can cause this.. Are you getting any vertical foldover at the top of the screen?
Jan 18, 2008 | Philips Magnavox 27MS343S 27" TV
DS25390 Verticle foldover
If you have a picture but the top is folded over, your vertical IC is probably good and you need to replace the pump-up capacitor next to the IC. When the pump-up cap (typically a 47 or 100uF 35V cap) is open then the picture will have white lines and foldover at the top. The typical vertical output IC is the LA7838, but I am not familiar with exactly which output IC your set uses.
Jul 02, 2007 | Sanyo DS25390 TV
Philips 20PT6441 20" TV Logo
209 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
