Question about KitchenAid KGRC707 Gas Kitchen Range
Oven not working
I have a Kitchenaid gas range, 2 years old, and the oven will not work. It has a dual gas valve and the ignitor will not turn on. I'm suspisious that something may have knocked loose on the dual gas valve, since the problem happend shortly after the storage drawer was overloaded and closed. At that time both the broiler and bake function didn't work. After I disconnected and reconnected the leads to the gas valve the broil unit worked again. Still no luck with the bake function. Any suggestions?
Thanks,
Blair
  • 375 Answers
Check continuity on gas valve. the middle connector is common, upper is broil and bottom is bake. Resistance between common and bake should be about the same as between common and broil. I believe you'll need to set the ohmmeter to KOhms (or x1000.
If no continuity between any of the connectors - replace gas valve (not much fun, and part is expensive).
Posted on Jul 15, 2010
Gas oven does not start
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 16, 2011 | KitchenAid KDRS807SSS Dual Fuel (Electric...
Gas in oven not turning turning on, only electric works and oven does not heat to required temp. Gas on burners works.
heatman101
Oct 10, 2010 | KitchenAid KGST307 Gas Kitchen Range
Gas broiler works, but the regular oven works intermittently, can you explain how this can happen.
The ignitor for the oven could be going bad and causing the oven valve to open intermittently. I see this often. Or the oven valve could be going bad... but the usual suspect is the ignitor.
Tom
Aug 10, 2010 | KitchenAid KGRT607 Gas Kitchen Range
GE profile JGSP44 Oven stopped working
Ignitor needs to be working for the gas valve to open. If the ignitor does not reach the proper amp draw the gas valve will not open. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru performing an amp draw test on the ignitor.
Mar 28, 2010 | GE Profile JGSP44 Dual Fuel (Electric and...
Kitchenaid gas oven very slow to start - can be 5 - 10 minutes before I hear it kick on. For a while I could get it to start by turning on a gas burner, but that is 100% effective. Any suggestions? Also...
Replace your ignitor, this is a very common problem. As the ignitor gets older, it gets weaker. When it gets weaker, it usually starts out by not giving good temps in the oven, then it starts to take longer and longer before it lights the oven burner, then it stops lighting the burner completely. A good ignitor heats up fast, allows the current to flow through to the gas valve, opens the gas valve and lights the oven burner within 30 to 50 seconds. When you order your ignitor ask if their is a cheaper generic ignitor for this model. Their can be a huge price difference in some units. You can also have a bad sensor, control board, gas valve, or wiring problem, however for the last 15 or so years every job I have done with your problem has been an ignitor. Good Luck, Appliance Specialists
Jan 26, 2010 | KitchenAid KESC307 Electric Kitchen Range
Kitchenaid gas range model# ykgsc308lso oven
If it takes more than 2 minutes to light then that ignitor is weak. It should be very bright. It has to draw 3.5 amps to open the valve. The valve is good because the ignitor is working the oven control is good, all it can be is a weak ignitor. It should draw 3.5 amps or have measure 37 ohms.
Jan 14, 2010 | Ovens
Hi,I have a kitchenaid gas stove and the oven does notwant to heat up. I have it on now for 20min,just barely warm.Any suggestions?
Most likely a bad glow bar ignitor at the oven valve. It must read 3 amps or more to activate the gas valve. Turn the gas off,put a clamp on amp meter on the ignitor wire and turn the oven on. If it reads less than 3 amps,replace the ignitor.
Sep 30, 2009 | KitchenAid KGRA806PSS Gas Kitchen Range
Gas over not lighting
It is likely that the ignitor needs to be replaced. If the range does not sense the proper amount of resistance in the ignitor, it will not turn on the gas valve for the lower burner. If the broiler is still working, it would further this thinking, as it has a separate ignitor.
Sep 14, 2009 | KitchenAid KGRT607 Gas Kitchen Range
KitchenAid KGRT607 - Oven won't light reliably, can smell gas.
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 29, 2009 | KitchenAid KGRT607 Gas Kitchen Range
No Gas in the Oven
You probably have a bad ignitor. If the ignitor does not function correctly the gas valve will not open. Check ignitor by measuring the amps that it draws - It should draw about 3.5 amps.
Nov 16, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
KitchenAid KGRC707 Gas Kitchen Range Logo
197 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
