Question about Samsung Digimax D53 Digital Camera
300 dpi how do I change the resolution on my camera? I have set the camera to the highest res but all the pictures still say it is only 72 dpi?????
    Problem Solver:
  • 5 Answers
I am not positive if this is what you are looking for, but if you use the menu button on bottom right corner of back of camera you can change the settings for the picture resolution and the fineness of the stored images. If you set this and it still will not take the change, suggest removing the memory card and then turn camera on, use menu button and the go to reset and tell it yes. Then set all the settings the way you want and try it. Dont forget to set the time and date after resetting camera.
Posted on Apr 06, 2008
My pictures are only 72 DPI. How can I change the resolution to higher quality?
The dots per inch setting (DPI) is meaningful only when printing the picture. As such, the camera simply fills in a default value of 72. You can change it in Photoshop or any other photo editing program. The resolution setting on the camera only changes the number of pixels in the picture, not how you print it.
Feb 16, 2012 | Casio Exilim EX-S12 Digital Camera
Change 72 dpi to 300 dpi
Your camera cannont shoot at either 72 dpi or 300 dpi. It shoots at whatever resolution you have it set for. Dpi (dots per inch) is a print specification, denoting how large (or small) your pictures are printed.
The DSC-W100's highest resolution is 3264x2448. Printed at 72 dpi, it can generate a print bigger than 40x30 inches, albeit a bit grainy. Printed at 300 dpi, you can generate 10x8 inch prints.
Again, dpi is a measure of how you print pictures. It has no bearing on how you capture images with your camera.
Mar 15, 2010 | Sony Cyber-shot DSC-W100 Digital Camera
Want Increase resolution from 72dpi to 200 dpi
increase in dpi will not increase the resolution. dpi = dots per inch for example you have a res of 1024x768 at 72dpi you get a printed image of 14.2x10.6 inch at 300dpi you get a printed image of 3.4x2.5 inch
only thing possible is to interpolate the image. but thats **** in my opinion.
Jul 23, 2009 | Fuji Finepix S5800 Digital Camera
Photo resolution
Sony H1 takes photos at 72 dpi by default. But the picture quality will be good. if you want to convert it to 300dpi open the picture in adobe Photoshop and select image size and change resolution to 300 dpi. but the file size will be very high to up load. if you want to reduce the file size select the image size in adobe photoshop and reduce it according to your requirement. if my solution proves good please rate it. Regards.
Feb 04, 2009 | Sony Cyber-Shot DSC-H1 Digital Camera
Resolution
Many cameras will take pictures at only 72 dpi. Changing the resolution causes the camera to change the size of the picture in terms of pixel dimension (ie 800x600 vs 640x480) but always at 72 dots per inch. A photo editing program like Photoshop can change the resolution to whatever you need.
Dec 13, 2007 | Samsung Digimax 4010 Digital Camera
CHANGE DPI
Yes, every picture has a resolution of 72 ppi. This can be changed later in an image editing program on the computer.
Nov 25, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
DPI resolution
menu- camera set up- picture quality- try to locate picture size using menu button switch. RAW file is the best but it eats too much memory.
Sep 07, 2007 | Canon Digital Rebel XT / EOS 350D Body...
Minolta Dimage S414 Problem with resulution
What you are seeing is the difference between "pixel count resolution" and "embedded resolution". So in your example 2272*1704 is the actual pixel count resolution as recorded by the camera & 72 is the embedded resolution that tells the software (in this case photoshop) what the intended use of the picture will be. 72 ppi is the default for web pictures. You can change this in photoshop by going to the "Image" tab & select image size. The window that opens will show you the pixel dimensions i.e. pixel count resolution and the document size & resolution 72. You just change it to 300 for printing. You can change the default to 300 by going "edit", "preferences", "units & rulers" and setting the values for "new document preset resolutions". This is a complex subject, I recommend looking at the following web page: http://www.fotofinish.com/resources/centers/photo/resolution.htm
Aug 08, 2007 | Konica Minolta DiMAGE S414 Digital Camera
Higher res pics on OPtio S4
This resolution doesn't matter to most software. It doesn't change the image at all, just occasionally the size it is displayed (only if the software scales the image according to the resolution, which most don't). This having been said, I doubt there is a way to change it in camera. But you could certainly change the XResolution and YResolution meta information with any good EXIF editor. Also, Photoshop can do this too, but it will mess up other things in the meta information. You should be able to script either to apply this change to a number of photos at once.
Aug 30, 2005 | Pentax Optio S4 Digital Camera
Samsung Digimax D53 Digital Camera Logo
105 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
