Question about HP OfficeJet 6210 All-In-One InkJet Printer
Printer Problem I have a HP 6210 copier/printer/fax/coffee maker, The readout comes up "carriage jam". I did figure out the carriage hangs up on the last pass back to rest after each cleaning cycle. I can manually move it past the stoppage, but it's a pain after each sheet it prints. I can't quite see what is holding it up. Everything thing else works fine. Thanks for any help, Bob
Will not install because of problem with print spooler
Posted on Feb 27, 2008
Carriage jam- open door clear carriage jam and then press ok
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t6088190-hp_7400_displays
Sep 18, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Printer reads out "Carriage Jam". Have done all the usual stuff.... shut down,unplugged, cleaned around connections and still reads out "carriage jam". Makes a lot of noise after opening carriage and...
hi
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hp Cartridge issue
Complete the steps below in the order presented to resolve the problem. It might not be necessary to complete all of the steps.
Step one: Reset the printer
  1. Without turning the power off, remove the power cord from the back of the printer and from the wall socket.
  2. Wait 30 seconds and reconnect the power cord to the printer and to the wall socket. Turn the unit on if it is not already turned on.
  3. Check the printer for the error message. If the error message still displays, go to the next step.
Step two: Clean the cartridge contacts
Figure 1: Lifting the top cover
Lift the top cover.
  1. Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch, then lift the latch.
Figure 2: Unlatching cartridge
1 - Black cartridge
2 - Color cartridges
  1. Remove the cartridge indicated in the error message.
Figure 3: Removing cartridge
Gather cleaning materials:
    • Distilled, filtered, or bottled water (do not use tap water or alcohol or platen cleaners)
    • Lint-free cloth or swab. Eyeglass wipes and coffee filters work well.
  1. Lightly moisten the swab and squeeze out excess moisture.
  2. Holding the cartridge by its handle, wipe the copper contacts.
Figure 4: Wiping the contacts
1 - Copper contacts
  1. Replace the cartridge, then close the latch and the printer top cover.
Jul 29, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Carriage jam
change the carrage block.this error is comin because of faulty carrage cable
Aug 08, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Carriage jam
Please follow the steps mentioned in this link below:
HP Officejet 6210: Carriage Jam
Jul 14, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Carriage jam messsage
Jun 20, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Hp officejet all-in-one 6210
printer jerking and message says carriage jam and everything is clear, but paper goes in sideways.
Oct 13, 2008 | HP Photosmart C4180 All-In-One InkJet...
Paper jam on HP 6210 fax
opens from the back of printer be gentle its called a clean out
http://h10032.www1.hp.com/ctg/Manual/c00238458.pdf
click the link goto trouble shoot paper jam
May 04, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
70 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
