No hot water, blinking "12" yesterday. Where should I start
  • Cwindle Jan 23, 2008
    Rinnai Continuum Model 2532
  • Cwindle Jan 24, 2008
    Thank you very much!
  • 1,420 Answers
Start by provding us with a Make and Model number.
Posted on Jan 23, 2008
  • Chandler Ede
    Chandler Ede Jan 23, 2008
    code 12 is a flame failure. Remove the front cover and watch the unit as it cycles. Look to see if the burner starts then quickly goes out. This could be caused by lack of gas, blocked vent, not enough combustion air, moisture on the igniter, blockage in the burner or the flame rod sensor is dirty or defective. Troubleshooting this unit can be complex and I recommend a proffessional look at it.
Yesterday the hot water went cold after 2 minutes into a shower.I checkAQed the hot water unit and noticed it seems to be damp around the base.it's an Aquamax 315 twin element electric hot water heate
Electric hot water heaters are particular to water levels and air pockets. Air pockets (low water levels) can cause the upper element to fail thereby reducing the overall recovery of hot water. Also if this is supplied by a well the incoming water temperature is lower than city water and also maybe adding to your problem. First thing I would check is the upper element. Start there and re-post with updates..
Sep 30, 2014 | Water Heaters
Uline under the counter icemaker not making ice. Fed from RO water and had filters replaced to help but didnt. All is running fine, but not making ice. Dups one tray every 12 hours then stops
Is the condenser fan running? Is the condenser clean? (condenser is the "radiator like" coil outside of the ice box. It cools the hot refrigerant.
Sep 07, 2012 | U-Line Icemaker
The clean light is blinking and beeping. There is less than 2 cups of Vingegar still in the water reserve.
Sounds likea serious PIECE. Try running it on the regular mode with vinegar, or you could even use hot water.
Jan 22, 2011 | Mr. Coffee 072179228578 12 Cup Coffee...
Tefal quick cup
Press the Hot and Cold button for 3 seconds,
The red indicator light will start to blink,
Release the hot and cold buttons and while the red is still blinking, press the and hold the hold water button, Once the desired amount of hot water is reached release the hot water button.
Now press and hold the hot and cold water buttons simultaneously for about 3 seconds.
The red light will stop blinking to the end of the programming.
NB the RED LIGHT WILL BLINK FOR THE DURATION OF THE PROGRAMMING.
Repeat the process for the cup quanity selector for the cold water.
------------------------------------The end -------------------------------------------
Feb 28, 2009 | Tefal Kitchen Appliances - Others
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
