Question about Whirlpool LSB6300PW Top Load Washer
Agitate my machine, 5 years old, won't agitate. I washed clothes earlier and it worked find, now, 2nd load it won't work. I got it to drain on a different cycle, delicate area. If it matters, the softner area keeps clogging up.
  • mjmcc Jan 21, 2008
    thanks for replying, I went with the online chat and found out I have a broken motor coupler. tech17 was great.
  • mjmcc Jan 23, 2008
    I got the part today, everything is working fine. Tech17, thanks again for your help. $25 part and $20 chat beats a $100+ service call. Keep up the great service.
  • 770 Answers
Does the unit Spin?? or just pump out the water ??? i am trying to see if you need a $10 part or a $150 part plz post
Posted on Jan 21, 2008
  • Gary Davd
    Gary Davd Jan 21, 2008
    ok that was the 10$ part i thought you needed
Model 23832100
Sounds like clutch not catching,this may need to bed in .The fact it works okay with no load and no spin with load sounds like clutch/ but also could be motor torque.Ask repair man to recheck work done.
Jan 14, 2014 | Kenmore 24032\24036 Top Load Washer
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Asko 620 washer won't drain well with heavy load
Washing machine won't drain
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Overloading your washing machine can cause items to be swept into the space between the inner and outer tub, leading to clogs in the drain hose or pump. These clogs may be the reason for why your washing machine won't drain. Here are some steps to help you determine the problem and solution:
1. Pinched hose: Is the drain hose at the back of the washer been flattened or twisted in any area? A pinched hose could prevent the water from draining thoroughly. Gently straighten the hose, and make sure there is sufficient room between the back of the washing machine and the wall to prevent a repeat of the problem.
2. Clogged drain hose or pump:
Does the drum spin normally, but the washing machine won't drain the water? Sometimes a piece of clothing, money, fabric or other debris gets into the water between the inner and outer tub. It may then make its way into a drain hose or even into the pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. Call a repair professional for help.
3. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
4. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
5. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
6. Pump failure: Is your washing machine more than 7 years old? Your pump may simply have worn out. Even if it sounds as though it is running, the pump may not be working well enough to draw the water out of the machine. Replacement parts for pumps are generally unavailable. A new pump may be necessary.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Asko W6021 Front Load Washer
I have a roper washer 5 years old and it won't drain or turn on now it was working fine yesterday ive unplugged replugged pulled out all the clothes checked power supply and hoses what now?
I looked up your model number. You particular machine allows for wash with the lid open. You nothing happens. On that case I would check the motor capacitor.
Nov 13, 2011 | Roper RAS8445KQ Top Load Washer
My GE top load washer is about 5 months old. It fills up and runs through the agitation cycle but then stops at the end spin cycle. The clothes just sit in the water. I checked the hose for kinks and...
I have had this problem with two of my previous washers a top loader and front loader.Each time it was a faulty pump that drains the water from the tub after the wash cycle is complete. If the water does not drain from the tub the machine will not go to the spin cycle. Both of my washers were 5 or 6 years old when this occurred. If the washer is only 5 months old it should be under the manufactures warranty. Good Luck.
Nov 12, 2010 | General Electric WBB2090G Top Load Washer
Kenmore Washing Machine won't agitate, spin, or drain
It sounds like the motor needs to be replaced, you can drain the water by taking the drain hose from the drain and lowering down water will drain.
Jun 01, 2009 | Kenmore 24032\24036 Top Load Washer
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
Roper washer will not agitate
could be the transmission or the drive motor to transmission coupling. You say the agitator doesn't work but it washes fine please clarify your problem.
Jan 12, 2009 | Roper RAS8445KQ Top Load Washer
Rooper washing machine- unbalanced spin - rocking agitator
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
Jan 03, 2009 | Roper RAS6233KQ Top Load Washer
Washing Machines Logo
115 people viewed this question
Dan Webster
Dan Webster
Sal De
