Question about Sewing Machines
Janome M100 mini sewing machine
Hi i was wondering if you could help, i have a Janome M100 mini sewing machine and the bobbin won't catch, so it can't be pulled up with the thread.what do i do?
  • 3 more comments
  • CarrieAH Jun 01, 2008
    I am having a problem with my M100. I was sewing some school projects that were made of "binker" or cross-stitch material and I think it was too much for the machine. But, now it doesn't want to work properly. The bobbin takes forever to catch, I really have to play with it...and when it does then the stitches are all "loopy" and wrong.
    Anyone got any suggestions?
  • NEEDLED25 Aug 28, 2008
    I have tried to thread the mini machine lots of times and the thead from the bobbin won't pick up what can I do?????
  • vixhobo Mar 07, 2009
    i was making denim curtains and it was too much for the machine the stiches went all loopy and now it wont sew at all!
  • VARILEY5 May 13, 2009
    HOW DO I RETIME THE MACHINE
  • Anonymous Mar 12, 2014
    hi -I am just setting up my janome sewing machine. I have wound a bobbin, but there is there is already a bobbin in the case. how do I get it out?
Providing you have checked to make sure the needle is in correctly, if the machine will not pick up the thread then the machine will need retiming.
Posted on Jan 22, 2008
Janome sew mini will not fill the bobbin
a part of the bobbin winder is not working and should be checked
Mar 25, 2014 | Janome SEW MINI Mechanical Sewing Machine
John Lewis mini sewing machine
This was really helpful for me fixing my daughter a John Lewis (janome) mini sewing machine, and now can get the bobbin thread up again, however, when you sew, the thread is not staying in stitches, just coming off the material completely. I tried forcing the gears on one more time but then it didn't pick up the bobbin thread again so went back to the other gear position. Any ideas of what to try and get it stitching again? Thanks
Apr 02, 2013 | Janome Mini Compact
Janome 3000 bobbin thread will not catch. It just quit while I was sewing. I've cleaned the bobbin case and anything else I could but when I put the needle down the thread does not circle the b
try changing the needle
rethread the machine top & bobbin
make sure to use every thread guide
make sure the bobbin is not over wound
make sure the bobbin is turned the right way in the bobbin case
make sure the bobbin is not warped or damaged
if you've done all these things then it's also possible that the machine
is out of time & needs to be checked at a repair shop
Sep 01, 2012 | Janome Memory Craft 3000
Janome sew mini needle not picking up bobbin thread.
Hi: Is this a needle provided with the machine as new? What type of fabric are you sewing... have you tried a different fabric? Is the bobbin placed into the machine correctly with it unwinding in the right direction?
Aug 10, 2012 | Janome SEW MINI Mechanical Sewing Machine
Upper thread not engaging bobbin thread...
Hiya Kandie. Usually when you can't pull the bobbin through, the wrong size needle is in, try a different size needle. Hope I was some help for you.
Feb 08, 2012 | Janome SEW MINI Mechanical Sewing Machine
This machine came with a very limited Manuel. The bobbin thread is knotting up and not catching as it should. I've re threaded several times removed and reinserted the bobbin, but can't seem to find the...
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 22, 2011 | Janome SEW MINI Mechanical Sewing Machine
Janomes sewing machine bobbin
Hi. Check to make sure the needle is in correctly. There is a flat side on the needle shank and that has to be facing a particular way. For most modern machines, the flat side of the needle faces to the rear, away from you, but it's always a good idea to check the manual to make sure on your machine. If the needle is bent, that can cause the same thing, but it's almost always that the needle is in wrong.
Happy Sewing!
Robbie
Apr 16, 2010 | Janome Mini Compact
SIMILAR PROBLEM OF TOP THREAD ACCUMULATING IN BOBBIN AREA
it sounds like a needle threading problem. if you have the instruction book, pull yout needle thread off the machine and re-thread as per the book ie presser foot up and make sure thread goes betwen tension discs and up over takeup lever.
to check needle tension is ok, lower presser foot and pull needle thread through needle, the needle thread should be tight enough to bend the needle a little.
goodluck,
scott.
Jul 28, 2009 | Janome Mini Compact
Janome sew mini will not pick up bobbin thread
Oil the machine first. Then, determine whether or not you need any parts at all.
Jul 03, 2009 | Janome Mini Compact
Janome mini sewing machine not picking up thread
Is it under warranty? A dealer should be able to check it out without cost to you. Do you have the bobbin in properly.
Oct 18, 2008 | Janome Mini Compact
Sewing Machines Logo
530 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
