Question about Keurig Special Edition B60 Coffee Maker
Keurig not pumping water at all
It's not that it is pumping less - it doesn't pump water at all! This has happened with 3 other Keurigs that I've owned and I've just replaced them, but it is my common theme and I'd like to know if I can fix it. Thanks!
Judy in Arkansas
  • hoxiesgirl Jan 22, 2008
    Would it calcify with purified water? I've thought I was safe because of the water I have been using, purified, filtered, etc, but I'll sure give the vinegar treatment a try. Nothing to lose! Thanks for your help. j
  • 2,039 Answers
Hi judy im pierre in montreal canada. judy do you decaicify once in a while caicium a killer that stuff is like ciment it clues the inside of the machine try to decalcify you said the pump is fryed put the stuff in leave it there for a few hour put it on try it use a turkey blaster to prime the pump hopefully it will start if it does work dont forget to rinse it very good very corosif stuff take care cheers
Posted on Jan 22, 2008
  • pierre laplante Jan 22, 2008
    vinegar is not strong enought buy the special solution for that
I received a coffee marker about 3 years ago and it always only made 1/4 cups of coffee i never thought anything about it until i went over a friend of mine they have the same one and theres make 3...
Clean it out. If there is a partial clog, some Keurigs will pump some of the water back into the tank. See if this is happening when you brew. Then clean the brew head water input (stick a paper clip or similar up the shaft and wiggle it). If this is still a problem, replace the filter in the water tank.
Mar 05, 2014 | Keurig B60 Coffee Maker
Tip
Keurigs with Side tank not pumping water
Those of you having a pumping problem with the Keurigs with side maounted tanks. It seem that the screen in the base when you liftout the tank you can see it, has a tendency to vapor lock due to the small mesh and pump height. I corrected this by putting 4 larger holes in the screen which is plastic with a pointed object just be careful not to go to far down or you will puncture the hose for the pump. After doing so I have not had a problem with my pump supplying water for the last 2 weeks to the heat tank, if your pump is not humming or working this will not work. This is a fix for those that remove the tank and set it back and the pump works when this is done you are forcing water through the screen breaking the vapor lock so try it, if it works fine
on Feb 10, 2011 | Keurig Platinum B70 Coffee Maker
Keurig machine not pumping water.
Tube from Filter area clogged. Clean that first.
Jan 27, 2013 | Keurig B70 Platinum Brewer
Keurig b40 pump out of sync
PLugged exit port tube. Manual Page 18
Jun 24, 2012 | Keurig Elite B40 Coffee Maker
I purchased a B70 Keurig brewer less than a year ago and now it will not pump water.
That happened to mine. The pump broke. They sent me a new one at a "discount" but now after 2 months I have issues with this one. Can someone PLEASE make a coffee machine that will work? Preferably one NOT by Keurig that uses the K cups and the K cup you can use your own coffee in?
Oct 22, 2011 | Keurig Platinum B70 Coffee Maker
My pump on my keurig b66 does not work all the time and when it does gives less water.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Mar 25, 2011 | Keurig B66 3-Cup Coffee Maker
Looses prime.
Feb 09, 2011 | Keurig Platinum B70 Coffee Maker
Won't draw water from the resevoir.
It's a known problem with keurigs pump. Call Keurig, they will have you send back the original cup from your machine in a padded envelope and they will send you a new machine and direct you to throw the old one out.
Jan 10, 2011 | Keurig B70 Coffee Maker
This is the 2nd B60 that appears to have a pump
I unplugged mine and it fixed the problem.
Jun 03, 2010 | Keurig B60 Coffee Maker
My Keurig platinum B70 will not pump water through the system. It says "Ready to Brew",I push the brew button, it says "Brewing", but nothing happens. It also defaults to the largest cup size, and will not...
Please get a hold of the company at the number in the manual, they will send you a new one if they cannot fix it. Magic words, I got it as a gift three months ago, it worked fine until now. Worked on mine. Sending out a new one today. This company works with you until you are happy. and I am getting 4 boxes of coffee! Free!
Dec 01, 2009 | Keurig Platinum B70 Coffee Maker
Keurig Special Edition B60 Coffee Maker Logo
1,139 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
