Question about Sony VO-9800 VCR
Head Hours What exactly are head hours and can i verify the number? (is the vo too old for that?)
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 79 Answers
I have replaced many an upper drum on u-matic VCRs. They were mainly used in Thompson flight simulation fair ground rides and were on all day every day. The original heads that come with Sony Professional and Broadcast kit last twice the recommended time before suggested replacement. HOWEVER, the replacement heads you obtain from Sony spares last shorter and must be made of a softer compound.
Posted on Sep 27, 2008
    Problem Solver:
  • 10 Answers
Nope it's in the user menu and you have to have video going into the deck to read it on the monitor video out put. Head hours are the time the tape actually is in contact with the drum and the most accutate easy indication of drum ware. 3/4 Umatics don't eat heads as a rule. I think I only replaced 1 out of hundred for thousands and thousands decks. Brokers love head or durm hours tipically it's T2 on the menu.
Posted on Jan 27, 2008
How many hours to do head gasket 1999 tahoes
Most shops charge abt 9 to 11 hours labor to do both sides. It is a fairlyI involved repair.
Sep 23, 2015 | Cars & Trucks
How many hours and how much is the cost to replace a head gasket on a BMW 528 I
Most shops will quote about 11.5 hours of labor at about $95 to $125 per hour. An experienced tech can do the job in 8 hours but you will likely get charged the book rate of 11.5 hours. Gasket set is about $250 or more from a shop or order it form Autohaus for $195. Also add in the cost of radiator fluid and synthetic oil and filter. Other possible costs will be head resurfacing, valve job, or total head replacement if you have a crack in it. Also consider replacement of water pump and thermostat at this time. Total at a shop, depending where you go, will run from low end of about $1,500 up to $2,500. Much higher if your head is gone and needs replaced.
Apr 02, 2011 | 2008 BMW 528i Sedan
How to change the head gasket on a 1998 cavalier.
take off the belts mark timing marks before doin soo save you hours white chalk or black magic marker but then you have 16 bolts in the head have to take out then head lift off scrape old off (this is important make sure the gasket surface 100% clean then put new on and then put all back togethor make sure timing is exact you will have to unplug a bunch of senors and wires but thats around a 12 to 22 hour job depending experience make sure change oil after wards too
Sep 14, 2010 | 1997 Chevrolet Cavalier
What is the formula for caculating velocity?
velocity = distance divided by time
for more clarification, check this link
http://ceres.hsc.edu/homepages/classes/astronomy/fall97/Mathematics/sec5.html
Jun 23, 2010 | SoftMath Algebrator - Algebra Homework...
Can you give me a ballpark figure on replacing a head gasket on a older Craftsman riding lawn mower...
there are many variables, since you didn't give any specifics. if it is an older, single cylinder, L-head engine, labor would be roughly 1/2 hour; if an older twin, L-head, about 1 hour; if it's a kohler, add about 1/2 hour; if it's a single, OHV, about 1 hour; if a twin OHV, 1 1/2 hours; if a kohler, add 1/2 hour. each shop has it's own labor rate. flat rate manuals will vary and are not realistic when dealing with old, possibly rusted or frozen bolts, which will increase the cost of repair. a new head gasket will usually cost between $5 to $30, depending on which engine you have. {some older craftsmans had a briggs laid sideways or an onan. these will require a lot more work and the labor would be higher]
Aug 31, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a c86 printer. The test on the 4 color ink patterns says nothing. I have cleaned the heads numerous times and have replace all of the ink cartidges twice. Same old situation. I have used Windex to...
You can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully
into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any ink on the nozzle check, then there is hope! Repeat the head clean/ nozzle check process 2 or 3 times, but not more. Leave for 24 hours for any air bubbles to disperse, then repeat. If nothing, repeat the soak process once more. If still nothing, post a new comment detailing what you have done and the results.
May 01, 2009 | Epson Stylus C86 InkJet Printer
Ghost Ink
Hi Powerstone03, the solution below is probably not relevant to you. Please respond to my queries above if you still want help.
Hi barron scalp
Are you confident the new cartridge was full and in-date? Can you confirm that the old cartridge was not removed until immediately before the new cartridge was installed. Did you remove the yellow tape from the new cartridge before you installed it? Was the black cartridge change properly completed such that an ink charging cycle occurred. Have you retried any further head cleaning cycles after leaving the printer alone for 24 hours or more? If not, do it. Any sign of black ink now? Yes, but not perfect? If so do a couple more head cleans and nozzle checks. If still not perfect, let it rest for another 24 hours to disperse air bubbles. Then repeat. Patience is needed here.
If you still have no result, and you're sure you have a good ink cartridge properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position by hand (do NOT turn the printer on) so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean again. If still nothing, report back
Jan 24, 2009 | Epson Stylus C62 InkJet Printer
Dirty head
To find this information you will have to either go to the Panasonic customer support website and enter your palmcorder model number and check out the frequently asked questions to see if they have already asked this question and have a answer in the form. the website is (http://www.panasonic.com). you can call the customer support telephone number at 1-800-211-7262. Between the hours of 9am-7pm EST. You can also use the customer support e-mail at www.consumerproducts@panasonic.com Give them the Brand name and model number of the palmcorder and ask them for the correct connection procedures to find and clean the palmcorder tape heads. I Hope this information helps you with your palmcorder problem.
Nov 26, 2008 | Quasar VM-D51 Camcorder
Motor runs rough
Hi,there. I would suggest you do a compression test to verify that the cyl head was installed correctly.If the compression is good,i would check for codes stored in the computer and go from there.Good Luck!!!
Aug 04, 2008 | 1993 Pontiac Grand Prix
Black ink
Leanne83 and jzig - I presume your problems are solved by now. If not, please respond with a new comment.
Guest
Are you confident the new cartridge is full and in-date? Can you confirm that the old cartridge was not removed until immediately before the new cartridge was installed. Did you remove the yellow tape from the new cartridge before you installed it? Was the black cartridge change properly completed such that an ink charging cycle occurred. Have you carried out any head cleaning cycles? If not, do it. Have you done a nozzle check print? If not, do it. Any sign of black ink? Yes, but not perfect? If so do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat.
If you have already done lots of head cleans with no result, and you're SURE you have a good ink cartridge properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try up to 3 head clean/nozzle checks again. If still nothing, post a new comment with full details of what you have done and the results.
Nov 17, 2007 | Epson Stylus C40UX InkJet Printer
Sony VO-9800 VCR Logo
378 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
