Loud clattering noise
-Open the Front Cover.
-Remove the Toner Cartridge
-Remove the Drum Cartridge
-Next locate the black gear attached to the end of the Drum and turn it with your fingers.
-Check to see if the gear is locked, or difficult to turn. The gear will only turn in one direction.
-If the gear won't turn at all, or if it catches while you are turning it, or if you hear the same noise when you turn the gear that you heard when the machine was on, the Drum Cartridge is the cause and will need to be replaced.
I have the same noise problem. After a print, the cooler is making a terrible noise for about 10minutes. I have called Samsung as this MFP is still under warranty but the only thing they said was that there will be a firmware upgrade availbable that should reduce the fan speed. This was told to me in oktober 2007 and until now there is still no firmware upgrade available... Samsung also refuses to take back the MFP and replace it. Great job, samsung!!
