Question about Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint FFA70 Making a loud buzzing noise, freezer will not close with top 2 shelfs in place even though there is no obstruction I have removed the 2 freezer shelfs but it is buzzing crazy please help!!
  • ajw1976 Apr 10, 2008
    I don't have a buzzing noise, but I have hte same problem with the top two trays.
Remove the plastic venting box which feeds cold air over the top of the freezer drawers,There are 4 hexagon headed self tapping screws,two at top.and two bottom.Now defrost all ice off rear of freezer and back of vent box.Now replace and door will shut with draws in.Make sure no ice left round fan housing.
Posted on Apr 11, 2008
6ya staff
SOURCE:
GE profile fridge making loud humming noise
The door being open so long caused warm moist air to collect and freeze inside the unit.
Take everything out, unplug it and let it thaw out for an entire day. All the frost will thaw, and probably run water all over the place so put towels down.
When you plug it back it, it should work fine.
Jul 26, 2014 | Refrigerators
What is causing loud whirring noise in FFA-70 freezer with high freezer temperature and is it likely to be economical to fix?
Think you will find. That ice build up is preventing door closure and also the fan is being obstructed by the ice suggest you empty freezer and defrost for at least 24 hours, be prepared for a lot of water as ice melts
Jun 04, 2014 | Hotpoint FFA70 Bottom Freezer Refrigerator
Subzero 550 freezer making loud noise if top wire shelf closed
When you shut your top wire shelf you do a few things. First of all you activate your fan. Your fan sits in back of a large evaporator coil which is prone to defrost issues. I would imagine your fan is hitting ice due to a defrost issue. You may want to check your defrost system out. Ie your defrost timer.
or alternatively your fan could be getting old and needs replacing, it could just be making noise.
Joe B, Certified refrig.
Apr 04, 2013 | Freezers
Diverter valve on Hotpoint FFA70 recieves no power, Fridge ok
Bonjour..Your system check (hot cold) is correct. Generally all new refrig/freezers cool only the freezer & bleed cold air off to cool the refrigerator. Most diverter/airflow dampers I have seen are mechanically operated for simplicity & to keep costs down. I would unload freezer and pull the panel off where you see the fan mounted. Go slow, don't drop any screws.You may not get them back. Look at the drain pan under the evap. coil. If it has ice that is built up in layers. Suspect the defrost termination thermostat. If the evap coil is clogged with heavy frost, suspect 1 the defrost timer and 2 the defrost heaters mounted on the evap. coil. Let me know how you make out.
Parts http://www.repairclinic.com/Refrigerator-Parts?s=t-Hotpoint+FFA70-%3d%3da4&z=50
Jul 02, 2012 | Hotpoint FFA70 Bottom Freezer Refrigerator
Noises in freezer area of refrigerator
Some refrigerators have a small plastic fan under the bottom shelf of the freezer that circulates air. It's not too unusual for a heavily loaded shelf to rub the fan blades making the noise you describe. If you empty the freezer, you'll fin a few screws holding the bottom shelf in. remove the shelf and inspect the fan and surrounding parts for signs of rubbing. Also tug on the fan blade lightly to see if it is still attached to the motor's shaft securely. New fan blades can be purchased at a good appliance repair shop. Good Luck
Nov 30, 2009 | Hotpoint HTR16BBSR Top Freezer...
Freezer struggling
it might have a leak with the refrigerant and the compressor motor is having a hard time. Time to have it checked by a qualified tech if it's worth it
Aug 10, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
My freezer stopped freezing and is making a loud buzzing noise with the red light on at the bottom. Cant sleep HELP
the loud buzzing is the freezer high temp alarm. dont know why its warm though.
make sure you don't store anything on top of or on the sides of the unit as the condenser of most freezers are buried in the walls of the unit and it will over heat the compressor. if unit is in a hot garage this will compound the problem.
Jul 02, 2009 | Frigidaire 20.3 cu. ft. Upright Freezer...
Model HSS25IFMCCC GE Refrig motor/fan making loud noise
UN THAW YOUR REFRIGERATOR FOR 8 HOURS IF IT STOPS GREAT IF NOT.REPLACE YOUR FAN/IT IS LOCATED BEHIND THE TOP PANEL OF YOUR FREEZER.UN PLUG YOUR FRIDGE FIRST.BUY THE PART AT A APPLIANCE PARTS STORE,AND YOU CAN DO IT IT IS A EASY REPAIR.
Jan 16, 2009 | Hotpoint HSS25GFP Side by Side...
Hotpoint FFA70 - Freezer door will not close properly.
The rear panel can be removed,i have done it.I removed the 4 hex head screws from the top & bottom of the panel,and firmly pulled it forward.The reason i say pulled firmly is that when panel came out the back of the freezer was solid with ice.I have defrosted the freezer,dried any water from the unit and replaced the panel.Fingers crossed,so far,so good.In my case this build up of ice was definately the reason the drawers were not sitting in the correct position,as it caused the rear panel to 'bulge' out.Hope this helps.....
Dec 11, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint ffA71
ffa71 fridge and freezer warm and food defrosted. red light is on. Back of freezer making normal noise. Help.
Aug 27, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint FFA70 Bottom Freezer Refrigerator Logo
350 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
jdthefixer
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
