Question about HP PSC 1210 All-In-One InkJet Printer
Printer blinking so, the printer  "check paper" and "check print cartridge" lights are both blinking, though I've checked both. also, in the window with the number of copes wanted there is an E. what might I do? thanks! Emily
  • Reijo Jan 22, 2008
    I am having the same problem. I needed to replace my black cartridge and did so but am still getting the same error message. I unplugged the printer, checked for paper jam and still nothing.
  • Reijo Feb 23, 2008
    Printer says "check print cartridges" and there is an E in the window with the number of copes wanted. It appeared from my printing that I needed a new cartridge which I bought. When it was replaced my printer printed the test page and again I got the same message. I unplugged it for about 5 minutes, plugged it back in, got the test page and again the E. I've done this several times with the same problem. Could it be that I need a new COLOR cartridge as well? I hate to put more money into this printer if it's something else. Any advice?
    Genius:
  • 1,003 Answers
The E usually represents paper jam
unplug from wall socket and then replug and try printing
Posted on Jan 21, 2008
I own a HP PSC 1500 All-in-One Printer. Recently, when I turn on the printer, the Check Paper and Check Print Cartridge lights (both orange lights) flash. I have gone to the HP Troubleshooting site, d
Have you installed the latest printer driver? What operating system do you have - Windows 7 or 8? This sounds kinda like your printer may have been slightly fried by a lightening strike. Is it protected by a surge protector? Can you print a test page from your operating system?
Nov 28, 2014 | HP Office Equipment & Supplies
Orange light blinking, cleared paper jam, changed printer cartridge, won't print subsequent documents.
Double check all doors/ rollers for small pieces of paper stuck in the rollers. Sometimes just opening the door in question and closing will reset the paper jam sensors. Paper jams can be smaller than your pinky finger nail. So double check,
Comment if it still isn't working.
Oct 21, 2011 | HP Deskjet F335 All-In-One InkJet Printer
My HP Deskjet 1120Cxi fails to print normal document and test printing. My computer operating system is window XP
Power on the machine, check front panel 'cartridge led' blinking? replace the cartridges,if 'paper led blinking' indicates paper jam check for paper jam.If printer comes in ready mode check in system drivers its is ready mode?.. if no check parallel cable if its good replace formatter..
Sep 06, 2011 | HP Deskjet 1120c InkJet Printer
Is only blinking and not printing when i try to print the usb conect successfuly to the compter but the printer is not printing the light is only blinking
The blinking light could indicate either a paper jam, communication problem between one of your cartridges and the printer or a short in one of your cartridges. Please follow the steps below to identify and fix the problem:
  1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
  2. Open the printer cover and remove both the cartridges.
  3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
  4. Close the printer cover.
  5. Unplug and re-plug the printer into the power source to reset it.
  6. When the printer turns on, reinsert one cartridge first.
  7. Close the printer cover and check the light status.
  8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
  9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
  10. Load some paper. Try to print again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 11, 2011 | Lexmark X1150 All-In-One InkJet Printer
Check paper/Check print cartridge light blinks even though I have done both. Also keeps grabbing a sheet of paper and pulling it halfway through the machine. Will not print?
The HP Customer Care site says that if th check paper and check print cartridge lights are blinking, it is most likely that the carriage assembly, which holds the ink cartridges has stalled against the left side of the printer.
HP includes extensive troubleshooting instruction for correcting this problem at the following link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00095908&lc=en&dlc=&cc=us&product=374568
Hope this helps... their support site has been very helpful to me in on several
occasions.
Oct 13, 2010 | HP PSC 1315 All-In-One InkJet Printer
Printer mechnical error
Resolving a blinking light When an error occurs, the power light will blink continuously and an error message will appear on the computer screen. Read the onscreen error message explaining the problem and follow its solution. If no error message appears, go to the Maintenance section in the Printer Assistant and click any of the four main buttons. This will prompt the software to check the status of the printer and the error message should then appear. The following table lists possible causes and what to do to correct the problem. Symptom Possible cause What to do to correct the problem Power light is blinking Printer cover is open Close the cover. Printer is out of paper Insert appropriate media in the In tray. Printer has difficulty picking up label media
  • Change the printers print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
There is a paper jam Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the Power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
There is a problem with a print cartridge Follow each of these steps until the problem is resolved:
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Power light is blinking and/or there are missing lines or banding issues on the printout The print cartridge has partial loss of electrical interface with the carriage connections
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Sep 10, 2009 | HP DeskJet 3650 InkJet Printer
Flashing on/off light on hp deskjet 3520 printer
Introduction The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused. NOTE: The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking." Blinking lights Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first. Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution. Issue: Power light is blinking
c00374282.gif Solution
Close the cover.
Cause
Printer cover is open. Solution
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
Cause
The printer has difficulty picking up label media. Solution
  2. Press the power button once. Wait a moment for the paper jam to clear.
Cause
There is a paper jam. Solution
Cause
There is a problem with a print cartridge. Solution
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
Mar 03, 2009 | HP DeskJet 3520 InkJet Printer
When try to print the check paper/ink cartridge light blinks and printer wont print.
If both the Check paper, and the Check Cartridge Lights are blinking, this indicates a Carriage Jam. Follow the instructions here to clear this error.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&rule=8471&product=1146331&docname=c01447224
Dec 29, 2008 | HP Photosmart C3180 All-In-One InkJet...
Printer paused-unable to read
HI there,
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
Oct 04, 2008 | Brother HL-2070N Laser Printer
HP PSC 1210 All-In-One InkJet Printer Logo
167 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
