Question about Mitsubishi WS-55313 55" Rear Projection HDTV-Ready Television
Followup: Mitsubishi WS-55313...shorted green/CRT
Yes, I should have mentioned that I switched up the wires to make sure it wasn't a short in the controls. It disrupts the picture on the green, no matter what control that CRT is hooked into. So what do you do about a shorted out CRT?
I don't see anything loose or any visible problems with soldering etc.. whatsoever...Can you buy and replace these things very easily?
  • Mitsubishi Master
  • 8,617 Answers
You can purchae the tubes from between 200 and 300 dollars. To remove and set them up you will need the service manual for the safe and proper proceedure . Especially discharging the crt and realigning the new tube Green has to have perfect aim as the other tubes converge onto the green. Let me know if I can help you further.
Posted on Jan 21, 2008
My 55313 power light dose not come on
The SMPS section is not oscillating. Your TV need a through checkup. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electric shock. Instead, contact any experienced service technician, or the nearest service center.
Apr 24, 2013 | Mitsubishi WS-55313 55" Rear Projection...
What does code 2.2 mean. that's what i get on my ws-55313 ty.
It means short protection.
98% chance one of the two pico fuses that protect the convergence circuit is blown.
Repair entails replacing the two STK-394-250 CHIPS AND THE BLOWN FUSE.
This may or may not be a do it yourself repair.
Let me know if you have questions, total parts cost would be about 35 dollars.
SD TECH
Jan 15, 2011 | Mitsubishi WS-55313 55" Rear Projection...
WS-55313 Where can I find replacement Lenticular screen?
800-553-7278 CALL MITSUBISHI PARTS
A WS-55413 LENTICULAR SCREEN IS $171.10 + DELIVERY BUT THE DIAMOND SHIELD ISNT NEEDED THEY TELL ME AND IT WAS DISCONTINUED ANYWAYS BUT YOUR PART IS PROBABLY AVAILABLE THERE.
Nov 24, 2010 | Mitsubishi WS-55313 55" Rear Projection...
I have a Mitsubishi WS-55313 55 in. Rear Projection HDTV. My problem is, the picture suddenly goes to a black screen, while the audio remains. When I turn the TV off, and then back on, I may or may not get...
your dose not use lamp, it is a crt driven TV . One of com problems for that model was loose connection on one of the yokes. When that normaly happens , there is a sudden flash and screen gose dark and sometimes it can flash back if not you get red light blinks. If you you know where the yokes are at check little small board . A small mirror will come in handy, access from front of TV. adios ... john
Mar 31, 2010 | Mitsubishi WS-55313 55" Rear Projection...
HDTV Reception
Yes , If  a  high definition device is connected to the tv then you can watch high deff tv.
Dec 21, 2008 | Mitsubishi WS-55313 55" Rear Projection...
Deflect power supply
PCB Power has the Deflection Power Supply onboard and has a list price of $215.50 + S/H
Nov 10, 2008 | Mitsubishi WS-55313 55" Rear Projection...
Mitsubishi ws 55807
The green Crt for your set is part number 251C207050. You said that you cleaned up where the fluid leaked but if even the slightest is left it can and will short this board. You are looking at about 200-250 for this CRT and if it leaked you would want it replaced. I couldnt find any in stock anywhere most had feb ship dates. You can get it from andrews electronics and union electronics.
Feb 06, 2008 | Mitsubishi WS-55807 TV
WS-55807 power up problem
If you are handy with a multimeter you can check all of the pico fuses the little green 5 amp fuses. Most likley you will find one of those shorted F95A01 most likley but could be another. You will need to change this and also your convergence amps. These three parts are most likely shorted in your set. You are looking at about 250-350 from a competent repair shop.
Feb 04, 2008 | Mitsubishi WS-55807 TV
Lines horizonal - seems to be caused by voltage to green CRT
Your green CRT is shorted. To test put your red crt socket on the green and your red on the green. then try turning up red control if the green now works its not your tube. If the same thing happens with the red socket on the green you can be sure its the green CRT if the green works properly with the red socket, then you have a problem in the green drive circuit and not the CRT. hope this helps.
Jan 19, 2008 | Mitsubishi WS-55313 55" Rear Projection...
Blue Screen
Sounds Like Bad Tuner,Try Running Audio Video Jacks in,Also Replace your Cable wires ttech
Jul 29, 2007 | Mitsubishi WS-55313 55" Rear Projection...
Mitsubishi WS-55313 55" Rear Projection HDTV-Ready Television Logo
104 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
